Question about Samsung RS2630WW Side by Side Refrigerator
Fridge side not cooling
I hava a samsung DA99-00494V and the fridge side not cooling all the time is a 10 what to do
    Problem Solver:
  • 19 Answers
Start by turning off the ref.
Pull the plug.
Posted on May 22, 2014
SOURCE: i have a samsung side by side srs537nw. both side
Had exactly the same problem. Found the cooling coils are not defrosting, everything was iced up inside the back panels. The drain was blocked, water pooling underneath also.
Remove all the plastic panels in the back of the freezer, including the temp. sensor (unplug) and fan (unplug). Defrost everything with a hair drier.
Make sure that the drain at the bottom is free, a small plastic tube which takes water down into a pan where it is evaporated by the compressor etc.
Replace the defrost sensor - the most likely faulty part. This costs about $Au 20.00 from Samsung (just ask for a defrost sensor for the model of fridge). This sensor fits in a plastic cage attached to the top of the cooling coils, has wires which plug into a socket. Reassemble the fridge and see if this has solved the problem.
If the fridge still does not defrost automatically, you may need to replace the circuit board ($Au 80.00 from Samsung). This board is found from the back of the fridge, in a plastic box behind a back panel at the bottom of the back of the fridge. Lots of wires to unplug!
There may be other problems, like a faulty thermostat on the valve which controls circulation of cold air into the fridge from the freezer, I have no experience of solving this.
Samsung mechanics are HOPELESS in my experience, replacing the two parts above will be less expensive than a call to them. Good luck!
Posted on Jul 23, 2011
kel1guy2002
  • 3740 Answers
SOURCE: I have a 4 year
Hi and welcome to FixYa. I am Kelly
Press the Power Cool and the Power Freeze buttons for 8 seconds it will enter the diagnostic mode.
Take a look at this link to determine what fault you have under
Step One diagnostics..
http://www.ukwhitegoods.co.uk/modules.php?name=Content&pa=showpage&pid=209
There are 13 different faults than can be displayed. Each one of the LEDs in the picture under step one indicate what that fault is by the DIGIT position of the flashing LED. (Legend to the left of picture) Usually that fault is either a component or wiring problem.
The diagnostic test should pinpoint the problem.
Note that the Power Cool and Power Freeze buttons are depressed for 8 seconds to clear any faults. It the fault remains it will reappear again.
Thanks for choosing FixYa.
Kelly
Posted on Sep 26, 2010
tborn6
  • 700 Answers
SOURCE: samsung rs2533sw fridge not cooling
soiunds like the coil on the refrigerator side is iced up.take and open the refrfigerator side and take a blow drier and after removing the 11 screws use the hair drier to slowly melt the icec behind the cover. If you pull too hard and or too soon you'll break the stryofoam ductin that has to be around the coil. then make sure that the drain line is clear reassemble and have a Merry Christmas!
Posted on Dec 24, 2008
  • 3 Answers
SOURCE: RS2545SH. Fridge side is not cooling. Thanks
I have the same problem....anyone have a fix
Posted on Feb 16, 2010
heatman101
  • 43501 Answers
SOURCE: Samsung Side by side Fridge not cooling
Check out these tips...they can help you figure out whats going wrong with yourrefrigerator and why it is not cooling
Refrigerator not Cooling or Fridge not Cooling
How to Defrost Refrigerator Defrost Timer Problem
Water Running in refrigerator from Freezer
Refrigerator or Freezer not Cooling or Getting Cold
heatman101
Posted on Sep 30, 2010
Samsung fridge coils frozen over on refrigerator side.
Not sure what the ohms should be,but ckeck coils for damage you may have a leak
Dec 07, 2013 | Refrigerators
Samsung srs580dw fridge freezer after being
Most refrigerators get their cooling from the freezer. I suggest that you give it some time, and make sure the small door or damper leading from the freezer to the fridge is open and not obstructed by any food items
Aug 25, 2013 | Samsung RS2556 Side by Side Refrigerator
Have a 6 - 7 year old Samsung RS2534WW from Best Buy. The back interior wall of the fridge is bulging forward/inward for quite some time now. We had to remove some shelving in order to be able to close...
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";} Hi,
Check out these tips...they can help you figure out whats going wrong with your refrigerator and why it is not cooling
heatman101
Aug 30, 2010 | Samsung RS2534 Side by Side Refrigerator
heatman101
Feb 10, 2010 | Samsung RS2556 Side by Side Refrigerator
Our KSR25RSMSO1 is not working. The freezer is too cold, and the refrigerator is too hot.
May sound a silly question but has someone adjusted the fridge thinking it was the freezer and vice versa ?? I hava an Amana and have to think twice which symbol is fridge and which is freezer.
Usually the main won't go problem with fridges is.. the fridge part is cool but the freezer won't freeze. This indicates a refrigerant leak or compessor problem - all which require a service call to fix..
Nov 07, 2009 | KitchenAid KSRG25FK Side by Side...
My samsung ref rs2555sl stopped cooling. The temperature display for both freezer and fridge on the front keeps flashing. What do I need to do?
Most of the time if you unplug it from the power source for about 10-15 minutes will reset fridge computer and when you plug it back everything get back to normal.
Oct 02, 2009 | Samsung RS2578BB Side by Side Refrigerator
Fridge not cooling. Temperature rising
most common problem is the defrost timer motor,it tells the fridge to de ice ,about every 10 hrs or so,if it gets stuck or burns out your evaporator will be a block of ice ,and the fan blowing on it wont transfer cold air,look in the bottom of the fridge by the compressor,
Sep 14, 2009 | Samsung RS2534 Side by Side Refrigerator
Fridge & Freezer not cooling
You will need to change the complete control pc board.
Mar 05, 2009 | Samsung RS2630SH Side by Side Refrigerator
RS21DCNS
as a rule of thumb mfgs say give the unit 24 hrs to stablize where are you gettings the readings the fridge or freezer sides freezer readings run from -8 to -10 the fridge should run 34to38
Jan 31, 2008 | Samsung RS2630SH Side by Side Refrigerator
Samsung RS2555SL humming noise
don't know this model specifically, but have had loads of problems with these samsung fridge-freezers. the no water in drinks dispensor is probably due to the water bottle at the bottom of the fridge being frozen. this is endemic with samsung the noise you hear is ice hitting fan. samsung use two systems for fan. the one i think you have is separate fans for fridge and freezer and a separate evaperator for fridge and freezer. take of the back plate of the fridge and you will find the fan mounted in it. disconnect the plug and socket connection. you will probably find ice build up round the fan blade. melt off with hot water. the bar you had showing on the "8" is a fault code - the most common fault being the defrost termination sensor. unless you are experienced, this is not really a diy appliance
Apr 02, 2007 | Samsung 26 Cu. Ft. Side-by-Side...
Samsung RS2630WW Side by Side Refrigerator Logo
441 people viewed this question
Top Samsung Refrigerators Experts
John Tripp
John Tripp
Charles T Nevin
Charles T Nevin
Are you a Samsung Refrigerator Expert? Answer questions, earn points and help others
