Question about Kitchen Ranges
Rough opening too small
Rough opening between cabinets is 29.5". Is there a range hood solution other than dropping to a 24" hood?
3 Suggested Answers
SOURCE: Kitchen Hood Broan Nutone RM5200 Hood won't pull air.
There is definetly somthing blocking the air from escaping, either the duct is blocked or the installer did not remove the metal plate which opens the fan up for it to be able to evacuate.
Posted on Feb 08, 2009
  • 57 Answers
SOURCE: Offset venting of new microwave/range hood to old fixed venting
You might try your local furnace or heating shop as they can usually custom make ducting and may be able to do this for you, but I am sure it will cost. I have had similar problems and usually a good sheet metal man can help.
Posted on Oct 08, 2009
Testimonial: "Good suggestion. Thanks;"
Runs rough when it's warm. comes and goes. has a 2.7. and then a 99 dodge carvan with a 3.3 does the same thing.
Chrysler Sebring Questions - Car running very rough ...
www.cargurus.com > Questions > Chrysler > Sebring
CarGurusMar 27, 2011 - It seems after car gets to a certain temperature it runs very rough. ... 2011 at 12:16 PM about the 1998 Chrysler Sebring 2 Dr LXi Coupe ... it.one day it washot out and it was running sluggish with rough idle.and ... I changed the altnator and battery its runs like its brand-new.now ... 2002 Chrysler Sebring LXi.
Chrysler Sebring Questions - Engine Power Loss After Car ...
CarGurusNov 3, 2011 - Engine Power Loss After Car Is Warmed Up - Major loss of power after car has ... When vehicle is cold runs ok, sometimes a little rough but not bad. Full power. Allowed vehicle to run for over 45 minutes last night at idle, died on its own, car sat approximately 20-30 minutes. ... 2002 Chrysler Sebring LX.
* Chrysler Sebring/200 Convertible Club * • View topic - Rough ...
www.sebringclub.net/board/viewtopic.php?p=69097
Dec 29, 2006 - 5 posts - ‎3 authors
However, the vehicle still suffers from rough idle under certain conditions: ... been resolved (I don't think he noticed that it happened only when warm though). .... The test will tell you its general condition without having to dig it out of the fender, ..... Powered by phpBB © 2000, 2002, 2005, 2007 phpBB Group rough ...
May 24, 2010
Low idle rpm
Mar 8, 2007
More results from www.sebringclub.net
Jan 01, 2016 | 2002 Chrysler Sebring
2001 Dodge Grand Caravan Sport 3.3 Wifes van started running very rough last week while in slow moving traffic then stalled out. Code showed "map sensor", got a new one and installed. No change....
A bad vacuum line will cause this code also. Also it will cause a rough idle and stalling. Open the hood and listen for a hissing sound. track it and you,ll find the leak. Also I would just check all the lines to make sure another in not ready to go.
Jul 13, 2011 | Dodge Caravan Cars & Trucks
Rough openning for a 30"
You want to make that very close to 30" maybe 1/8 to 1/4" more max. If you make the opening too big you will be loosing stuff down the cracks....
When I did kitchens, my preferance was to let one or both of the countertops loose til the range was in place and then push the countertop snug and then screw it down...
heatman101
Apr 22, 2011 | Kitchen Ranges
My existing duct is a 4x10, the KOBE CH2230SQ does provide the 4x10 ducting option, but 1. it does not have any spout to catch the duct opening; 2. the vent plate has a thickness, but my cabinet is...
You should be able to purchase the 4x10 hood boot from Lowe's or Home Depot. As for the cabinet mount, maybe you can cut a bigger hole. I have modified fittings to fit small spaces but most heat and air installers can make you fittings for small confined spaces. I have found them to be quite reasonable too! Hope this helps.
Aug 12, 2010 | Kobe CH2230SQ Kitchen Hood
A local small contractor installed our Kobe RA3830SQ Range Hood a few days ago. We have not been too impressed with the efficiency of the fan. Today I noticed that it seems to blow out instead of sucking...
Hoods should blow out from the chimney, its defianately not a wiring problem. If it is blowing down towards your cooker instead of sucking up then you should contact Range as it could be a manufacturing fault.
Dec 06, 2009 | Kobe RA3836SQ Under Cabinet Range Hood
Rough idle / what is correct idle 25 td. swb pajero
I have a 98 Montero Sport and to adjust the idle all I needed was a phillips screw driver. Check owners manuel for Idle speed and remember to have lights off when adjusting. Also it showed the idle range posted on the hood underneath.
Jun 02, 2009 | 1999 Mitsubishi Montero Sport
Jenn-Air 30 in. Under Cabinet Hood had no instructions on how to
This is a straight forward wiring project involving 110 volts of electricity and a 15 amp circuit.
If there is already power available at this location use it. If not, run a wire to the cabinet above the hood location with enough extra to drop down into the hood area and hook it up.
Once you have the power wire in place it is just a matter of hooking the wires up black-black, white-white, ground-ground screw.
enjoy your new hood.
May 26, 2009 | Jenn-Air 30 in. Pro-Style Range Hood
Runs rough and keeps fouling out new spark plugs
sounds like too rich of a mixture check for vacuum leaks and check fuel press regulator
Apr 23, 2009 | 1996 Mazda Millenia
Specific dimensions of a side by side model 532
FINISHED ROUGH OPENING DIMENSIONS: WIDTH = 47 1/2" HEIGHT = 83 3/4"
DIMENSION OF 532: H=84" W=48" D=24" MINIMUM HEIGHT=82 7/8" DOOR SWING=29 1/4"
Mar 24, 2009 | Sub-Zero 690 Side by Side Refrigerator
Rough space needed to install 24" built in dishwasher
A 24" dishwasher requires 24" of space between two cabinets.
Dec 07, 2008 | Tappan 18 in. MDR251RE Built-in Dishwasher
Kitchen Ranges Logo
70 people viewed this question
Top Kitchen Ranges Experts
Dan Webster
Dan Webster
paulcarew
Are you a Kitchen Range Expert? Answer questions, earn points and help others
