Question about HEWLETT-PACKARD LaserJet P1006 Printer
There is a rolled paper at the yellow fuse area, how to remove?
How to open the rear cover of this printer so i can remove the rolled paper inside.
  • 110 Answers
Please click Attention Light Blinks on the Control Panel When Paper Jam Occurs to access the steps that should resolve the issue.
If issue still persists, then contact HP Tech Support for further assistance .
If you are in US , the toll free # is 1-800-474-6836 .
If you are not in US , then log on to www.hp.com , at bottom-left corner there is a world map icon, click on it and then select the region you belong to, which would then provide support options for you for that region.
Posted on Apr 23, 2014
How to remove cover on lexmark F4270
Leading cause of paper jams is debris / foreign objects that accidentally fell into the paper feed area. Please try this approach to fix the problem:
  1. Remove the sheets of paper from the feeder.
  2. Grab a flashlight and look inside the feeder for any debris or foreign objects.
  3. If you're willing and physically able, you may also carefully turn the printer over. Any debris should just freely roll out from the feeder.
  4. If feeder is clear, place the printer on the table. Open the printer cover and remove the cartridges.
  5. Check the cartridge area for any obstructions in the paper path.
  6. Close the printer cover.
  7. Re-brick your printer by pulling out the power supply - the black box where the power cord is plugged into. Re-plug after 30 seconds.
  8. When the printer turns on, reinsert the cartridges and load some paper. Try to print again to verify that the problem is fixed.
Mar 14, 2012 | Lexmark F4270 Plain Paper Inkjet Fax
How do I open to get inside it?
Leading cause of paper misfeeds is debris / foreign objects that accidentally fell into the paper feed area. Please try this approach to fix the problem:
Dec 28, 2011 | Lexmark X6650 4-In-One Wireless InkJet...
Paper jam and I don't know how to fix it, I have a 2600
Leading cause of paper jams is debris/foreign objects that accidentally fell into the paper feed area. Please follow steps below to fix the problem:
3. If you're willing and physically able, you may also turn the printer over. Any debris should just freely roll out from the feeder.
4. If feeder is clear, place the printer back on the table, open the printer cover and remove the cartridges.
5. Check the cartridge area for any obstructions/debris in the cartridge carrier's path or the paper path.
6. If cartridge area is clear, close the cover.
7. Unplug and re-plug the printer into the power outlet to reset it.
8. When the printer turns on, reinsert the cartridges and load some paper. Try to print again.
Aug 17, 2011 | Lexmark X2650 All-In-One InkJet Printer
Paper jammed inside printer unable 2 see it and pull it out? its a all in one x2500 lexmark printer?
7. Rebrick (pull out power supply, black box where the power cord is plugged in at the back of the printer, and put it back after 30 seconds).
If problem continues, please contact Lexmark Technical Support Center for additional assistance.
Aug 08, 2011 | Lexmark X2500 All-In-One Printer
Won't feed paper
There could be something blocking the paper path.
2. Grab a flashlight and look inside for any debris.
5. Check the cartridge area for any obstructions/debris that could cause this error or problem.
May 12, 2011 | Lexmark X6570 InkJet Printer
PAPER starts to go into printer then goes crocked and stops
May 11, 2011 | Lexmark C533DN InkJet Printer
My Lexmark Z2300 printer pulls paper in only on 1 side when trying to print. What is causing this?
It could be due to some debris/foreign objects that have accidentally falleninto the paper feed area. 1.Remove the sheets of paper from the feeder. 2.Grab a flashlight and look inside for any debris. 3.If you're willing and physically able, you may also turn the printer over. Anydebris should just freely roll out from the feeder. 4.If feeder is clear, open the printer cover and remove the cartridges. 5.Check the cartridge area for any obstructions/debris that could cause thiserror or problem. 6.If cartridge area is clear, close the cover. 7.Unplug and re-plug the printer into the power outlet to reset it. 8.When the printer turns on, reinsert the cartridges and load some paper. Try toprint again.
If problem continues, then it could be some hardware problem in the feeder mechanism.
May 02, 2011 | Lexmark Z2300 InkJet Printer
Paper get stuck every time I try to print. I notice the paper just slides a bit inside and then on right side it just gets collected and I have to turn printer off to clear paper jam. please help. thanks.
Leading cause of paper jams is debris/foreign objects that have accidentally fallen into the paper feed area.
4. If feeder is clear, open the printer cover and remove the cartridges.
Apr 28, 2011 | Lexmark X6170 All-In-One InkJet Printer
I don't see a paper jam, but that is the error i keep getting. it will let me print or copy anything. the printer i have is a lexmark x5470
Apr 26, 2011 | Lexmark X5470 All-In-One InkJet Printer
HEWLETT-PACKARD LaserJet P1006 Printer Logo
21 people viewed this question
Top HEWLETT-PACKARD Office Equipment & Supplies Experts
Victorman
Victorman
Are you a HEWLETT-PACKARD Office Equipment and Supply Expert? Answer questions, earn points and help others
