Bosch Logixx 7. No power.
Made a funny noise and lights flashed on display. Wife turned the machine off. When I tried to turn it back on there is no power to the machine. have checked the socket and it is fine. changed the fuse in the plug.Still no power.
3 Suggested Answers
57 varieties
  • 1653 Answers
SOURCE: Bosch 1400 Exxpress washing machine : Turning off after a few sec
1. Switch off the machine and disconnect the mains power.
2. Remove the filter and make sure that the filter is not blocked and is clean and clear of all debris. Clean as required. Note that depending on the machine type you may get a lot of water coming out of the filter when you remove it if the machine has not drained successfully. Note that if the machine has stopped and not fully drained then you may be able to drain out the excess water by removing or disconnecting the waste hose and laying it on the ground in a tray.
3. Proceed by checking the drain hose for proper connection and kinks and make sure that it is not blocked.
4. Also check that the main waste drain pipe, if you use one, is not blocked and clean if required.
5. Reconnect the power and switch the machine on.
If the problem persists then do the following.
6. Switch off the machine and disconnect the mains power.
7. Check the electrical connections at the pump and make sure it is operational.
8. Remove the connecting hoses, and expect water to drain out and make sure the pipes are not blocked with debris or any object blockage.
9. Makes sure the pump appears clear and that the impeller looks in good condition.
10. Reconnect the hoses and then reconnect power and switch the machine on.
11. If problem has not been corrected, then remove the pump and check that the drive coupling to the motor is OK and that the motor turns OK. If all is well then replace the pump.
Posted on Oct 23, 2009
barkencoa
  • 3463 Answers
SOURCE: my washing machine wont turn
It is nothing to do with the extension lead you are using, sounds more like a board problem to me, or another fault causing the lights to flash.
Posted on Jan 03, 2011
Pls how can i unblock a pump on bosch logixx
Turn it anticlockwise
if it won't turn it has something inside jamming it
you will need to remove the pump and filter assembly and take it apart to clear it
Jan 08, 2015 | Bosch Logixx WFT 2806 Front Load...
Bosch logixx 8 varioperfect
you will have a broken spider in the machine
Jul 22, 2014 | Washing Machines
Bosch logixx 7 (5 years old) Serial No WIS24140GB/07 door will not open at end of programme. start/pause, 400, rinse, spin & end lights all flashing and a bleeping sound. To open door have to switch to off...
After trying to find manual and doing it the right way with no success my son solved the door problem with a metal fork. Where your hand meets the handle (inside the door drum) shove the fork in to force the clip open. Not the outer edge of the door, theres no locking system there - behind the actual handle.
Aug 29, 2013 | Washing Machines
Hi I have a Bosch Logixx 8 washing machine that
go to the manufactures website and download the user manual giving the model nr eric
Jan 19, 2018 | Bosch Logixx WAS2446 Front Load Washer
I have a bosch logixx 8 washing machine. Fault code f67 when I turn the machine on. What does this mean?
I have Logixx8 WAS 32782 that got the f-67 code. I had it repaired today and the technichan updated the software. f-67 was indicating "lost contact with display panel". The display panel had of some reason erased its software. SW update was the standard solution.
Oct 02, 2010 | Bosch Washing Machines
Bosch logixx code f-23 .wat does it mean?
it means the float at the base of the machine has been triggered. Open the back panel on the machine (turn off power and water tap first) then remove all screws and take metallic back off. Dry inside base with a towel and push down the float which is located in the corner. This will reset it. Keep an eye on it as it may mean you have a leak.
Aug 02, 2010 | Bosch Logixx WFT 2806 Front Load...
My manual for bosch washer dryer wft6 is in norwegian and display lights flashing as fault but cannot understand it
you can now download the manual for this appliance direct from the bosch web site if its not listed there try the bsh home appliance web site when you connect it will ask you what language you want the manual in
good luck
Mar 10, 2009 | Bosch Logixx WFT 2806 Front Load...
Bosch logixx 10 washing mashine
just turn filter cap. outer door is just a hinged flap
Aug 05, 2008 | Bosch Logixx WFT 2806 Front Load...
Washing Machines Logo
90 people viewed this question
Top Washing Machines Experts
