Question about Logitech Z506 Surround Sound Speakers
So i have a subwoofer (188W) with some serious power. Next to it i have a surroundset (about 0,5 meters apart). On a day i had my subwoofer on at full power and then the surroundset turned off (becaus
There was a safety causion on the subwoofer: Strong magnetic field, keep electronic devices at least 0,5 meters away from subwoofer.
    Problem Solver:
  • 8 Answers
You should move your surround set a little further so it doesn't interfere with the subwoofer. It may say .5 but the surround set may have a magnetic field that requires it to be further away. Just move it further and you should be good.
Posted on Jun 11, 2014
2006 TOYOTA SIENNE RADIO, GPS, BACK UP CAMERA SCREEN HAS GONE BLACK WHAT MAY BE WRONG WITH IT
all those toys, when broken can be expensive...to fix. labor.... and parts
but my guess is :"?
next time check all fuses, in cab and engine bay .box.
if fuses look bad they are,! blown up.
if they look good, they can in fact, be bad. hmmmmmmmm....
use any ohm meter (any,DMM/DVM) and select ohms low
0 ohms is good.
infinity is bad fuse. every time,
ohms is the value of resistance, all full meters have this check
0 can be 0 to 1ohm if meter has auto zero , 0 will be 0 (RTM )
if not, most read about 0.3 ohms or the meter lead contract restance which we ignore on cheap meters)
Dec 14, 2013 | Toyota Toyota Cars & Trucks
How to use a multi meter to check continuity
you can use the ohms check, 0 ohms is full continuity. or diode check will beep when continuous circuit is achieved.
Dec 29, 2012 | Car Audio & Video
How to use
Voltage testers and volt meters are two different things. A meter will provide a an indication of the exact voltage and type AC or DC. A tester on the other hand simply provides an indication of presence of power with little to no indication of how much or type.
AC power is what is provided by most power companies in the world. DC is a type of power provided by batteries and DC power supplies. If your tester or meter has provisions to check for AC and DC, you should check for BOTH. If AC power is present and you are have set your meter to test for DC power, your meter will indicate 0 volts. You can see this can be a dangerous condition. Most simple testers will not care if AC or DC power is being tested and the types that use neon lamps will usually glow differently for AC and DC power.
When setting up for testing voltage, you must test across the power source (or in "parallel") or load (such as a light bulb), as opposed to "in series" with the power source. Across would be from the + to - post of a battery, into the slots of an outlet, etc. "In series" is when the tester would be completing a circuit - such as testing across an open switch.
First, check the meter's operation by testing a known good power source by following the next steps. Set the meter for the type power to be tested. Choose AC if unsure. Next, set the meter for the highest voltage range supported. Make sure this range is higher than the expected voltage, otherwise damage to the meter may result. Connect the probes to the power source. Read the meter. If the meter moved only slightly, adjust the range of the meter to the next lower value. You can keep adjusting downward as needed to get the most precise reading possible - but do not set the range to a value less than the voltage present. A 0-300 volt scale is the lowest to measure a 240 volt outlet - switching to a 0 - 150 volt scale will damage the meter. The 0 - 150 volt scale would be fine for measuring 120 volt outlets.
If the meter did not move, change the type from AC to DC. and repeat. If it still does not work, the meter is not working correctly (if testing a know good source) or there is no power present (if the meter worked on a known good power source).
May 12, 2012 | Measuring Tools & Sensors
Pioneer home theather subwoofer powers up but I get no sound. I checked the speaker cone, it looks perfect. This is an older sub woofer so I don't mind taking it apart to learn how to fix it if possible. ...
Look for the biggest semi-conductor on the PC board, that will be the power amp that does all the work, or perhaps in your case not! If it is an IC replace it! You can test transistors with an Ohm meter. Look for shorts in the case of those.
Mar 13, 2010 | Audio Players & Recorders
How to unseize a speaker
Does it smell really bad, if so you probibly over powered the voicecoil wire and the insulation melted off and shorted. You should check the resistance first to see if it's fryed, if your sub is 4 ohm that's what you should read with a multi-meter, if it's close to 0 or 1 than you won't be able to fix it
Sep 29, 2009 | Kicker CVR12 Car Subwoofer
Klipsch Subwoofer sub10 power supply problem in India
as we know in India power goes on and out all day. so avoid using any extensions
Mar 18, 2017 | Audio Players & Recorders
One minutes Battery meter shows full, the next 0% Battery Low
Have you tried powering the phone off and removing the battery? Cleaning the charging contacts on the phone and the charger? Inspect the charging port to make sure there wasn't any damage from the fall. Then restart the device.
Hope that helps.
Apr 22, 2009 | Sony Ericsson Walkman W810i Cellular Phone
My 2000 watt nitro amp just stopped working need help
Think about anything out of the ordinary that may have happened the day (or day before) it quit.
  • Was work done to your system?
  • Did someone mess with your system?
  • Smell anything odd?
  • Especially loud?
  • Did it quit mid-song or did it work yesterday and not today?
Assuming nothing special, here are some diagnostics you can perform. At the very least, they will help tell you what the problem isn't, First....
Eliminate power supply problems.
Use a meter to make sure you have power to your amps +12v terminal. A meter is preferred over a test light to confirm a full +12 volts.
Make sure the ground terminal is grounded. A meter with a continuity test option is best for this.
If either of these fail, trace the wires to find the fault. Large amps like yours normally have dedicated power cables. These cables usually have an additional in line fuse close to the battery. Check it.
If they pass, double check the amp fuse.
Pull the wire (usually blue) from the 'remote' terminal on the amp.
Then try jumping the +12v line to the remote terminal.
If it still doesn't power up, check for signal shorts.
Turn the gains down low.
Pull the input lines and try the +12v to remote jump again.
Next pull the speaker wires.
Your amp should now have only two wires and a jumper attached to it. Try the same jump.
If it still fails, the problem is in the amp itself and (I'm sorry to say) leaning toward the serious.
Hope this helped
Mike.
Jul 09, 2008 | Nitro BMW-486 Car Audio Amplifier
Woofer not powering on
hows power strip your pluged into ? try differt outlets is it
srewed down tight to wood cabnit wires tight on speaker good grounded power how sthe wire going to it
Jan 06, 2008 | Bose Acoustimass 15 System
Logitech Z506 Surround Sound Speakers Logo
65 people viewed this question
Top Logitech Computers & Internet Experts
micky dee
mukhtar21 shaikh
mukhtar21 shaikh
Are you a Logitech Computer and Internet Expert? Answer questions, earn points and help others
