Question about Ricoh Office Equipment & Supplies
Error code sc200 on a ricoh afcio mp c1500 - Ricoh Office Equipment & Supplies
  • 383 Answers
Contact Service Center if it's still in Warranty, otherwise Contact any Hardware Engineer.
Posted on Mar 29, 2014
SOURCE: Ricoh Aficio MP C1500SP - functional error SC202
call ricoh serviceman he/she can fix it.
Defective tank full sensor
• Tank full lever bent or broken
• Incorrect ink suction
1. Check the harness of the tank full sensor.
2. Replace the GJ engine.
3. Replace the maintenance unit.
• The position of the tank full lever
does not stay at the tank full position
after ink initialization or air releasing.
• The position of the tank full lever is
not detected at ink suction.
Posted on Jun 23, 2008
Bubbabear64
  • 2794 Answers
SOURCE: Waste ink tank full on a Ricoh Africio MP C1500 sp
The book doesn't really tell you where it is in the machine but if you open the door in front of the copier, look for a white plastic bottle with toner in. Remove the toner bottle from the machine and dispose of the toner bottle and replace it with a new one or dispose of the waste toner. Clean the bottle and replace it back into the machine.
Posted on Dec 02, 2008
  • 95 Answers
SOURCE: Ricoh Aficio MP C3500 Error Code SC529
It would help to know the code. Like SCxxx.
Posted on Mar 27, 2009
M2Tech1
  • 313 Answers
SOURCE: Ricoh copier MP 6000 error code
THIS IS USUALLY FOR THE FUSER SECTION IT MAY BE THAT SOME TONER HAS BUILT UP ON THE THERMISTOR AND IT AINT READUNG THE TEMP PROPERLY AT WARM UP OR ON A RUN IT HAS TO OVERHEAT TO GET RIGHT READING TAKE THE FUSER OUT CHECK THE THERMISTORS.. YOU COULD ALSO GO INTO THE SERVICE MODE VIA CLEAR ALL THEN 107 AND HOLD DOWN THE RED STOP BUTTON TILL THE SCREEN CHANGES IF YOU LOOK FOR COPIER SP IN THE FEED SECTION THE FUSER SETTINGS ARE THERE YOU CAN OPEN FUSING TEMP AND CHECK THE TEMPS AT THE TIME TO SEE IF THEY ARE RIGHT.. IF IT SEEMS RIGHT IT MIGHT HAVE BEEN A READ ERROR AND BY GOING INTO MODE AND LOOKING FOR 5- 810 YOU CAN RESET THE SC TURN OFF AND THEN BACK ON IT SHOULD CLEAR... GOOOD LUCK A
Posted on Jun 26, 2009
SOURCE: I am getting an error code SC 534 on my Ricoh
The best I can find is that this is related to a malfunctioning cooling fan, I cannot find that specific code for your model, but all other 534 codes from that manufacturer are related to cooling fans
B010/B188 SC 534 Right fusing pressure motor HP error 1 - HP sensor defective
B010/B188 SC 534 Right fusing pressure motor HP error 1 - IOB defective
B010/B188 SC 534 Right fusing pressure motor HP error 1 - Motor defective
B010/B188 SC 534 Right fusing pressure motor HP error 1 - motor drive bound
B132/B200 SC 534 Duplex exhaust fan error - Paper exit fan motor M28 defective, indexed as 146, electrical component layout.
B132/B200 SC 534 Duplex exhaust fan error - check and or replace fusing exhaust fan / paper blocking fan
B132/B200 SC 534 Duplex exhaust fan error - replace duplex fan motors M29 or M30
B222/B224/G878 SC 534 2nd duct fan error - replace fan motor
B230/B237 SC 534 Fusing exit sensor fan error, BICU defective
B230/B237 SC 534 Fusing exit sensor fan error, Fan defective
D014/D015 SC 534 Duplex unit fan error - Fuser exhaust fan blocked or has paper in it.
D014/D015 SC 534 Duplex unit fan error - Duplex Unit fan obstructed
D014/D015 SC 534 Duplex unit fan error - Fan harness disconnected or damaged
D014/D015 SC 534 Duplex unit fan error - Fuser unit connector has paper obstruction
D014/D015 SC 534 Duplex unit fan error - Replace duplex fan
D023/D025 SC 534 Second duct fan error - replace the 2nd duct motor
D023/D025 SC 534 Second duct fan error - replace the IOB
D027/D029 SC 534 Second duct fan error - check connections and harness to fan
D027/D029 SC 534 Second duct fan error - replace fan motor
D037/D038/D041 SC 534 Fusing rear fan error: Check or replace harness
D037/D038/D041 SC 534 Fusing rear fan error: Replace BCU board
D037/D038/D041 SC 534 Fusing rear fan error: Replace fusing rear fan
D037/D038/D041 SC 534 Fusing rear fan error: Replace the DRB
Posted on Aug 05, 2009
Ricoh mp 1600 error 194 ricoh mp 1600 error code 194 how do I solve the problem
Having problems finding your error code. Here is a complete list of all codes for your printer: http://www.printcopy.info/?l=en&mod=free&chap=erc&brand=Ricoh&model=Aficio%20MP1600
I do find the error code for a different Ricoh model (Aficio 1018).
http://printcopy.info/?l=en&mod=free&chap=erc&brand=Ricoh&model=Aficio%201018
Please verify your model number and error code.
Apr 21, 2015 | Ricoh Aficio Mp-1600 Copier
RICOH MP4500 SC 390 DISPLAYS WHAT TO DO
Hello.
That error is related to TD sensor error.
I advise you to call a trained Technician
Mar 16, 2015 | Ricoh Savin Lanier Genuine Toner Type Mp...
Turn Machine off then on.
If it doesnt work press on keypad [*107 Clear] then press System SP. then turn Off the On.
Mar 29, 2014 | Ricoh Aficio 1035 Copier
The 7,010.43 error code indicates the printer is having difficulty tilting the printhead forward from the parked position to the print position. There are several printer systems involved in tilting the printhead so troubleshooting the error can be challenging. The printer does not directly sense the printhead's tilting position. Instead it applies drive current to the process drive motor, and monitors the motion of the motor's rotation encoder for "following error". For a particular drive voltage the encoder should rotate at a particular rate as the printhead (driven thru the process drive, the DM camshaft, and the head tilt gear train) tilts forward. If the printer does not see the expected encoder readings it assumes a tilt failure.
for more hrlp visit CBR Tech Solutions
Mar 30, 2012 | Ricoh Aficio Office Equipment & Supplies
Problem with the Ricoh mp c2800 Ricoh error code sc 672,
If the model ia a MPC 2800 it a controller board issue maybe the operation panel. -carl
Nov 15, 2010 | Ricoh Aficio 1035 Copier
Mar 26, 2009 | Ricoh Aficio MP1600SPF Copier
The copier is a Ricoh Afcio 350
SC 326: Laser synchronization detector board cannot receive the laser beam.
Replace the laser sync detector, Part No. A2935310.
Or try the following solution;
Open the front cover and remove the brown inner cover - 2 screws.
The black unit after the inner cover is the laser unit. There are 2 screws securing the laser unit - loosen them.
Tighten the right securing screw while jacking up the right side of the laser unit with a screwdriver.
Tighten the left securing screw and put the inner cover back on.
If SC 326 is still indicated after the above procedure, replace the laser sync detector or the whole laser unit.
Good luck and please rate me, thanks.
Apr 05, 2008 | Ricoh Aficio 450 Copier
104 people viewed this question
Top Ricoh Office Equipment & Supplies Experts
OfficeServiceAjnc
OfficeServiceAjnc
fares
Level 1 Expert
CheckitRight
CheckitRight
Are you a Ricoh Office Equipment and Supply Expert? Answer questions, earn points and help others
