Behnegar The copy machine is not ready to print
    Champion:
    Habit-Forming:
  • 210 Answers
There are a lot of problems that can keep a copier from printing. You will have to go through step by step of re-installation and checking. Is it plugged in and on? Is there ink? Is there a problem with the programming?
Elisa Jed ' http://stores.abmcopier.com/canon-color-pre-owned/
Posted on Jul 15, 2014
Copy Machine is running ready but can't print and copy.
The paper tray is not placed properly leading to erroneous sensing place the paper trays properly
Jun 22, 2015 | Canon ImageRunner 4570 | IR4570 |
Hi dear sir I have Ricoh 700 machine it was working fine but yesterday it's got some problem when I switch on its showing ready when i make the copy its scan the paper but not print stay on same place but...
You should try resetting the machine if you can. Taking out power cord will not reset machine. The micro chip has to be reset on the machine. If test / counter print works but copy doesn't work, then reset machine.
Nov 26, 2014 | Office Equipment & Supplies
Double sided copies
Your printer has Duplex printing Capabilities. However when you are ready to send the print job, open the Printer Properties and select Double Sided.
To copy a Double sided document, insert it in the ADF (Automatic Document Feeder) and open the copy settings on the machine and select Double sided.
Jan 07, 2014 | Office Equipment & Supplies
When I load paper, printer still says "out of
sometimes by just turning the machine on and lifting the copy cover and letting copy scroll back will reset machine so the software on your computer shows ready to print. Also you can print from top of machine or front may be trying to print from one while you have paper in the other.
Mar 02, 2011 | HP PS C4780 All in One InkJet Printer
I have a Sharp AL 1631 it won't print. It shows an H-4 in the menu screen
Press "Clear" then "Exposure Mode" then "Clear" then "Exposure Mode" quickly like within 4 seconds. The exposure mode key is the far left key.
If you do this correctly the display will go blank.
Key in 14 as if making 14 copies
Press the print button.
Short version: C, far left, C, far left, 14, print
The machine should reset and run fine. This is a common "false" code on these machines.
If it comes back after a couple of tries the you have a thermal fuse or heater lamp failure.
Nov 18, 2009 | Sharp AL 1631 Copier
Testing print cartridge
Printing is not possible with B-820. You can just make a copy of an original print. Put the original in the mentioned place, it displays 'Document Ready' then just press 'START' button twice. you'll get a copy.
Aug 11, 2008 | Canon FAX-B820 Plain Paper Bubblejet
I have a xerox dc12 with error message please turn machine off and on again 9-363 have tried several times but no good! what else can I do?
That's a process problem with that machine.
May require a service call .ON and OFF is pretty much all a customer can do and wait for it to setup.
NOTE: The problem occurs because of the trickle development system in the machine, making extended lengths of black and white copies / prints does not allow the black developer housing to purge itself of excess waste Toner (Dry Ink) and Developer. There are two solutions for the problem:
  • Make 1,000 copies / prints of a black and white job, then make 150 copies / prints of full color. Continue making 1,000 copies / prints of the black and white job, then 150 full color, and so on, until the entire black and white job is complete.
  • Make extended jobs in groups of 100 by making 100 copies / prints of the black and white job, then allowing the machine to cycle down (return to 'Ready') and making the next 100 copies / prints. Continue in this pattern until the entire black and white job is complete.
Apr 28, 2008 | Xerox DocuColor 12 Printer
Error 9-363
NOTE: The above solutions are based on jobs using 8.5 x 11 inch paper, single sided, with no more than 28% coverage.
Feb 18, 2008 | Xerox DocuColor 12 Printer
or
  1. Power OFF the machine.
  2. Wait 30 seconds.
  3. Power ON the machine.
Dec 04, 2007 | Xerox DocuColor 12 Printer
jasbo
jasbo
