Question about GE Washing Machines
GE WJRE5550H1WW agitates slowly
My wash machine agitates back and forth and takes a whole second to swish one way and a whole second to swish the other way. The last 5 to 8 seconds of the wash cycle it agitates at what I think is a normal speed. This is a consistent behavior. In my mind if the coupler was bad I don't think it would consistently agitate normally the last 8 seconds. From reading other posts I'm leaning toward maybe the shifter or timer.? Not sure.
SOURCE: Inglis Washing Machine agitator not working right
replaced timer problem solved thanks
Posted on Mar 30, 2008
  • 116 Answers
SOURCE: Squeaking/grinding/rattle noise during wash and spin
That sounds like a clutch problem - probably just worn and need replacement. Will definitely need to pull to find exact fault.
Posted on Nov 16, 2008
  • 258 Answers
SOURCE: agitator doesn't spin during wash cycle
If The washer won't agitate
Check to make sure no clothing got wrapped around the agitator. Check the lid switch, timer, and drive belt, other potential causes, such as a bad transmission or bad agitate/spin solenoid, but they are much more involved.
if the washer won't spin, the lid switch, timer, drive belt, transmission, or agitate/spin solenoid could be the cause here as well. Sometimes if the load is unbalanced or too heavy, the washer won't spin. Take some of the clothes out and try the spin cycle again with a lighter load.
Here are the steps to replace the agitator.
1: Take the fabric softener dispenser off and pry off the agitator lid.
2: Use a socket wrench with an extension bar to remove the stud and seal.
3: Remove the agitator top and bottom.
4: Check the agitator clutch assembly (located in the agitator top) for excessive wear.
5: To replace, just reverse the directions.
Posted on Jun 29, 2009
  • 35 Answers
SOURCE: Knocking noise during agitation cycle - GE WNSR2100T8WW
I believe you must have one of the bottom of the line cheapo washers, as I do--the one with the plastic, rather than steel wash tub and basket? These are pretty poor machines. They cut corners drastically in every part of the design. I've replaced the aluminum hub that supports the spin basket ( the hub is bare aluminum and corrodes within about 5 years use from the highly alkaline detergent, then it fractures under mechanical stress. Then the motor burned out. I was able to get a nearly new motor on ebay for $90 incl. shipping. (BTW, if you need appliance parts try GOOD Appliance on ebay for new and salvaged parts--they're excellent! 100% feedback rating) However, I now have the same problem--a fairly loud knocking noise during the agitation phases of the cycle. This is cause by a really crappy transmission design that does not wear well. My advice is just ignore it as long as it works and isn't leaking oil and the tub seal is still good. If it does finally go to pieces get one on ebay--that is if you feel up to doing the job yourself since a repair person would charge more than it's worth to install it. I believe new ones can be had on ebay for about $80, some are sold with seal kits. Bottom line is--if you want a machine that will last you for 15-20 years--don't buy a cheapo model. The front loaders are better as they use far less hot water (energy and water savings) but a good one is going to be anywhere from about $800 to $1600.
Posted on Sep 17, 2009
  • 3085 Answers
SOURCE: my maytag mod #mvwc6esww1 [bought refurbished
Yes, this is a normal function, the washer is actually figuring out the best way to wash the clothes.
Posted on Nov 25, 2009
I am not sure my machine is agitating correctly. This is my first load and all it does is swish back and forth. Is this normal agitation.
Nicki-you must have a front load machine or an older model that you can lift the lid on. Or this may be a new machine to you-unfamilar with-a make and model number would be helpful-the last new washer we got said on the lid-your new machine will not make the same noises as your old agitator-cheers Denny
Oct 16, 2013 | Washing Machines
I have a model WJRE5550H1WW washer that will fill agitate but will not pump out and spin
first check the lid switch, a lot of washers will agitate with the lid open but wont spin out. If its not that check your timer and then your water pump. Most likey it is the lid switch.
Feb 27, 2012 | GE WBSR3140DW Top Load Washer
Need to know how to get agitator off a ge washing machine
onthejob5130_7.jpgonthejob5130_1.gifthis should be a big help..remove agitator first ,if frozen hit top of agitator back and forth to losen it ,,,remove agitator coupling and you should have it,,,good luck
Sep 12, 2011 | GE WDSR2080D Top Load Washer
My ge wjre5550h1ww wont spin. everything else work up to that point
Might need to be reset. To Reset the Inverter board on the motor push the timer knob in so the washer is idle or if digital have the machine in the off position. Unplug the machine for one minute. Plug back in and raise and lower the lid six times within 12 seconds. This might take more than one time. Service Manual and MORE HERE
Aug 23, 2011 | GE WBSR3140DW Top Load Washer
My GE wjre5550h1ww waher makes a continuos loud clank/bang noise when time the washer is in the soak/agitator cycle. Rinse and spine cycle, normal noise/sound. Please help! Thanks
The part (it has three prongs) that the transmission (yes your washing machine has a transmission) uses to cause the reciprocating motion of agitation has broken off 1 or 2 of the 3 prongs, and, if you
continue to use the washer (you might as well, the part is broken already - you may as well run it until it dies), the part will break completely, and you'll lose the soak/agitator cycle altogether.
FIX: replace the broken 3-prong plate, and give it a nice coating of automotive bearing grease to help it last for awhile (until the next thing breaks).
Dec 11, 2010 | GE WBSR3140DW Top Load Washer
Ge top loading washer wjsr4160gww. How can I open top cover and see the agitation? Suspect it is not agitatiing properly.
If you suspect this machine is not agitating try grabbing the fins at the bottom of the agitator and see if you can move it back and forth if it moves then you have a stripped coupler or a bad transmission.
Feb 27, 2010 | GE Washing Machines
Thumping hitting front stops on wash cycle.
if it was not NEW and under warranty, you bet i would ask for your paid service in heartbeat.
the repairman is arriving finally tonight.i will update what he finds.
Apr 05, 2009 | GE Washing Machines
GE topload washer Agitator
theres no nut and bolt,,only a cam or bell have to roch agitator back and forth,,until it losens,,and pull up reall hard..or put your belt under agitator and yank up..onthejob
Jan 23, 2009 | GE WBSR3140DW Top Load Washer
Squeaking Top Load GE Washer
I bought a new GE Washer GTWN5050MWS yesterday. From the first load it squeaked each time the tub moved back and forth (no agitator in the infusion type) It is a quick squeak and kind of resembles a cat getting it's tail under a moving rocking chair. I checked the entire owners manual and it describes several noises and not one of them describes what my new washer is doing. It does not make this sound except for when it is in the wash cycle. Spinning is quiet, and during the agitation of the rinse cycle it is a much more subdued squeak. But during the wash cycle it is not acceptable.
I called GE this morning and they told me it was normal operation for all infuser types of their washer to make this noise. Tomorrow I will be taking it back for a full refund.
We purchased this machine because our 2-year old front loading GE washer broke down (discharge pump I think) and to get it fixed usually takes a couple of weeks. We thought it might be better to have a 2nd washing machine instead of paying the laundry mat. It took a month to get the last one declared unfixable in 2008. Maybe I was wrong. But this is very bad luck to have a brand new washing machine squeak so loud out of the box.
Mar 15, 2008 | GE Profile WPRE6100G Top Load Washer
Just spins during the wash cycle
Sounds like the agitator got dislogged during moving. In some machines the design allows for the agitator to move up and down alittle too much. Try this and this is only a guess. With the machine empty push down firmly on the agitator and move it back and forth as you do. You might hear a little "pop". If it does, try running the machine again. If it works problem solved, if not tell what happened.
Jul 17, 2007 | Whirlpool GSC9455 Top Load Washer
Washing Machines Logo
Top GE Washing Machines Experts
Dan Webster
Dan Webster
Tim Whalen
Are you a GE Washing Machine Expert? Answer questions, earn points and help others
