Question about Dishwashers
Code i20 comes up on my Westinghouse dishwasher SB915 ?
Half way through the cycle i20 code will show up and stop working
  • 5 Answers
SOURCE: Westinghouse sb915 will not heat
Westinghouse SB907 had same problem, which I had thought might be the heating element. Fixed relay soldering on PCB where it was burnt/melted, now works! This probably applies to the Westinghouse SB925 also.
Posted on Aug 25, 2008
charliech822
SOURCE: stops working half way through a cycle and alarm goes off
how many beeps does it make
Posted on Oct 04, 2009
SOURCE: IDL705 dishwasher showing error code
Indesit IDL700 first two green lights flashing and cycle stops with dirty water left in the machine. CAUSE - blocked or jammed drain pump. SOLUTION - First remove all the filters inside the machine, syphon or sponge up all the water in the sump and check for any obstruction over the fine grill at the very bottom. (we had a pistachio shell covering the hole!). If this doesn't cue it you will need to gain access to the pump. First, turn off the power. Gently lift the machine onto it's side (be ready for some water to spill out!). Remove the bottom plate (6 screws) and disconnect the sump float switch. Remove the single screw retaining the pump to the bottom of the machine and rotate to remove. You should be able to see the rotor blades. With your finger check to see if the pump rotates freely. To dismantle the pump, remove the 3 screws and separate the two halves. Our pump was jammed with an apple stalk!. Reassemble and connect any cables. Apparently this is a known problem with these machines and can be prevented by assembling the filter system correctly and pre-rinsing plates etc. before placing in the dishwasher.
Posted on Nov 01, 2009
SOURCE: Westinghouse SB915 wont heat up water
found the 2 large lugs mounted on the circuit board had been hot and had dry solder joint's removed solder cleaned with sand paper then re soldered and tested it now heats up .
Posted on Feb 04, 2011
  • 10 Answers
SOURCE: runs through entire cycle fine but water is cold
you need replaced the control board its very popular with this dishwashers cost around $220 as i have replaced mine
HO 1 code dishwasher will not start
Jenny, I believe the HO 1 (or H: 01) means that the machine is set to delay starting for 1 hour. Continue pressing the "DELAY" button until the readout shows H: 00.
Mar 06, 2016 | Westinghouse SB915
I20 trouble light on fridigaie dishwasher
Try this
"Based off the information you have provided your Frigidaire dishwasher is showing you an "I20" error code. I have located that code and it is described as a drain problem that could be either your pump or control panel. I would recommend resetting you appliance, which can be done by flipping the household circuit breaker off for roughly ten minutes. If you continue to experience the error code I would seek assistance from a professional to come diagnose and repair your appliance"
Aug 13, 2015 | Dishwashers
What does error code i20 mean on frigidaire dishwasher mean
Need a model number but the answer may be found in the trouble shooting section of you users manual which again is model number specific.
Aug 13, 2015 | Frigidaire Dishwashers
Zanussi dishwasher beeps once and end of cycle light flashes
Most likely your dishwasher finds fault.
Appliances without a display will show the alarms by a number of flashes of the LED "end of cycle".
For example: one flash = i10, two flashes = i20
..........and so on
So, count how many times LED "end of cycle" flashes and you will know the error code.
Dado
Aug 24, 2014 | Zanussi Dishwashers
Dishwasher Westinghouse SB915 fills with water for wash cycle but does not wash.
Contact Westinghouse directly to request the wiring diagram.
May 30, 2017 | Dishwashers
My dishes come out clean but wet. They used to always come out dry. Do I need a service or replacement part? I have a Westinghouse touchdry SB915.
Check your heating element..
A bad heating element causes many problems in dishwashers...
Dishwasher Problems The Heating Element not Working
How to Replace the Dishwasher Heating Element
Dishwasher Maintenance
heatman101
Asker's Testimonial " explanation very clear. will give it a go and seehow simple it was. thanks Ronnie " - ronnieshomes
Aug 30, 2011 | Westinghouse Dishwashers
Runs through entire cycle fine but water is cold
Apr 07, 2010 | Fisher DD603FCSS Dishwasher
Westinghouse sb915 - draining too early.
1. Is your drain point higher than the bottom of the dishwasher? (ie, does it drain into the garbage disposer or does the drain line drop down below the floor into house plumbing?) Did you just install the unit? You may have to install an "air gap" to prevent syphoning.
2. Did the dishwasher work then suddenly stop working? (asking for clarification)
Dec 13, 2009 | Westinghouse Dishwashers
Dishwashers Logo
111 people viewed this question
Top Dishwashers Experts
