The L.E.D. located on the tiller
dashboard will indicate with flash codes what problem is occurring.
L.E.D. Flashes 1 time and pauses, 1 time and pauses…. Batteries are low,
scooter will still operate.
L.E.D. Flashes 2 times and pauses, 2 times and pauses…. Batteries are very
low, scooter will not operate.
L.E.D. Flashes 3 times and pauses, 3 times and pauses….Over voltage to
controller.
L.E.D. Flashes 5 times and pauses, 5 times and pauses….Brake is in the
freewheel position or connection to brake is open.
L.E.D. Flashes 6 times and pauses, 6 times and pauses….Paddle or speed
potentiometer problem.
L.E.D. Flashes 7 times and pauses, 7 times and pauses….Paddle or speed
L.E.D. Flashes 8 times and pauses, 8 times and pauses….Motor
disconnected or faulty.
L.E.D. Flashes 9 times and pauses, 9 times and pause….Controller fault.
I hope this helps they are pretty standard codes I got this from Golden Tech Web Site
Check the Lamp if no picture, audio may be present. Screen is completely dark. Lamp LED
flashes 2X every 5 seconds, Power LED flashes GREEN for 140 seconds then
flashes RED. Check the ballast if no picture, audio may be present. Screen is completely dark. Lamp LED
flashes 3X every 5 seconds, Power LED flashes GREEN for 140 seconds then
flashes RED.
Press reset button located to right of led for 2 seconds led will flash
Release button
After 2 secs led will flash once
Enter first digit by pressing reset button relevent number of times
After 2secs led will flash once
Enter next digit by pressing reset button relevent number of times
Repeat operation for remaining digits
if code is entered correctly led will flash
if code is entered wrong led will remain lit but not flash
Note if one of the digits of the code is a zero
after the single flash DO NOT press button but wait for next request and enter the next digit.
hi ,
this can be problem with CMOS ,reset CMOS by jumper or disconnecting CMOS battery .after this still problem with display please disconnect Processor from motherboard get cpu on without processor for 2 min .& after that cut off power assambled it as it is with processor & cheak it out
Display will come
If this information is useful for you please rate me ............
hi , this can be problem with CMOS ,reset CMOS by jumper or disconnecting CMOS battery .after this still problem with display please disconnect Processor from motherboard get cpu on without processor for 2 min .& after that cut off power assambled it as it is with processor & cheak it out Display will come
