Question about Keurig Coffee Makers & Espresso Machines
It wont brew
Just one blue light comes on then it won't brew
Carefully clean the sharp pin that pouches the hole in the top of the k-cups by inserting a toothpick or paperclip into the hole where the water is pushed into the k-cup.You need to descale it by cycling some vinegar and water through it. Pour a couple cups of vinegar and a cup of water in the reservoir push the large cup size, you can reuse the vinegar mix just don't pour any grounds back into the resevoir.Do this several times (you should see noticeable improvement)then run some clean tap water through so your coffee doesn't taste like vinegar. Hope this helps!Justin
Posted on Apr 15, 2014
Keurig b31 mini. Power light on, brew light not on
Water reservoir may not be seated properly or filled above the Max line. Did you do a purge and establish filling the hot water reservoir?
Feb 08, 2013 | Keurig B30 Mini Coffee Maker
Beeping sound, won't brew
Our Hassle-Free Replacement Warranty guarantees that if your PRO LINE™ countertop appliance fails in
the first two years, KitchenAid will replace it free of charge. We will:
  • Deliver a replacement to your door
  • Arrange the return of the failed appliance
  • Guarantee the new appliance for two years
    For more information or complete warranty details on KitchenAid® PRO LINE™ countertop
    appliances, please call Customer Service at 1-800-541-6390 or click here.
    spacer.gif spacer.gif spacer.gif spacer.gif spacer.gif spacer.gif spacer.gif spacer.gif spacer.gif Product Literature spacer.gif Additional Resources
    Feb 15, 2008 | KitchenAid Pro Line Coffeemaker Coffee...
    Keurig Mini B 30 won't work.
    Time for a new unit....it is past its prime now.
    Jan 05, 2013 | Keurig B30 Mini Coffee Maker
    Descaling won't brew
    Desacle now or it won't reset to factory settings.
    Mar 11, 2012 | Keurig Platinum B70 Coffee Maker
    I have had my Kuerig coffee maker for over a year now which I believe means it's no longer under warranty. However, I paid quite a lot for it so I'd really like to see if I can have it repaired...
    unfortunatly keurig treats any home model as throwaway once warrenty is up. They even do the same with mostcommercial models. By the sounds of your problems its time for a new one. sorry. try for a b145 or b150 they are a little more robust.
    Sep 05, 2011 | Keurig Platinum B70 Coffee Maker
    Blue light keeps blinking and its full of water-- just got it today and it won't brew
    There is air in the lines and it is blocking the water flow...
    Here is a tip that will help you getyour Keurig to prime...
    Keurig CoffeeBrewer will not prime
    heatman101-=-
    [p
    Aug 10, 2011 | Keurig B30 Mini Coffee Maker
    I have a keurig b30 and has been working great but now it will not recognize any of my cups so the flashing blue light will not come on to start brewing? none of them are clear and have all worked in the...
    I haven't solved the problem, but I continue to disassemble my K30. Most likely points of failure for the blue start light not coming on appear to be a sensor to detect the cup is in place (two small holes on the left/right front edge of the cup holder) or a sensor in the resovoir lid where the blue pin presses on a pressure switch. I did find that the red wire to this switch gets caught in the lid hinge and may be damaged. I will post more if I finally discover the root cause but may just go to Bed Bath & Beyond and buy the resovoir model with a 2 year warranty. Lesson learned. Cheap switches and mechanical devices.
    Nov 06, 2010 | Keurig B30 Mini Coffee Maker
    From slow to no drip brewing....no descale issues....clogged?
    clean the needles and if that dont work call keurig and get a replacement
    Sep 20, 2009 | Keurig B60 Coffee Maker
    Coffee Makers & Espresso Machines Logo
    103 people viewed this question
    Top Keurig Coffee Makers & Espresso Machines Experts
    Lisa
    Lisa
    Jason
    Are you a Keurig Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
