Question about Ricoh Aficio 1035 Copier
Error code sc200 on a ricoh afcio mp c1500 - Ricoh Aficio 1035 Copier
  • 3 Answers
Turn Machine off then on.
If it doesnt work press on keypad [*107 Clear] then press System SP. then turn Off the On.
Posted on Jan 05, 2016
SOURCE: Ricoh Aficio MP C1500SP - functional error SC202
call ricoh serviceman he/she can fix it.
Defective tank full sensor
• Tank full lever bent or broken
• Incorrect ink suction
1. Check the harness of the tank full sensor.
2. Replace the GJ engine.
3. Replace the maintenance unit.
• The position of the tank full lever
does not stay at the tank full position
after ink initialization or air releasing.
• The position of the tank full lever is
not detected at ink suction.
Posted on Jun 23, 2008
Bubbabear64
  • 2794 Answers
SOURCE: Waste ink tank full on a Ricoh Africio MP C1500 sp
The book doesn't really tell you where it is in the machine but if you open the door in front of the copier, look for a white plastic bottle with toner in. Remove the toner bottle from the machine and dispose of the toner bottle and replace it with a new one or dispose of the waste toner. Clean the bottle and replace it back into the machine.
Posted on Dec 02, 2008
  • 95 Answers
SOURCE: Ricoh Aficio MP C3500 Error Code SC529
It would help to know the code. Like SCxxx.
Posted on Mar 27, 2009
Ickoajnc
  • 183 Answers
SOURCE: Ricoh Aficio MP 1600 Le error code sc 322 occured
Try to reset the machine by turn it off and after 5 second turn it on again by the red switch-plug which is located on the left side in the middle.
If this do not help you will need to cal a technician because the machine have problem with the laser unit.
Please answer do this is helpful.
Regards
Posted on Jan 13, 2010
  • 2072 Answers
SOURCE: Describe how to remove a hard drive from Ricoh Afcio 2045
Remove the back cover, It should be located directly on the right of the machine. Just requires a phillips screw driver. REMOVE POWER FIRST .
Posted on Jul 27, 2010
Ricoh mp 1600 error 194 ricoh mp 1600 error code 194 how do I solve the problem
Having problems finding your error code. Here is a complete list of all codes for your printer: http://www.printcopy.info/?l=en&mod=free&chap=erc&brand=Ricoh&model=Aficio%20MP1600
I do find the error code for a different Ricoh model (Aficio 1018).
http://printcopy.info/?l=en&mod=free&chap=erc&brand=Ricoh&model=Aficio%201018
Please verify your model number and error code.
Apr 21, 2015 | Ricoh Aficio Mp-1600 Copier
RICOH MP4500 SC 390 DISPLAYS WHAT TO DO
Hello.
That error is related to TD sensor error.
I advise you to call a trained Technician
Mar 16, 2015 | Ricoh Savin Lanier Genuine Toner Type Mp...
Contact Service Center if it's still in Warranty, otherwise Contact any Hardware Engineer.
Mar 29, 2014 | Ricoh Office Equipment & Supplies
The 7,010.43 error code indicates the printer is having difficulty tilting the printhead forward from the parked position to the print position. There are several printer systems involved in tilting the printhead so troubleshooting the error can be challenging. The printer does not directly sense the printhead's tilting position. Instead it applies drive current to the process drive motor, and monitors the motion of the motor's rotation encoder for "following error". For a particular drive voltage the encoder should rotate at a particular rate as the printhead (driven thru the process drive, the DM camshaft, and the head tilt gear train) tilts forward. If the printer does not see the expected encoder readings it assumes a tilt failure.
for more hrlp visit CBR Tech Solutions
Mar 30, 2012 | Ricoh Aficio Office Equipment & Supplies
Problem with the Ricoh mp c2800 Ricoh error code sc 672,
If the model ia a MPC 2800 it a controller board issue maybe the operation panel. -carl
Nov 15, 2010 | Ricoh Aficio 1035 Copier
Mar 26, 2009 | Ricoh Aficio MP1600SPF Copier
The copier is a Ricoh Afcio 350
SC 326: Laser synchronization detector board cannot receive the laser beam.
Replace the laser sync detector, Part No. A2935310.
Or try the following solution;
Open the front cover and remove the brown inner cover - 2 screws.
The black unit after the inner cover is the laser unit. There are 2 screws securing the laser unit - loosen them.
Tighten the right securing screw while jacking up the right side of the laser unit with a screwdriver.
Tighten the left securing screw and put the inner cover back on.
If SC 326 is still indicated after the above procedure, replace the laser sync detector or the whole laser unit.
Good luck and please rate me, thanks.
Apr 05, 2008 | Ricoh Aficio 450 Copier
Ricoh Aficio 1035 Copier Logo
130 people viewed this question
Top Ricoh Office Equipment & Supplies Experts
OfficeServiceAjnc
OfficeServiceAjnc
fares
Level 1 Expert
SOURAV KAPOOR
Level 1 Expert
Are you a Ricoh Office Equipment and Supply Expert? Answer questions, earn points and help others
