Question about Refrigerators
Samsung american fridge freezer RSH5UBBP
The display is showing 23 e and compressor fan at the back not working what does this all mean please
SOURCE: Samsung RCS21DCNS Side by Side
probly the evaporator coil in fridge all frozen up you need to pull all the back out inside the fridge section and defrost with air drier
Posted on Sep 21, 2007
dididsaythat
  • 291 Answers
SOURCE: SAMSUNG AMERICAN STYLE FRIDGE FREEZER MODEL RS21DCNS
Sounds like u need to replace fan motor
Check fan motor for continity IF none replace fan motor
Posted on Oct 12, 2007
farfield
  • 462 Answers
SOURCE: fridge condensation - freezer thawing
OK now I'm wondering are theses numbers your getting 4 -9 the actual temps of the refrigerator and the freezer? and do they feel this cold and correct to you? I know the refrigerator side shouldn't be below 34 or so and definitely not below 32. If this is correct and the numbers are not settings but temps. (Now if you have a touch pad its electronic. If it has knobs it has a separate defrost and thermostat and are electro-mechanical)
If electronic Your control board and possibly defrost control are out.
It would more likely be the sensors going to the board(s) It will both sensors have the possibility of causing your problem. 1 will control the run of the compressor (and this one could and probably is connected to the inside coil) and 1 will control the air damper tween the refdg and freezer compartments, and may turn on the inside fan operation too.
(this would be my first suspect if these are degrees numbers). Look at the thermostat control see if it is attached to the indoor coil (usually the tube leavign the indoor section. If its not attached its not sensing the coil temp and when goes into defrost wala its not senmsing temps like its designed to do. Look for a broken clip or possible a plastic wire tie that holds this sensor in place.
Please get back to me with what you see - find on this look up.
Posted on Mar 18, 2009
SOURCE: Samsung american style fridge/freezer needs repairing
Spray a good quantity of WD-40 on the spindle of the fan motor where it enters the motor itself. This should get the fan working smoothly with no noise. This will probably solve the other problems, as the fan prevents various components from overheating and shutting down.
Posted on Sep 20, 2009
  • 3 Answers
SOURCE: samsung side by side fridge freezer sr-s2028css
Have you tried Appliance DIY Repairs? They sell a repair kit for that model.
Posted on Feb 25, 2011
Not colling
Check the back to see if the compressor is running or just really hot. If it is not running it could be a thermostat issue, but if it is hot and not running, that means your compressor has problems and will need to be replaced.
Apr 07, 2014 | Whirlpool 22" Dual Zone 38 Bottle Wine...
I've got a lg air conditioner nano plasma model LSZ182VM4, this one is not working, according to a manual the cause of malfunction is DC peak error and on the display show a "C6" code. what does...
C6 means high discharge temp due to over current of compressor. May be one or more reasons as follows:
Reasons & solutions.
1. Condenser coil blocked. Clean it., 2. Fan runs slowly due to weak capacitor.Replace capacitor. 3. Outlet pipe sensor open or short circuit. Replace it.
Dec 28, 2010 | LG Heating & Cooling
Fan works but compressor does not start. Its a brand new unit
Hi!!
By fan woks you mean inside unit right? assuming so, check remote control settings and battery, set temp.to 70 degrees, a light should come on at the display and seconds later, the compressor should kick in. If Unit is brand new, it should be it. If split units, try another remote, some times those remotes show the display but do not send signal strong enough that the unit can receive it. Try getting closer to the unit.
Keep me posted! Rate this post!!
Aug 14, 2010 | Mitsubishi Mr. Slim MXZ30TN Air...
The center between the sides is very hot to the touch
The fan which cools the compressor in the back of refrig is not working . Either something blocking the fan blade or the motor is bad . Also clean the coils of dust , lint , etc...
Aug 16, 2009 | Jcb Jenn-Air® 23 cu. ft. Counter...
Fridge/freezer warm, water puddling underneath
Hi, clicking sound from compressor, means compressor not running (working) compressor overlay relay is what making that clicking sound, possible your compressor have a hard start, you can purchase compressor ( hard start kit ) from appliance store, your fans could be working, but compressor short cycling, you said fan not working? which one inside of ref, or one near to compressor, check fan, remove 2 wires from fan terminal, use ohm tester, place tester lead one on each fan terminal, if you get a beep sound (continuity) fan is o/k, if not, fan burnt out, replace fan, now if compressor is good, fans are good, then check or replace, defrost timer, but before doing any repairs, unplug ref, excessive water is because ref defrosting, because there's no refrigeration, remove your produce, leave ref. off for about an hour, then replug it, let it work for about another hour, then check to see if temp. dropping (colder) maybe you experiencing, low voltage, let me know what happened, then i can tell you exactly, what's the problem. good luck.
Aug 11, 2009 | GE GDS18LBR Bottom Freezer Refrigerator
TEMP DISPLAY AND FAN NOT WORKING
i have the same problem--i havent replaced the fan--but was considering the control board--have you replaced or cheked this yet?
Aug 01, 2009 | GE Profile 22.2 Cu. Ft. Side-by-Side...
Refrigerators Logo
44 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
