Question about Acer Aspire 3610 Notebook
Removing the middle
Does any one know how to remove the middle cover to get to the keyboard.
  • 90 Answers
Cannot remove gas tank on '11 blackline harley
Gently remove the "Bar and Shield" logo in the middle of the cover, then the final nut, that holds the cover will be exposed.
May 14, 2012 | Motorcycles
How do i remove keyboard on5551-a laptop?
It's almost simular. First of all you have to remove two little screws at the back of the hinges.
Mar 12, 2011 | Acer Aspire 5500 5570-2609 Laptop
Have gateway lt2016u, i need to know how to take it apart
remove battery and all screws on bottom including the three screws in the battery compartment turn over and starting in the top middle of keyboard ( abvove the f8 key ) pop keyboard up remove keyboard cable and lift away keyboard remove all screws from under keyboard and up plug the two cables lift top cover off you now have access to all inter parts
Oct 15, 2010 | Gateway Computers & Internet
How do you get underneath the keyboard
You don't need to remove the keyboard to access the ram. Just undo the single crosshead screw on the removable cover in the middle of the laptop from beneath. I you do ever need to remove the keyboard there are 2 screws underneath this cover, which are marked with a keyboard symbol. Undo these and then slide the 4 small lugs at the top of the keyboard and it will lift up
Jan 04, 2010 | HP Compaq nx6325 Notebook
Remove the RTC battery for at least 15 monutes then replace. Get into BIOS and reset date and time. Removing the Coin-Cell Battery
  1. Follow the instructions in Before You Begin.
  2. Remove the hinge cover (see Removing the Hinge Cover).
  3. Remove the keyboard (see Removing the Keyboard).
  4. Insert a plastic scribe into the guide on the side of the coin-cell battery compartment, and pry out the battery.
Replacing the Coin-Cell Battery
  1. When you replace the battery, insert it at a 30-degree angle under the clip with the positive (identified by a plus [+] symbol) side up, and then push it into place.
  2. Replace the keyboard (see Replacing the Keyboard).
  3. Replace the hinge cover (see Replacing the Hinge Cover).
Oct 02, 2009 | Dell Inspiron 1501 Notebook
How to replace Dell Precision M6400 keyboard?
Removing the Keyboard caution.gif CAUTION: Before working inside your computer, read the safety information that shipped with your computer. For additional safety best practices information, see the Regulatory Compliance Homepage on at:
  1. Follow the procedures in Before Working on Your Computer.
  2. Remove the LED cover (see Removing the LED Cover).
  3. Remove the four M2 x 3-mm screws along the top of the keyboard.
notice.gif NOTICE: The key caps on the keyboard are fragile, easily dislodged, and time-consuming to replace. Exercise care when removing and handling the keyboard.
  1. Use the metal pull tabs to gently slide the keyboard toward the back of the computer to disconnect the keyboard.
Oct 01, 2009 | Dell Computers & Internet
How to remove the keyboard from a toshiba satellite a100
Here is the link to the manual
if this helped you please vote for me.
Aug 31, 2009 | Toshiba Satellite A100-S8111TD Notebook
Im trying to replace the dc jack on a gateway mx6930. I need help removing the case to get at this. You know I removed all visable screws from the case, started prying, and stoped as not to break anything....
yes you need to pull ALL parts HDD, dvd drive,....
then turn it over and pry loos the cover above the keyboard you should then be able to remove the keyboard
Jun 08, 2009 | Gateway MX6931 Notebook
How to remove keyboard
These are the steps you need to take to Remove the Keyboard for D631 Dell.:
  1. Remove the hinge cover.NOTICE: The hinge cover is fragile and can be damaged if extreme force is used. Be careful when removing the hinge cover.
  2. Open the display all the way (180 degrees) so that the display rests flat on your work surface.
NOTICE: To avoid damaging the hinge cover, do not lift the cover on both sides simultaneously. Removing the hinge cover in a different way than described may cause the plastic to break.
NOTICE: The keycaps on the keyboard are fragile, easily dislodged, and time-consuming to replace. Be careful when removing and handling the keyboard.
3. Remove the three screws at the top of the keyboard.
NOTE: Lift the keyboard carefully to ensure that you do not pull on the keyboard cable.
4. Ease the edges of the keyboard out of the small detents on the sides, then slide the keyboard slightly forward to free the keyboard tabs from the palm rest.
5. Rotate the top of the keyboard forward and away from the display, and lay it upside-down on the palm rest to gain access to the keyboard connector.
6. If the keyboard cable is held in place by a locking arm next to the keyboard connector, carefully spread the retaining bracket away from the connector so that you can pivot the locking arm upward to release the cable.
7. Pull up on the pull tab to disconnect the keyboard cable connector from the keyboard connector on the system board.
Apr 25, 2009 | Computers & Internet
Acer Aspire 3610 Notebook Logo
32 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
