Question about LG 22" FLATRON LCD Monitor
Osd appearing without pressing any buttons
Osd menu appears by itself, and if it is not locked, settings change
  • LG Master
  • 3,320 Answers
What's going on is either a misconfiguration on your video card, your monitor settings or a cabling/connector issue. A signal is being sent to the monitor it doesn't understand. You're going to have to play with settings and if you're using an adapter in your connectors, that could be the problem too.
Posted on Mar 29, 2014
Testimonial: "Many thanks. If you may elaborate, with which settings am I to play with? The problem appears rarely, but consistently, for instance, once a month for a whole day the monitor is nigh unusable."
  •  Mike M
    Mike M Mar 30, 2014
    OK That's a different scenario. Think about what programs you might be using when the error occurs. You might also look for a new video card driver. I was talking about a similar issue with a friend and it came down to Windows is a dynamic OS and linux/Mac Os's are static. When Windows calls a program it loads dll files and when it closes the program it over writes the dll files. There is an opportunity for glitches to be written to the dll file. Linux loads the lib files but when done doesn't write the lib files back to the lib directory.
  • 30 Answers
SOURCE: OSD Locked
You can try this lcd monitor factory service mode login method here http://www.fastrepairguide.com/monitor-and-lcd-monitor-problem-solutions/login-factory-service-mode-lg-lcd-mo.html http://www.fastrepairguide.com/monitor-and-lcd-monitor-problem-solutions/how-to-login-to-lcd-monitor-factory-service.html Try and see!
Posted on Sep 18, 2007
DCSE
  • 191 Answers
SOURCE: Problem in TFT
The OSD can be enabled or disabled by pressing and holding the Menu button on the front panel for 10 seconds. If the OSD is locked, the warning message OSD Lock displays for ten seconds.
  • If the OSD is locked, press and hold the Menu button for 10 seconds to unlock the OSD.
  • If the OSD is unlocked, press and hold the Menu button for 10 seconds to lock the OSD.
Posted on Jun 09, 2008
SOURCE: FLATRON L192WS LG
hold de book buton 5 or 6 sek
Posted on Aug 26, 2008
  • 62 Answers
SOURCE: OSD Locked
1. replaced the control panel micro switchs.
2. press the menu switch 15 secunds.
Posted on Dec 01, 2008
  • 42 Answers
SOURCE: w2361vg
Posted on Sep 03, 2009
How do I unlock the OSD lockout on a Samsung B2430H monitor. I've unplugged the power and computer connection cable. Tried holding the menu and auto keys nothing seems to work. There is just the...
OSD LOCKED/UNLOCKED
This function allows you to lock the current control settings, so that they cannot be inadvertently changed. Press and hold the MENU button for several seconds. The message "OSD LOCKED" should appear. You can unlock the OSD controls at any time by pushing the MENU button for several seconds. The message "OSD UNLOCKED" should appear.
Sep 09, 2013 | Samsung SyncMaster 753S 17" CRT Monitor
There is a blue lock that appears in the center of the screen
Change the OSD Lock option from ON to OFF by following these steps:
Press the Menu button on the remote or the control panel for 15 seconds to unlock the OSD menu.
When the OSD menu appears, select the Management option at the Main Menu, then select OFF at the OSD Lock option.
Select Exit to save the setting and exit the menu.
hope this helps
Aug 07, 2012 | Dell OptiPlex SX280 PC Desktop
How to unlock osd lock lg flatron w1643c
OSD LOCKED/UNLOCKED
This function allows you to lock the current control settings, so that they cannot be inadvertently changed. Press and hold the MENU button for several seconds. The message "OSD LOCKED" should appear. You can unlock the OSD controls at any time by pushing the MENU button for several seconds. The message "OSD UNLOCKED" should appear. system admin
May 30, 2012 | LG Computers & Internet
"OSD Locked" message appears when
The OSD can be enabled or disabled by pressing and holding the Menu button on the front panel for 10 seconds. If the OSD is locked, the warning message OSD Lock displays for ten seconds. If the OSD is locked, press and hold the Menu button for 10 seconds to unlock the OSD.
Jan 22, 2011 | Computers & Internet
"OSD LOCKED" box on my screen
* If the OSD is locked, press and hold the Menu button for 10 seconds to unlock the OSD.
* If the OSD is unlocked, press and hold the Menu button for 10 seconds to lock the OSD.
OSD stands for "On Screen Display." It is an onscreen configuration menu included with various monitors. When you press the MENU button or one of the other buttons on the front or side of a monitor, the onscreen display may appear. The OSD typically includes monitor calibration options, such as brightness, contrast, and color adjustments. Some OSDs may also include horizontal and vertical position controls as well as tilt and keystone adjustments.
If you can't make adjustments to the monitor settings using the OSD interface, the onscreen display may be locked. You may also see the phrase "OSD Locked" appear when you try to change the settings. Some monitors include an option within the menu called "OSD Lock", which you can turn on or off. If this option is available, simply turn OSD Lock off and you will be able to make adjustments to the settings.
If your monitor does not include the "OSD Lock" option, you may be able to unlock the OSD by pressing and holding the MENU button on the front or side of the monitor for several seconds. If you try this method, be patient! It may take up to 15 seconds for the OSD to unlock.
VOTE ME
Dec 07, 2010 | Dell Computers & Internet
OSD locked. Can't get mouse to work on monitor
-Press and hold the MENU button (on the monitor) for several seconds.
-The message "OSD LOCKED" should appear. You can unlock the OSD controls at any time by pushing the MENU button for several seconds. The message "OSD UNLOCKED" should appear
Nov 24, 2010 | LG Computers & Internet
How to get rid of osd lock which appears frequently on screen?
Hold the MENU button for ten seconds to unlock or lock the OSD.
This information is from your manual for the L194WT:
OSD LOCKED/UNLOCKED
Please rate me if this solution works for you
Thanks......Have a great time
Jul 08, 2010 | ViewSonic Computers & Internet
The OSD Menu on the monitor itself is locked. How do I unlock it so I can adjust my settings? It was given to me, I have no printed material for it. Thanks
Turn off monitor, hold down the menu button, turn the monitor back on, release the menu button after 10-20 seconds. Your Iiyama screen will now be unlocked.
Mar 07, 2010 | HP M700 Monitor
Osd locked
On some display devices, there is an OSD Lock that locks all current control settings and prevents access to the control menus until this mode is unlocked.
The method for unlocking the OSD is different for different monitors, but will be one of the 2 below. If the first method doesn't work, try the second.
Method 1: Press and hold both the [1] button on the front of the monitor and the down arrow button for 10 seconds.
Method 2: Press and hold both the [1] button on the front of the monitor and the up arrow button for 10 seconds.
Note: These same buttons, when pressed for another 10 seconds, will lock the OSD.
Nov 21, 2008 | ViewSonic E70f 17" CRT Monitor
ViewSonic E70f 17" CRT pincushion changed itsself continously
Press the [1] key & hold it for 10 seconds / till OSD Unlock appears on the screen. When OSD unlock appears on the screen , release [1 ] & press [1] or [2] key. This will unlock the OSD.
May 22, 2008 | ViewSonic E70f 17" CRT Monitor
LG 22" FLATRON LCD Monitor Logo
49 people viewed this question
Top LG Computers & Internet Experts
Michael Vincent Cruz
Are you a LG Computer and Internet Expert? Answer questions, earn points and help others
