Question about Dometic RM2652 Refrigerator
My dometic will only work a couple of hours on electric then goe to check mode, is this the board
    President:
  • 704 Answers
Problem. Unit controls go to "check"
There is a common problem with, Dometic RM2807 or RM2811 and most later model Dometics with upper controls. The refrigerator's "check light" comes on or the refrigerator just shuts down seemingly for no reason. Another common problem occurs while on 120v. The refrigerator might switch to gas or just shut down even while you have a good 120v supply.
Answer. Dometic RV refrigerators with the push button upper control boards have a problem with the main power boards. The power board components are encased in yellow epoxy, reducing heat transfer. This tends to cause them to run too hot which in turn can often cause the power board to fail completely or cause problems such as listed above. We have found the only effective repair is to replace the power board. We do not use the Dometic replacement as they too can fail. The Dometic replacement also requires you to rewire the board and gas valve. The only board we recommend is the P-711. The P-711 not only will fix these problems but does not require the rewiring. It uses all the standard wiring. See Power Boards
Hope you found this very helpful, best regards!
Posted on Aug 08, 2009
Dometic Fridge 2652 will not stay lit or relight in gas mode
check house batteries needs 12 volts to control board
Jul 13, 2012 | Dometic RM2652 Refrigerator
I bought at Dometic propane/ electric fridge for my cabin last year. It has not run properly since. The fridge will light and run for a while with a blue flame but sometimes in the idle mode it goes out....
I have to ask, what is idle mode? I've never seen one that runs on idle mode, in a RV in 15 years. Has anyone used a manometer and tested Inches of water column in propane supply to fridge, as well as other appliances?
Any I've seen run on propane, are either on, (flame present, or off, no flame present.) Flame goes out completely when not calling for cool.
Jun 13, 2010 | Dometic RM2620 Refrigerator
Thermofuse continues to trip
if fan in back of unit not working and overheating
Mar 31, 2010 | Dometic RM2852 Refrigerator
Dometic Duo Therm Ac, Fan runs, Compressor cuts in and out?
your compressor is locked up. i would try replacing the round start capacitor. you need to check what the exact rating for yours is but I believe one of these two will work for ya. In the meantime do not continue to try to run it, it will kill the compressor.
seth
53-64 mfd
45-53 mfd
Jul 19, 2009 | Dometic Rooftop RV Air Conditioner
Dometic rm 2612. Shuts down on gas.
Ron;
Check the burner assembly. 1 screw, remove the sheet metal cover and clean it. The burner collects rust. This is the likely. Other issues would be the gas pressure usually checked with a manometer. Should 11" of water column. If your furnace works good then the gas pressure is probably ok. Also could have a faulty ignitor which sends a miliamp signal back to the circuit board. Check the burner first, after that leave the cover off and turn the fridge on. Watch the ingnitor attempt to lite the burner. Be sure the spark is going to the burner and not shorting out on the sheet metal it is mounted in. If it is shorting to the frame the ignitor needs replacing.
Thanks for using Fixya
Jerry
Mar 30, 2009 | Dometic RM2620 Refrigerator
I have a Dometic fridge with cooling issues.
theese wire that goes to the fins are your thermostat probes it possible that your thermostat is defective if you take your thermostat and bypass the two wire connected to it toghether if your fridge works replace the thermostat thanks from gilles
Mar 07, 2009 | Dometic RM2652 Refrigerator
FRIDGE WILL NOT IGNITE IN GAS MODE
The part you are looking for is the thermo couple. It senses the heat from the flame and holds the gas valve open. The clicking will try three times and then go into lock out. You then will need to reset on the front of the fridge. When installing the thermo couple do not over tighten.
Aug 11, 2008 | Dometic RM2652 Refrigerator
Dometic RM2652 Refrigerator Logo
730 people viewed this question
Top Dometic Refrigerators Experts
John Tripp
John Tripp
Charles T Nevin
Charles T Nevin
Colin Stickland
Colin Stickland
Are you a Dometic Refrigerator Expert? Answer questions, earn points and help others
