Question about Calphalon HE650CO XL 1400 Watts Toaster Oven with Convection Cooking
Need a new timer knob for my caphalon HE650CO toaster oven
I need a knob insert for the timer knob.
Need timer knob for calphalon he56c0
WARRANTY AND PRODUCT SUPPORT
Call 800-809-PANS (7267)
Oct 14, 2014 | Calphalon HE650CO XL 1400 Watts Toaster...
Replace door handle
Not enough info to help you. However, if the door can be separated into two pieces fitted together, you will see the screws holding the handle.
Otherwise, you have not asked a question.
Oct 20, 2013 | Calphalon HE650CO XL 1400 Watts Toaster...
The toaster button will not work-now what??
I found that if you pry off the plastic chrome ring around the button, you can manipulate the button to make it work. Mine works if I first push the button up before pressing. Inelegant, but it works!
Mar 05, 2011 | Calphalon HE650CO XL 1400 Watts Toaster...
Oster 6232 toaster oven.
trying to find a solution for a broken knob, i discovered that there aren't many decent options. so i took it upon myself to find one. my father actually recommended that i post the solution, seeing that there were so many with broken knobs. now this works on the timer knob on an oster 6232 toaster oven. it may work on the other knobs and possibly other models, but i cannot confirm that. the plastic stem of the knob that slips over the medal stem of the timer had broken. i crazy glued it back together and knew that there was no way in hell it would hold up with just glue. sorry for the lack of pics on this part. with the broken piece glued back in place, i went to home depot to find something/ anything that would securely slip over the stem of the knob. i tried all sorts of tubing. copper, pvc, steel and found nothing. in the plumbing isle with all the brass fittings and compression fittings, i found an "ander-lign compression nut" 5/8" OD w/ insert. part # A-304 961-P. 634052c.jpg
all you need is the brass flanged insert. if you can find it without the nut and compression ring, then more power to you. after buying this, slip the piece over the knob stem flanged end first. i used 5 minute opoxy to ensure it would stay in place. 7c9f2a3.jpg
i then used a cone shaped diamond bit in my dremel tool to notch out the two sides of the knob. 6be2e7e.jpg
just cut the brass down enough to match the notches in the stem of the knob. 0cdfdf7.jpg
and there you have it. sorry for the 2 blurry pics. hope this can help some of you.
Sep 15, 2009 | Oster 6232 / 6233 1500 Watts Toaster Oven...
My timer knob is broken. How can I order only that part?
I would advise you to call Kitchenaid Customer Service. They would be able to send you a replacement timer knob at no cost. You may simply pull off the broken timer knob, and the new knob will snap in with ease.
Their toll free telephone number is 1800-541-6390.
Jun 16, 2009 | KitchenAid KCO1005OB 1400 Watts Toaster...
Broken timer knob
I had the same problem where the time knob broke. I filled in a claim form on the Oster Website and they answered within 3 days saying the timer knob was discontinued and no longer available. They proposed to replace the whole toaster-oven with another model 6073-33 which I received last week. I've to say that their customer service was amazing.
May 04, 2009 | Oster 6232 / 6233 1500 Watts Toaster Oven...
Kenmore toaster oven timer knob broken
I have the same toaster oven and my timer knob just broke 2 days ago. Go to SearsPartDirect.com website. They have a substitute timer knob.
Mar 18, 2009 | Kenmore KTES8 Toaster Oven with Convection...
OSTER TOASTER OVEN --- TIMER TWIST KNOB BROKE
you can get on amazon for sure. take a look here Thanksgiving essentials from the Oster brand. p.s. take a look on seller reviews. I hope this was helpful. cheers
Jan 19, 2009 | Oster 6232 / 6233 1500 Watts Toaster Oven...
Timer Switch
Same problem with Black & Decker CTO6160 toaster oven. Same switch. Must be they're all Chinese garbage.
Dec 28, 2008 | Euro-Pro TO160L 1380 Watts Toaster Oven...
Need a knob for the oven broiler on a welbilt
I needed a new timer knob as weel. I contacted KitchenAid's customer satisfaction Center at 1-800-541-6390, and they sent a new one to me at no charge.
Jul 13, 2008 | Toaster Ovens
Calphalon HE650CO XL 1400 Watts Toaster Oven with Convection Cooking Logo
80 people viewed this question
Top Calphalon Toaster Ovens Experts
Angel Joseph Jr.
Angel Joseph Jr.
Dave
Dave
Are you a Calphalon Toaster Oven Expert? Answer questions, earn points and help others
