Hotpoint HV7L130 How do I remove control panel facia. Selection knob just rotates and unable to change programme
gittos73
  • 244 Answers
SOURCE: how do i remove a rear control knob on a hotpoint wma50s machine
to replace your timer dial take the lid of by unscrewing 2 screws at the back of the lid were your dial is look down a small oval shape opening u will see a screw undo it and the dial will come off m8
Posted on Aug 15, 2007
  • 90 Answers
SOURCE: How to remove top panel and front facia on a Hotpoint Aquarius WDF451 washing machine
Un plug it. There should be small screws either at the bottom of the panel on the front or there is separate panel that comes off the top back. If the back is one solid piece top to bottom, then the control panel lifts out and hinges up when the two small cross tip screws are removed from the bottom outside corners of the control panel..
Posted on Feb 10, 2008
  • 108 Answers
SOURCE: Hotpoint Wf 541 how to remove top and front facia
To remove the Top you need to pop small torx covers on each side at the top (near to front). Then unscrew the torx each side. the top will then slide back about 5mm.
Once the top is opened you will have a major task of removing all cables from control unity behind facia and the holding screws. Depending on the damage to the button/plastic you may be able to pop the button into place. It is also possible you may need to order a new control unit from hotpoint. I believe you can order online for minimum hassle.
Posted on Feb 21, 2008
jsrock516
  • 5911 Answers
SOURCE: How to remove the washer cycle selection/start-stop knob on a Whilpool Heavy Duty Thin Twin stacked washer dryer
I believe the selector knob on a Whirpool just has to be turned counter-clockwise with the selector pushed in. It will spin off the shaft and then the outer indicator dial will pull off. The shaft also has a keyed slot that will only allow the dial to be removed and installed one way, so there should be no question as to how it goes back on.
Was there a reason as to why you are removing the washer selector knob? If this is a simple matter of replacing a broken water temperature selector, you shouldn't have to remove any of the control knobs to gain access to the selector. The entire front panel comes off by removing the screws holding it in place. That way you can access the broken selector from behind the front panel much easier. Just remove the panel right above the washer top (under the dryer) and it should expose the front panel mounting screws. Remove these screws and the front panel comes off. Just make sure the unit is unplugged before you begin. I hope this helps you. Let me know if you need further assistance.
Posted on Apr 22, 2008
keemo68
  • 1263 Answers
SOURCE: Control Panel Installation
in some instances there is either a set screw(generally a small allen head) or a small pin that has to be forced out. these keep the knob from spinning on the shaft and stripping it.
Posted on Aug 29, 2008
How to remove the control unit on a hotpoint wm62 washing machine please
The main control unit on the WM62 is at the top behind the user facia control panel. If you remove the lid you should get relative easy access to it. If memory serves, there are 2 wee plastic plug to remove on the SIDES of the top lid, ease them out with a flat screw driver, then you need a torx T20 screwdriver to remove the screws behind the plug. The lid should now be removed with a gentle knock forward from the rear of the lid. Remove the soap drawer and you will see a few more screws, remove these and the 2 screws on the top of the Facia, the control unit is now easily removed.
Oct 24, 2014 | Hotpoint Washing Machines
How do I replace the light bulb behind the heater selection knob
The panel in front (facia panel) should snap off. If not there are only a couple of screws holding it on. From there it is just a few screws away from replacement.
Oct 04, 2014 | 2008 Honda Civic LX
I got 2005 Holden commodore v6 . How can I change the air con fan control knob pls.
looks more like an opel insignia dash to me but whatever you will need to remove the front centre console facia panel and i think they just clip in .
Nov 19, 2012 | Cars & Trucks
Error code F2EO
Hello Marie,
The F2EO error code means that button on the keypad has shorted out and the keypad(touchpad) needs to be replaced.
GENE
Nov 06, 2011 | KitchenAid KGSA906PSS Gas Kitchen Range
I have just purchased a Hotpoint washing machine WMD 962 Ultimate. On switching on for the first time there was a language selection programme and in error I entered Italian I am now unable to change the...
OK the manual has it a little wrong.
What you have to do is switch the power off (not at the wall but on the machine itself)
then press the three buttons for around 5 seconds till you hear a beeb
next time you switch it on it will be back to the language selection
just follow the manual to select.
Aug 02, 2010 | Hotpoint Washing Machines
How do i fit a drive belt on a hotpoint tumble drier
Hi, To fit the belt to your dryer you will need to remove the top of the appliance by removing the screws at the rear. Pull of the timer/control knob. Look inside the top of the t/dryer behind the control panel you will see little plastic stems which are attached to the facia panel. You need to knock these out to remove the facia. Once this is off then you can remove the the top 3 screws and the bottom 3 screws the front panel will now come off for you to place the belt on the drum and over the motor spindle. Becareful as the t/dryer will be very loose and will twist. it is easier to lay the appilance down on its back to stop everything falling about. Now you can put it back together in the reverse order....
Good luck.............
Jan 26, 2009 | Hotpoint Aquarius WMA42 Front Load Washer
Fan Switch needs replacement
You can try to have access removing center facia panel
(then disconnect air temperature switch connector).
Aug 09, 2008 | 2000 Hyundai Sonata
Apr 22, 2008 | Whirlpool LTE6234D Top Load Stacked...
SOAP DISPENSER HOSE
take both star screws from under lugs on either side of the lid remove that then take soap drawer out if screws are not visable remove front facia panel the same screws which hold the facia will also hold the soap drawer in place as you lift the drawer you will be able to undo the hose to the drum.
Mar 08, 2008 | Hotpoint WMA64 Front Load Washer
Feb 10, 2008 | Hotpoint Aquarius WD63 Front Load...
Washing Machines Logo
41 people viewed this question
Top Washing Machines Experts
