Question about Sharp AR-M205 Black and White Copier
Eoor h4 on m205, tried #-> intprt-> C -> intrpt -> 14 -> Strat but doen't work please help
    New Friend:
  • 91 Answers
If the error can not be reset, you should check the heater lamp with an Ohm meter
Posted on Jun 17, 2009
What to do when Sharp AR-M205 showing message h4
Fusing error.
check fuser unit first and reset by simulation 14.
Mar 11, 2014 | Sharp AR-M205 Copier
What is an H4 code and what do I need to fix it
H4 mean fusing lamp problem so you have to
1) check the fusing lamp
2: check fusing lamp thermostat
and after all you must rest the code by press - # key -interrupt key - C key - interrupt key - 14 - ready
Dec 17, 2010 | Sharp AR-M205 Copier
Hi, My machine is sayin error H4, how can i Fix it. its a sharp ar-m205.
H4 code means your fuser did not come up to the preset temp in the predetermined time-frame. Try resetting the copier by pushing the # key, the * key, the C Key, then the * key, in rapid succession which will bring you into simulation mode. once there type 14 with your number pad, and press the start key. It may ask you to verify, select yes. once it is finished, push the CA (clear all) key and the machine will reboot.
If this doesn't correct the issue, call a service technician in your area to come and look at your fuser. a bulb may be burnt out, or the thermistor may be broken,
Hope this helps!
Ryan
Oct 28, 2010 | Sharp AR-M205 Black and White Copier
H4 errer
H4 error mean heater lamp error.
You can try to reset this code
# * C* press 14 press print key.If machine will not be ready may be really your heater lamp is damage.Replace new one.
Sep 02, 2010 | Sharp AR-M205 Copier
Sharp AR-123E, H4 error code, printer not ready
it doesn`t need to change board. code 14 clears.
May 04, 2010 | Sharp AR-M205 Copier
AR-M205 Error message: H 4 Please help!
H4 error mean heater unite problem
Solve: # -Interrupt -C - interrupt, press 14, press Start key.
Jan 27, 2010 | Sharp AR-M205 Copier
My Sharp AR M205 has the error H4
Hello sir; Your machine require reset procedure; press "#", "interupt", "clear", "interupt" then enter 14 press start.
Jun 04, 2009 | Sharp AR-M205 Black and White Copier
SHARP AR M-205
Hello sir; this error code require reset the procedure as follow;
1, press "#", "interrupt", "clear", "interrupt".
2, enter 14, press start.
3, turn power off and back on
Feb 07, 2009 | Sharp AR-M205 Copier
H4 flashing
to access the service mode.
enter the folowning keys .PROGRAM .ITEREPT .CLEAR INTERPT MUST BE IN SEQUENCE
THAT ENTER NUMBER 14 THAT START BOTTON
HOPE THAT HELP
Nov 14, 2008 | Sharp AR-M205 Copier
Sharp AR-M205 Black and White Copier Logo
50 people viewed this question
Top Sharp Office Equipment & Supplies Experts
Anthony Karuku
k24674
jasbo
jasbo
Are you a Sharp Office Equipment and Supply Expert? Answer questions, earn points and help others
