Question about Kenmore HE2 Plus Front Load Washer
How do i know if control board is bad causing a f6 code
I get a f6 code on washer, how do i determine if board is bad or good
    New Friend:
If you take the code book out of the washer. Or if you have a service manual. Then go though the code list. it should tell you what the f6 code is. That's how I sound the problem with the problem with the RPM sensor. Replaced it and the machine works fine. It should tell you what part of the machine the code is from.
Posted on Mar 30, 2014
I have an f6 code and the machine will not operate once it comes up
The F6 error code means that the computer on the control didnt detect that the motor reached a high speed on the spin cycle, sometimes it thinks the washer didnt spin fast enough because of a loose wire connection either on the motor or the control boards (motor &machine control) if you find that the washer did actually spin at high speed (clothes dont come out sopping wet at the end of cycle) the wire connections or the motor control board will be the potential causes of the F6 error code. Try unplugging the machine for five minutes to let the computer reset then try again. Next check the control panel wires. f6 code flashing on display Kenmore Elite HE3 Washing Machine
May 19, 2015 | Washing Machines
When the motor is bad can it cause the Motor Control Board to go bad also?
Good Morning Friend,
I understand that you want to know if the motor is bad in your Frigidaire Affinity washer, model# ATF7000E, can it cause the motor control board to go bad as well. Just because the motor is bad, does not mean that the motor control board is bad. It depends on what is going on with your appliance. I suggest contacting your local authorized technician for further assistance. They will be able to diagnose your washer and determine exactly what is going on. Hope this is helpful.
-Best Regards-
WP
Jun 14, 2014 | Frigidaire Affinity ATF7000E Front Load...
F6 error on Hitachi washing machine Sk 120KJS
Jul 09, 2012 | Washing Machines
Why does the washer stop during a load and "F 06"
GENE
Sep 09, 2011 | Kenmore HE2 Plus Front Load Washer
F6????
The F06 error code on the HE3 elite is a tachometer error. Per the tech sheet, it says to check all connections and continuity between the MCU, CCU and Drive Motor. The tech sheet says normal reading is at 6 ohms.
Apr 18, 2010 | Kenmore 3.8 cu. ft. HE3 Front Load Washer
He 3t error code f6,washer will not spin,door will not open
"f6" error code means that there a miss communication between mcu(motor speed control board) and ccu(central control unit). i recommend you to ohm out the motor. most likely its your motor speed control located at the bottom left of the washer good luck. replace the motor speed control board and you should be all set to go.
May 09, 2009 | Kenmore 3.8 cu. ft. HE3t Front Load Washer
Kenmore HE3,what F6 means
f6 is a communication error with the motor control board, i would unplug unit , remv eth bottom panel)3 screws across the botom of nit) andthe motor control board is rightthere on the left floor of the unit. check for good non corroded terminal connections, ive also seen extreme humidity/ water in surronding area trip this code
Jan 26, 2009 | Whirlpool Gold Duet GHW9400P 3.8 Cu. Ft....
F6 Code
its a bad motor or motor controller board in bottom of washer by motor,had 2 f6 both times it was motor 1 bad bearing other freezing up,replaced motor easy to do ops were ok
Nov 09, 2008 | Kenmore Elite 45986 Front Load Washer
Whirlpool duet front load
The "F06" error is a Motor Speed problem. You may have a problem with either your drive motor, motor control unit or main computer board (known as a CCU). The following link explains how to check and determine what may be causing your problem:
http://www.fixya.com/support/r714929-f06_error_whirlpool_duet_kenmore_elite
If you have any questions, or require additional assistance, please let me know. I hope this helps.
PS Check for the obvious first. Make sure the drive belt is still attached and not broken before getting too deep into troubleshooting everything else. NOTE: More commonly, this is an indication of a motor control unit failure.
Aug 10, 2008 | Whirlpool Duet GHW9150P Front Load Washer
Kenmore HE2 Plus Front Load Washer Logo
134 people viewed this question
Sal De
fordexpert
Jim Goldsmith
Jim Goldsmith
