Question about Pioneer GM-5200T Car Audio Amplifier
Red light on on amp
Whenever I take fuse out green light comes on when I put fuse back in red light appears
    Night Owl:
    An expert who has answered 10 or more questions between 12 midnight and 6am on the same day.
  • 104 Answers
Take speaker wires off amp if the lit is green then speaker are hooked up wrong or blown.
Posted on Apr 02, 2014
    Problem Solver:
  • 5 Answers
If the speakers are not shorted then the amp most likely has shorted outputs or a blown power supply.
Posted on Apr 30, 2014
I have a Peavey Renown Solo Series guitar amp. It's 450 Watts. It's a great sounding amp. My problem is that now when I turn it on, the light comes on but there is no sound. This used to happen a few times...
You'll need to have the amp in for some troubleshooting. It's not easy to say what the problem is and it could be a number of things. Also, that 450 watts is the power the amp uses, not how much audio power it puts out. The Renown was originally made in a 160 watt format and on the back of it, it says "450 watts" on the left side of the back, but that is the power it uses... This is why I say you should take the amp to a shop...
Oct 13, 2010 | Audio Players & Recorders
Red light
try runing the remot to the battery and c wat it does
May 14, 2010 | Dual 2-Channel Bridgeable MOSFET Amplifier...
Is the horn relay in the fuse box under the hood?
Under the hood, NOT in the fuse box. Hard to tell you which one, but its the 4th one back, 3 wires, Light Green, Light Green and Red, and Black and Red. The Light Green is HOT and comes from the fuse 32 (15 amp)
May 10, 2010 | 2004 Nissan XTerra
Amp runs but then will just turn off and red light comes on
you may have fried the amp pre outs in the head deck, try the amps on another stereo
Jun 01, 2009 | Lightning Audio Bolt B2.150.2 Car Audio...
Need a radio wire diagram for 1989 ford mustang 5.0
Radio Connector:
Light Green / Yellow - Hot at all times (Fuse 8)
Yellow / Black - Hot in ACC or Run (Fuse 11)
Light Brown / Red - Goes to instrument panel dimming rheostat (Fuse 4)
Red - Ground
White / Purple - Hot in ACC or Run (Fuse 11)
Speaker Connector:
White / Light Green - (+) Right Instrument Panel & Door Speaker
Dark Green / Orange - (-) Right Instrument Panel & Door Speaker
Brown / Pink - (+) Right Rear Speaker
Pink / Light Brown - (-) Right Rear Speaker
Pink / Light Green - (+) Left Rear Speaker
Tan / Yellow - (-) Left Rear Speaker
Light Brown / White - (+) Left Instrument Panel & Door Speaker
Orange / Light Green - (-) Left Instrument Panel & Door Speaker
Apr 04, 2009 | Sony CDX-GT320 FM / AM / XM Radio / Sirius...
Green light turns red on hard notes with kicker 750 mono amp
First off, never, ever replace a blown fuse with a bigger one (especially one that is almost twice as big) unless it's an absolute emergency. Most of the time, the reason a fuse blows is because of a problem with the device (in this case, the amp). By installing a larger fuse, there's a very good chance the problem will become permanent (i.e. busted amp).
The amp could be going into an overcurrent mode when the bass hits and power cycling itself to try and reset the problem. If this is the case, take it to a local electronics repair shop and see what they can do.
It's also possible the input voltage to the amp is dropping too low during the bass hit, making the amp restart. Try putting a 1.0F or higher capacitor on the battery to buffer the power during the bass hits.
Mar 16, 2009 | Kicker (ZX750.1) Car Audio Amplifier
When tv is turned on green light comes on then goes to standby
had the same problem on mine.
Found loose solder terminals on the main power transformer, resoldered fixed it up about 5 min.
Nov 01, 2008 | Pioneer SD-532HD5 53" Rear Projection...
My "Power Acoustik OV2-420" has a problem. Some advice please!!!
It appears that the output transistors have failed. To eliminate other possible causes, read through the following page. Let me know if you have any other questions.
Amp in Protect Mode - Troubleshooting
Oct 04, 2008 | Power Acoustik GOTHIC OV2-1200 Car Audio...
PS3 doesn't appear on screen. Possible power issue.
Hello. There are a few causes for this. I will list acouple solutions for you.
1. Reset the Video Output Settings. While the PLAYSTATION 3 system is in standby mode (red light on the front of the system), hold down the touch-sensitive On/Off button on the front of the system until the system goes into standby mode again . (So the light cycle would go from: red light to --> green light --> then back to red light) This will ensure that you have held down the On/Off button long enough to reset the Video Output Settings. Once you turn it back on, it should work fine.
2. If option 1 does not work call Sony because the video out chip has blown or come unsoldered.
I hope this helps. Good luck to you.
Jul 27, 2008 | Sony Playstation 3 (PS3) Console
Power protector light on sony xplode 1000 watt amp
a green light is the power indicator, a red light is when the protector is in affect
May 30, 2008 | Sony Xplod XM-554ZR Car Audio Amplifier
Pioneer GM-5200T Car Audio Amplifier Logo
171 people viewed this question
Top Pioneer Car Audio & Video Experts
Michael Kovalik III
Michael Kovalik III
Are you a Pioneer Car Audio and Video Expert? Answer questions, earn points and help others
