Question about Beko WM5140W
Drum not spinning
Is there a common fort which would stop the drum from spinning. The water fills in the washing machine but doesn't start the cycle.
  • 3640 Answers
SOURCE: Machine won't wash but will spin
If your washer doesn't agitate, check these:Lid switchMotor couplerBeltsClutchDrive motorDrive pulleysTransmissionAgitator good-day !
Posted on Feb 07, 2012
vladmototole
  • 226 Answers
SOURCE: beko washing machine WME 7267 fills with water but will not continue through the cycle
See if the filter is clean or if the exhaust hose isn't blocked.
Posted on Feb 23, 2012
kevin_getz
  • 1031 Answers
SOURCE: beko washing machine not draining
If the drain hose is stretched too much to reach the standpipe, the hose can pitch.
Posted on May 22, 2012
caroldon
  • 17129 Answers
SOURCE: beko washing machine belt keeps coming off
Possible that you need to find out if the replacement belt is the OE type or there is a fault on the quality.
Please check this site. www espares.com for spares
Posted on Jun 06, 2012
  • 66 Answers
SOURCE: beko wme8227 stuck half way through cycle
Ring ds suplies 01782-625551 and ask for chell
Posted on Aug 16, 2012
Electrolux EWF 1495 won't spin.
The belt could be stretched or the tension idler could be malfunctioning.
Feb 12, 2015 | Electrolux Washing Machines
Washer will not spin at all no code . will drain and tumble back and forth,when it comes time to spin it turns off.
A washing machine is basically a big tub that repeatedly fills with water and then drains, spins to wring clothes dry, and has a device for stirring things up-- either an agitator in the middle of a top-load machine or a rolling drum in the case of a front-loader.
The four cycles that every washer performs are fill, wash, drain, and spin. Though these functions are pretty basic, a number of things can go wrong with them.
There are a number of problems that you can fix quite simply; some issues, however, are better left in the hands of an appliance repairperson.Problems that commonly occur with a clothes washer are discussed in depth below.If your washer doesn't run, be sure it's plugged in and that the receptacle works (the circuit hasn't overloaded). Before working on the washing machine, be sure to unplug it.
To prevent problems, follow good maintenance procedures. Use the right amount of detergent for your washer and your water hardness, make sure the machine is level, and don't overload it for the cycle chosen.
Washing Machine Does Not Fill
If the washer doesn't fill, the water inlet screens may be blocked. Clean or replace them. (Check your owner's manual for the location of the screens; they're often located at one end of the supply hoses, or you may have to remove a panel to access them.) Other reasons for not filling may be that either the timer or temperature selector is broken--both of these are repairs for an appliance repairperson.
Washer Does Not Spin
If your washer doesn't spin, check to see if the clothes have jammed or are unbalanced in the drum before calling a repairperson. Unbalanced clothes will also cause a w
asher to shudder or "walk." If straightening out the load doesn't stop the washer from shaking, look at the feet underneath and be sure they are properly adjusted to keep the washer sitting level on the floor (you just turn them to move them up or down).
Clothes Are Wet After Spin Cycle
If your clothes remain wet after your washer's spin cycle, perform the following diagnostics:
1) Lift the lid during the spin cycle. If the tub is not spinning, you may have a damaged motor coupler. Call a repairperson to replace this part.
2) If the tub is spinning, recheck the load to make sure it is balanced. If you are certain the load is balanced but your clothes are still wet, you may need to call a repairperson to replace a damaged motor pulley, tub bearing, belt, or clutch.
3) You can also follow the troubleshooting steps outlined in "Washing Machine Doesn't Drain." You may have a problem with your drain hose or pump.
Oct 27, 2011 | Washing Machines
Front loading washing machine. Made by Jinan Hitone Electrical Appliance Co., Ltd, WM-3011 is the model, but I think it would have other names like Onyx. Been working well up till now (3years+). Today,...
it could be the motor controller. this part is resposable to drive the motor and other components like the electric pump. there is a chance that the combination of motor-controller be bad. try the controller first. is the most common to go out.
Feb 05, 2011 | Washing Machines
The drum doesn;t turn during wash or spin cycle
Kindly remove the back panel of the unit and check whether the belt is properly fixed if it is ok means check the wire connection if everything is fine. kindly check the motor humming sound once the water is filled if you find the humming sound means kindly replace the motor
May 18, 2010 | Whirlpool LHW0050PQ Front Load Washer
Wash cycle and spin
you need to check a simple button called " no spin" may you will see it marked "aspiral shap" and has "x" over
good work !
Jul 05, 2009 | Zanussi ZWF1430W Front Load Washer
Drum will not spin
I am the new owner of a used Asko Cylinda 10504.
The last owner briefly demonstrated the washer starting a wash cycle and entering the agitation cycle of the wash before stopping and pumping the water out and spinning in a final end cycle. I bought it. I had the machine installed turned it on and cannot get it to go through the wash cycle. After starting at #1 it goes through a perpetual spin cycle of sorts--water and soap soaking the drum and laundry but not enough water to fill up half way or less. It stops at number 4 on the program knob sits on a red dot (next to the #4) and does nothing. I then manually move it to the next cycle and it repeats the spin cycle again until I have advanced the program to the end. No wash cycle no rinse cycle. Nothing. When it advances to the red dot I wait for at least 5 minutes before manually advancing the knob. The instructions say that I should get the water pumped out by turning the program knob to #7 or #9 but in both cases it just spins and does no empty or finish in the end spin cycle of several (9?) minutes. Nothing but banging and spinning. The water seems to get into the drum as well as the detergent but nothing else is happening.
No mater where I start the program it spins and sloshes soapy water, pumping almost nothing out.
Any suggestions short of putting it on the curb or paying a kings ransom to fly a tech out to look at it?
MY GUESS.
It seems that it is repeating the same brief cycle over and over. During the move to my house the electronics re set(??!?!?) and now need to be set to the normal mode after being re connected?
Can you help?
Blessings,
Douglas
May 20, 2009 | Asko Washing Machines
WFD 2460 will not start wash cycle after it has filled with water
Isolate power and water supply and gain access to the main drum motor. Check for condition of carbon brushes by removing them and repla
ce if severely worn. Check wiring loom around motor and right back to module controller. The clicking is obviously power being supplied to motor via the loom to the motor. finally check for any dry solder joints or burnt areas on the circuit board controlling the motor.
Dec 07, 2008 | Bosch Logixx WFT 2806 Front Load...
Asko 10505 runs through was cycle in approx. 30 seconds, then wont drain. Simply stops. It doesnt matter which cycle I start with, the dial moves quickly to stop. It fill with water and spins. ANY HELP...
hi sir' start the wash machine empty and see if it happens when nothing is in it.
2. When machine is off, open the top grab the centerpiece inside the wash machine and pull and push it slowly, does it move? (For safety unplug the machine)
3. Make sure machine is 100% level (front to back, left to right)
The most common thing is bad drum bearing, which force the wash machine out of whack when in spin / wash. Which are common and the best thing is to call Maytag.
thank u .........................................please rate
__________________
Sep 11, 2008 | Asko Washing Machines
Wash starts it fills with water then stops and wont wash
problem may just be that drum is not turning so you think program is stopped. try cancelling and select spin program and see if you get spin
Apr 01, 2007 | Hotpoint WMA44 Front Load Washer
Beko WM5140W Logo
29 people viewed this question
Top Beko Washing Machines Experts
Tom Chichester
J D Wright
 Russ Hill
Russ Hill
Are you a Beko Washing Machine Expert? Answer questions, earn points and help others
