Question about GoVideo VR3845 DVD Recorder/VCR
VR3845 A lock symbol appears on front panel and cannot use front panel buttons how do I unlock front panel buttons.
  • clementemesa Dec 29, 2007
    A "safe" script appears on front panel and cannot use front panel buttons. How do I unlock front panel buttons? Have been unable to find any help with this in the user's guide.
On the remote, just above the red "REC" button is a button marked "LOCK". Hit this button and it will unlock the panel. I have hit this button accidently several times.
Posted on Jan 02, 2008
Door not unlocking Fisher Paykel front loader Wh60f60w. The cycle appears to have completed but the door remains locked well beyond normal lock delay. Is there a manual release?
Have switched this on?
Child-proof lock
? You can protect the appliance from being tampered by activating the child-proof lock.
? When activated, no change can be made to the programme running.
To activate the child-proof lock:
1 Press the 1st and 2nd additional function buttons for 3 seconds.
2 The "C ON" (child lock is activated) symbol appears on the screen.
Note: the child lock symbol will also be displayed whenever any button is pressed while the
machine is child-locked.
3 The child-proof lock lamp on the programme follow-up indicator will light up when the childproof lock is activated.
To deactivate the child-proof lock:
2 The "C OFF" (child-proof lock is deactivated) symbol appears on the screen.
3 The child-proof lock lamp on the programme follow-up indicator will go off when the child-proof
lock is deactivated.
Apr 01, 2017 | Fisher Washing Machines
A key symbol is showing. How do we unlock
Hello. Look on the control panel for a button(or set of buttons) that are usually pressed for 4-5 seconds. The button(s) will have a lock symbol or the word "lock" beneath it. You press and hold the button(s) until the lock symbol goes dark. That tells you the lock has been disabled.
Nov 03, 2015 | Ovens
Bottom oven stopped working there is a key symbol showing on the panel what is wrong ?
There are a few reasons for this. One is the most obvious and that is the child lock switch needs to be engaged to unlock.Some models call it panel lock.
Turning the panel lock on and off:
To turn the panel lock on, press and hold the Panel Lock key for four seconds. The Panel Lock symbol will appear in the display.
To turn the panel lock off, press and hold the Panel Lock key for four seconds. The message in the display will disappear.
Oct 04, 2014 | Bosch HBL 5056 Electric Double Oven
Lock displaying symbol
Haven't done this exact model but usually it means keypad locked (child lock) should be in the manual how to unlock. Usually hold down a couple of buttons for 5sec.( most of the time a faint lock symbol will be written between the buttons on the button panel.)
Sep 23, 2013 | General Electric WCVH6800J Front Load...
on most machines, CL is a child lock safety feature. look on the buttons on the front of the machine. you should either see one with a lock symbol next to it, or two buttons joined by a line with a lock symbol in the middle. just press and hold the button(s) for about 5 seconds until the child lock turns off. hope this helps
Aug 30, 2011 | LG WM2301HW Front Load Washer
Hello. On this Dell flat panel the menu access appears to be locked, if the lock symbol you are referring to is from the monitor itself.
You should be able to lock or unlock the OSD by pushing and holding the Menu button for 15 seconds.
Oct 23, 2009 | Dell E152FP 15" Flat Panel LCD Monitor
Fpa lock on how do i get this offf
hello Lock/Unlock Parental Controls
Selecting this option lets you lock and unlock parental controls settings
using a password.
If you do not lock parental controls, none of the settings for V-Chip,
Channel Block, or Front Panel Block will take effect.
If you forget your password, press the MENU button, then select Parental
(the password entry screen appears). Simultaneously press and
hold CH+ and VOL+ on the front panel for 8 seconds. Parental Controls
unlock and the Parental Control menu appears. You can enter a new
password by locking the Parental Controls again.
Front Panel Block
Selecting this option lets you block (disable) or unblock (enable) the TV’s
front panel. The remote still tunes to any channel. When using this as a
Parental Control method, remove access to any remote that is capable of
operating the television while you have the front panel blocked.
Don’t forget to lock parental controls after you change the status. If you
don’t, the front panel block will not take effect .if this don't work get back to me i've got manual good luck
Sep 19, 2009 | RCA R52WH73 Projection Television
Wont start key symol appears
This advise is for Kenmore Elite and Whirlpool Duet front loader washers and dryers with a Control Lock problem.
This may or may not be an indication of a serious problem. In the majority of the cases, this is a simple operator error. Nearly all these model appliances have some sort of Control Lock feature on the front panel now. This is a designed safety feature that is used to prevent small children from manipulating the controls. The controls can be easily locked or unlocked by pressing and holding the following button on the front panel:
Whirlpool Duet Washer - Press and hold the END OF CYCLE SIGNAL button for 3 seconds.
Whirlpool Duet Dryer - Press and hold the END OF CYCLE SIGNAL button for 3 seconds.
Kenmore Elite Washer - Press and hold the DRAIN/SPIN button for 3 seconds.
Kenmore Elite Dryer - Press and hold the AUTO DRY LEVEL button for 3 seconds.
These instructions may not be all inclusive for all Kenmore and Whirlpool models, but they are the most common. Chances are, if you have a Control Lock feature, the instructions will be printed on the front panel adjacent to the button that is required to lock or unlock the controls.
NOTE: These instructions may also work for newer model Maytag, Hotpoint, Admiral and Fridgidaire model front loaders as well. Refer to your owner's manual or front panel for instructions pertaining to your sepcific model.
If the Control Lock feature will not lock or unlock the appliance, unplugging the unit for AT LEAST 30 minutes is recommended in order to reset the main control board. In many cases this is all that is required to correct momentary glitches.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
May 02, 2009 | Washing Machines
Lock/unlock symbol appears in the middle of the screen
5-22-09 Same problem last month. I had the problem a year ago for a month, then it stopped, reappearing this last month. Last week, I finally called support...I was accidentally transferred to a Dell "internal" technical support department...happily a very diligent technician spent a bit of time with me for free...for same problem, even though he confirmed I was over a year past all warranties. He confirmed this was a monitor problem (not virus, malware, etc.). He also confirmed their standard "guidance"/solution for this monitor issue (if under warrantee) is to replace the monitor (i.e. not attempt to fix it). New monitor needed. But problem again gone for last 10 days. So, when fully irritated, buy new monitor.
Apr 03, 2009 | Dell E172FP 17" LCD Flat Panel Monitor
Frigidaire professional series dishwasher has a lock symbol
did you try holding that button for 3 secs, it should unlock it
Mar 04, 2009 | Electrolux Frigidaire Professional Series...
GoVideo VR3845 DVD Recorder/VCR Logo
89 people viewed this question
Top GoVideo Televison & Video Experts
Computer Repairing
Computer Repairing
Are you a GoVideo Televison and Video Expert? Answer questions, earn points and help others
