Question about Samsung VP-D34i Mini DV Digital Camcorder
Driver for pc
I want to connect my camcorder to my personnal computer
Cyberview cs memor-ease unable to connect to pc
Try a connecting it to a different port on the computer. Make sure the computer can see a different device on that port, so you know the port is ok. Then try a different cable.
Dec 21, 2013 | Pacific Image Electronics Memor-ease...
How to import files from camcorder to my pc
If you have data cable given to the camcorder connect it with the camcorder and the other end to the usb of pc.Then computer can detect the device ,import files to the computer.Install your camcorder driver before plugging data cable
Sep 06, 2010 | Panasonic VDR-D100 DVD Camcorder
My computer isn't letting me import the data.
In order to connect your camcorder to your computer, and download your pictures or videos, you have to install the drivers for your camcorder and windows Operating system before you connect your comcorder to your computer. Here are the steps in sequence to install the drivers.
1- Use the CD which came with your camcorder and install the drivers.
2- After installing the drivers, Connect your camcorder to your PC and turn the dial to play (Turn on the comcorder if not on).
Follow the screen until it says ready.
3- Now click start, then computer. You should see several icons with one of them having all or part of Sony DCR-TRV16E Mini DV Camcorder. If you double click on that icon, you would see one or more folders with your stored pictures and videos. Now you can download, copy delete all of them.
GOOD LUCK!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!
Jun 27, 2009 | Sony Handycam DCR-TRV16E Mini DV Digital...
We can not connect our JVC GR-DF430AA CamCorder via IEEE-1394 CarBus to the computer !!! Why??? The computer didn't display any messages.
In order to connect your camcorder to your computer, you have to install the drivers for your camcorder and windows Operating system before you connect your comcorder to your computer. Here are the steps in sequence to install the drivers.
1- Use the CD which came with your camcorder and install the drivers. If you do not have the CD, you may be able to download it from JVC webSite.
2- Afetr installing the drivers, Connect your camcorder to your PC and turn the dial to play (Turn on the comcorder if not on).
3- Now click start, then computer. You should see several icons with one of them having all or part of JVC GR-DF-430AA Camcorder. If you double click on that icon, you would see one or more folders with your stored pictures and videos. Now you can download, copy delete all of them.
Jun 25, 2009 | Video Cameras
How do I get a video from my camcorder to PC?
3- Now click start, then computer. You should see several icons with one of them having all or part of Sony DCR-HC39E Mini DV Camcorder. If you double click on that icon, you would see one or more folders with your stored pictures and videos. Now you can download, copy delete all of them.
Jun 25, 2009 | Sony DCR-HC39E Mini DV Digital Camcorder
I CAN NOT TRANSFER VIDEOS FROM MY SONY HANDYCAM VAMERA TO MY PC
You need to install the drivers for your camcorder, before you conncet your camcorder to your PC.
The drivers are in the CD which came with your camcorder. follow these steps
1- inser the CD( If you do not have your CD go the link below to download it
http://www.bioticaindia.com/dcr-trv285e.html
2- select install drivers
3- after drivers are installed, Connect your camcorder to your PC, turn it on and follow the screen untill it states your camcorder is installed and ready
4- Now if you click start, then computer you should see an icon which has all or part of sony DCR-trv285. Double click on this icon. You would see one or more folders with your pictures and videos stored in it.
You may now download, copy, delete etc all of them.
Jun 15, 2009 | Sony DCR-TRV285E Digital-8 Digital...
I have panasonic handycam model no. NV-VZ1EN/ENH/ENC .how can i connect this to my computer?
You need to install the drivers for your Camcorder in order to be able to connect to your PC. When you bought your Cam a CD came with it. Here are the steps to install the drivers.
1- Insert the CD and follow the screen to install the drivers. If you do not have your CD go to this link to download drivers for your camcorder
http://www2.panasonic.com/consumer-electronics/support/Cameras-Camcorders/Camcorders.75489
enter your model# and download the drivers
2- After installing the drivers, connect your camcorder to your PC and turn the Cam ON.
3- The drivers will be installed automatically
4- After it is finished, click start, then computer. You should see a drive with name of your camcorder. Double click that, Now you should see one or more folders containing your pictures. You can copy, delete, and view all the pictures or videos stored in your camcorder.
GOOD LUCK!!!!!!!!!
Jun 11, 2009 | Video Cameras
TRANSFER TO PC
Hook up camera let windows say find new hardware. FOllow the prompts. Acording to Sony Xp has the driver already unless it is a 64 bit. See Below:
  • The drivers needed to connect most Sony® cameras and camcorders to a computer are already included in the Windows Vista and Windows XP operating systems. With these drivers, you should be able to connect and transfer files to a computer.
    Note: If the your camera or camcorder is not recognized by the computer when connected, you may need an updated driver.
  • Detailed Windows Vista compatibility information is available for Sony Cameras and Camcorders.
  • The Windows Vista Starter edition and Windows XP 64-bit operating systems are not supported.
http://esupport.sony.com/US/perl/swu-list.pl?mdl=DCRHC21&SelectOS=31
Dec 21, 2008 | Sony Handycam DCR-HC21 Mini DV Digital...
Connecting analong camcorder to computer
The only Analog camcorder that has a USB Connection for transferring pictures or video is the SC-L770. The SC-L770 can transfer video (live or recorded) and still photos through the USB connection. You can also transfer audio using the audio cable provided. After installing the driver and software, you can begin transferring data using the software provided. Connecting to a PC 1. Connect a USB cable to the USB port on the PC. 2. Connect the other end of the USB cable into the proper terminal on the camcorder. (USB jack) 3. Connect the audio cable to the Line input jack of the PC. If the PC has no Line input jack, connect the audio cable to the MIC input jack. In this case, however, a noise may be produced depending on the PC. Notes: * If you disconnect the USB cable from the PC or the camcorder while transferring, the data transmission will stop and the data may be damaged. * If you connect the USB cable to a PC via a USB HUB or simultaneously connect the USB cable along with other USB devices, the camcorder may not work properly. * In this case, remove the other USB devices from the PC and reconnect the camcorder. Some other Analog Camcorders have a snapshot mode which allows you to take a still photo with your camcorder. However, you cannot transfer these to a computer unless you purchase additional hardware such as a capture card. Some capture cards have analog a/v inputs which will allow you to use the a/v outputs on the camcorder to connect to your pc and transfer images and video. You can purchase a capture card at most computer and electronics stores. Samsung does not support capture cards.
Sep 06, 2005 | Samsung DouCam VP-D5000i Mini DV Digital...
Samsung VP-D34i Mini DV Digital Camcorder Logo
Top Samsung Video Cameras Experts
Tony
Lawrence Oravetz
Are you a Samsung Video Camera Expert? Answer questions, earn points and help others
