Question about TurboChef TORNADO Electric Oven
F3 Mag Low Current
F3 Magnetron Low Current. Replaced HV Diadodes, Capacitors andMagnetron. F3 Fuse is blowing now.
  • 126 Answers
CHANGE Tranformer too. Did you check ampere at the blue wire looping at control board? Must be around 15 to 17 amps only.
Posted on Dec 08, 2014
    Problem Solver:
  • 6 Answers
Did you check transformers. also k1 , k2, k3, relays. also make sure all wires are put back right and the diodes are going in the right direction.
Posted on Mar 29, 2014
2 Suggested Answers
richroth
  • 9472 Answers
SOURCE: f 3 mag error. had a bad magnetron and hv
F3 errors can indicate a mag problem. Did you replace both mags? It can also be a door switch. If your fuses are good, you need to inspect the 2 magnetrons. If you have a burned tip on one the waveguide and waveguide cover it will need to be replaced.
Posted on Feb 05, 2011
F3 mag curr
F3 MAG CURR means you have a problem with the high voltage system in your oven, the microwave circuit.
The next part is extremely dangerous, if you have no background in electric STAY OUT. CALL A PRO you will be working with 5000 volts.
With that said you will need a clamp on ampmeter to measure the current to narrow down the problem.
Discharging can be done by unplugging the oven and then short across the red wire on each capacitor to the chassis with an insulated screwdriver.
1. Remove the top and right side covers.
2. Enter the test mode. (From the OVEN OFF mode, simultaneously press
BACK and ENTER keys, enter the code 9-4-2-8 and press ENTER).
3. Place amp meter on the brown "ct" wire for amp reading. Wire is coming from the primary side of the
HV transformers and looping through the black plastic current transformer on the main control board and back to the HV transformers.
4. Press and hold the MGTRON soft key on the keypad to energize the magnetrons.
5. Observe the amperage on the meter. Typical readings are:
NORTH AMERICA: 12-14 amps at 240VAC/13-16 amps at 208VAC.
If you are getting 12-16 amps then change the I/O board.
If you are only getting 7 or 8 amps then only one side of the of the HV system is not working correctly. You will need to figure out which side is bad by un-plugging the power wires going to one of the HV transformers. Then test again and if you get no amps you have found the bad side. Replace the HV transformer, cap and diode.
If you are not getting any amps then check the F3 fuse it will most likely be blown. Replace and start over"
Mar 09, 2013 | TurboChef TORNADO Electric Oven
"F3 MAG CURR" error message,
Its a big pain in the *** issue.
IF YOU KNOW HOW TO USE CLAMP AMMETER THEN ONLY YOU CAN USE MY METHOD TO TROUBLESHOOT IT.
MAKE SURE OVEN HAS 5000V IN THE CAPACITOR.DISCHARGE THEM FIRST .
AND IF YOU DON'T KNOW THEN STOP HERE
STEPS
1. open right side pannel
2. press back key to turn off oven
3. press back and enter key simultaneously.
4. enter 9428 then press enter.You are directed to testmode.
5.put clamp ammeter on the primary wire(orange in color).The one which come from top and looping the IO board.
6.Under Displaty screen you see Word Magnetron.Press and hold the soft key to energize the magnetron.
7.Check the amperage.It should be under 14-16 Amps.
8.If its half of the value or nothing comes then.
9 half value means(one magnetron is working
10. No value means F3 fuse blown and check the cause why it blown(physically look at the transformers and the capacitors and the diodes that they didn't burnt or change their shape.
IF YES THEN REPLACE IT.
OKAY LET ME KNOW IF YOU CAN REACH UPTO HERE .
AND REPLY ME
THNAKS
PLEASE RATE MY WORK
Sep 06, 2011 | TurboChef TORNADO Electric Oven
Hi, F3 mag curr. what is means and how do I fix it?
F3 is an complex code.
Easy fix is look at the transformers and the capacitors and the diodes.If it seems that any component has changed its appearence then fix it and replace the F3 fuse(3rd one from the front).
If the magnetron is bad ,then to check that you must know how to use clamp ammeter.
let me know if you know how to use clamp meter .
I will give you the solution .
NOTE oven has 5000V in it.
make sure you dischared the capacitors.
Thanks
please rate my work
Apr 16, 2011 | TurboChef TORNADO Electric Oven
F 3 mag error. had a bad magnetron and hv transformer. went head and changed both hv transformers,diodes,caps,magnetrons. worked for about 5 hours and its back to blowing f3 fuse. Any ideas
Feb 05, 2011 | TurboChef TORNADO Electric Oven
My microwave over works but no heat
Sorry to read about your problem, I hope this helps you out.
you could have one of the following issues
  1. Blown fuse in HV transformer primary circuit or HV fuse (if used).
  2. Bad connections (particularly to magnetron filament).
  3. Open thermal protector or thermal fuse.
  4. Open HV capacitor, HV diode, HV transformer, or magnetron filament.
  5. Shorted HV diode, HV capacitor (will blow a fuse), or magnetron.
  6. Damaged protective VDR from filament to chassis (not commonly used).
  7. Defective HV relay (not commonly used).
Microwaves must be serviced by technicians due to the inherent dangers involved in repairing these appliances. Internal capacitors can retain a lethal electrical charge even though the unit is completely unplugged. A microwave radiation leakage test must be performed on the unit following any internal component repair.
I tried to help you. Please help me and Rate/Vote on my response. We take the time to answer your question's. take the time to rate us.Thanks and good luck
4 Thumbs - Very Helpful
3 Thumbs - Helpful
Jan 02, 2011 | GE Ovens
Changed out multiple parts but still get F3 MAG CURR error. Any Idea how to fix
You Didn't say which parts you have replaced so i have nothing to go on.
But we will begin from the start. F3 MAG CURR means you have a problem with the high voltage system in your oven, the microwave circuit.
Good Luck If you have anymore questions just ask.
Nov 12, 2010 | TurboChef TORNADO Electric Oven
I have a f3 mag current error is coming.... and it is not heationg the sub enough...
Nov 08, 2010 | TurboChef TORNADO Electric Oven
What does f3 mag mean on the display?
F3: Magnetron Current Low
Fault is displayed when the current transformer
(CT) on the I/O control board does not detect
enough current. The fault is monitored when the
microwave is on during a cook cycle or self-test.
The fault is cleared from the display at the onset of
a cook cycle if the CT detects current or when the
magnetron is successfully energized in Test Mode
Sep 03, 2010 | TurboChef TORNADO Electric Oven
Getting f3 mag current reading
f 3 means blown fuse , which is located on the right side of the unit at the bottom , third one accross, once you have tested the fuse and found it to be faulty, before replacing it , you have to find out why it has failed, there are several reasons why this has happen , 1/ if primary and secondary interlocking door microswitches on left side panel open before monitor door switch on the other side ,it will put a short accross L1 AND L2 blowing F3 fuse , 2/ CHECK high voltage transformers to see if there are signs of burning on either primary or secondary windings, if you are not a tech or a electrician it is very hard to explain how to test to the other componets, capacitor doide or magnetron visual inspections is all you can do
Mar 11, 2010 | TurboChef C3 Single Oven
F3 FUSE BLOWING. DURING MAG AMPERAGE TEST 17.25 AMPS DOESNT BLOW FUSE AFTER 15 TO 20 SECONDS OF MAG TEST MODE. BLOWS 10 SECONDS AFTER STARTING TRUE COOK CYCLE. 208 VOLT OVEN. STEST SHOWS ALL ITEMS...
so you seem to know alot or enough to get by on this oven and you have the testing equipment clearly since you gave me the amp reading.
17.25 is just a little to high. Which is prolly why your having a hard time figuring out the problem. The next thing i would check would be the HV transformers. One of them is prolly pulling just to much. They should be somewhat even.
Discharge the HV Cap before continuing
Unplug the wire coming from the first cap to the transformer at the transformer and then energize the mag current record your amps
then plug that one back in and repeat for the other cap and HV transformer
hopefully you will notice a big difference in the amps between the two transformers
if that didn't work you will need to measure the windings of each transformer of which turbochef will give you this info
Also if the oven is working in test mode but not in a true cycle. Run it in a true cycle. Clamp your meter on then power up the oven and run the cycle that blows the fuse. See if the amps spike before the fuse blows
These fuses are expensive, too expensive to be blowing testing the oven. Bring the fuse to home depot and buy a bunch from them. There not an exact match, they will be a little short but will work for testing purposes. Once fixed buy the proper fuse from turbochef there around 10 bucks each
Good luck and don’t get down that you replaced those parts and its still not working. Most repair company’s replace all those parts anyway. Your typical bill to fix this problem is around 1800.
Oct 22, 2009 | TurboChef C3 Single Oven
TurboChef TORNADO Electric Oven Logo
470 people viewed this question
Top TurboChef Ovens Experts
Dennis Boxerman
Shehu Pro
Shehu Pro
Are you a TurboChef Oven Expert? Answer questions, earn points and help others
