Question about Kelvinator Refrigerators
Kelvinator stove with F1 code coming up
Mod# 539750-1 failure code F1 what would be a wrong ?
  • Marlene Inglis
    Marlene Inglis Mar 29, 2014
    what would this code mean F1? The oven door locked and will not open
  • 383 Answers
If it is not opening, Safety Feature is causing it to not open. Better, contact Authorized Service Center.
Posted on Mar 29, 2014
What does an F-1 code mean on the display? washer will not start.
power problem
  • Whirlpool Fault Codes - AppliancePartsPros.com www.appliancepartspros.com > Appliance Repair Whirlpool Range / Stove / Oven Fault Codes: Failure Code: Fault Code Description: Solution: 4 Digit Failure Codes (for 2 digit codes see below) F1 - E0
  • Washer Diagnostic& Repair - F1 Error Code power supply ... www.youtube.com/watch?v=BAVS9mI3JLQ
    • BY APPLIANCEVIDEO.COM
    • 4 MIN
    • 65K VIEWS
    2014-02-07 · Troubleshoot your trusty Whirlpool Top Load Washer that has these following symptoms: F1 Error Code At: http://www.appliancevideo.com To ...
  • Whirlpool Cabrio f1 error and how to fix it https://whirlpoolcabriof1error.wordpress.com Control board W10189966 will work with the Whirlpool model numbers listed at the bottom of this page. These models include the Maytag Bravos and Kenmore Oasis.
  • whirlpool F1 code - Appliance Repair Forum forum.appliancepartspros.com > ... > Washer Repair
    • 68 POSTS
    • FIRST POST: 2008-07-28
    2009-09-29 · Discuss whirlpool F1 code in Washer Repair. "whirlpool cabrio washing machine displays f1 code. have already pushed cancel and restart to no avail.
  • Cabrio Washer by Whirlpool F1 Error Code - Facebook www.facebook.com/CabrioWasherByWhirlpoolF1ErrorCode Cabrio Washer by Whirlpool F1 Error Code. 793 likes. Got the F1 Error Code? Tell your story! Share ALL your issues with this washer to warn others...
  • Whirlpool Fault Codes - Appliance Help Online appliancehelponline.com/whirlpool.html Whirlpool Range / Stove / Oven Fault Codes: Failure Code: Fault Code Description: Solution: 4 Digit Failure Codes (for 2 digit codes see below) F1 - E0
  • May 04, 2016 | Whirlpool WTW8200YW Cabrio Top Load Washer
    Error code F1 F3 F6
    KitchenAid Fault Codes - AppliancePartsPros.com
    www.appliancepartspros.com/repair-help/kitchenaid-fault-codes.html
    Jump to Kitchen Aid Range / Stove / Oven Fault Codes - Failure Code, Fault CodeDescription, Solution ... F1 - E6, Latch signal mismatch error ... F3 - E0, Oventemperature ... electronic control will display F6 ...
    Jan 27, 2016 | Kitchen Ranges
    What des error cde F1 mean on a Jenn-Air D156 drp-in range
    JENN-AIR
    'Newer Style' Range/Stove/Oven Fault Codes Failure
    Code
    Condition Check/Repair F1 Power to element relay energized during time of day display Wiring harness shorted or change power relay board (PRB)
    Note: for double ovens, change second oven board
    JENN AIR
    Code
    Condition Check/Repair F1 Defective touch pad or membrane Replace touch pad or membrane (this problem is usually the touch pad)
    Mar 22, 2010 | Food Processors
    What does F1 fault code mean?
    Whirlpool Range / Stove / Oven Fault Codes Failure Code Fault Code Description Solution 4 Digit Failure Codes (for 2 digit codes see below) F1 - E0 EEPROM communication error 1. Disconnect power for at least 30 seconds.
    2. Re-apply power and observe for at least one minute.
    3. If code re-appears, replace control board (also called ERC or clock).
    Note: Applies to all F1-E... codes except F1-E3. F1 - E1 EEPROM checksum error F1 - E2 UL A/D error(s) F1 - E4 Model ID error F1 - E5 Calibration shifted F1 - E6 Latch signal mismatch error F1 - E9 Stack overflow F1 - E3 Wiring harness cavity size does not match previously stored value The "Cavity Size Select" jumpers in the wiring harness indicate a cavity size different from that which the control was previously configured for. Check the jumpers in the harness to make sure they agree with the actual oven size.
    Jan 08, 2010 | Kitchen Ranges
    Frigidaire Mod.FEF369CGTE, F1 and now getting F9 please help
    Hi n5my ,
    F1 =  Electronic oven control failure
    Sol. Replace electronic oven control (also called EOC or clock).
    The "F9" error code means the EOC (electronic oven control) has found the lock motor switches to be out of sequence or shorted.
    Test switches and if there is nothing wrong then replace the EOC.
    both of the error indicates the problem in EOC.
    Regards
    R.K.
    Oct 16, 2009 | GE Spectra JBP78 Electric Kitchen Range
    Getting error F1 on digital display
    F1 Board failure Replace control board (also called ERC or clock).
    Mar 20, 2009 | Ovens
    F1 Failure , need to know how to advance the clean timer to get unit to unlock
    Hello welcome to fixya,
    Below I pasted the fault codes for the two different years of this range.
    To diagnose these difference you will need a hands on tech !
    this is not an easy thing to determine
    JENN AIR
    Failure
    Code
    JENN-AIR
    Failure
    Code
    Dec 08, 2008 | Jenn-Air SVE47100 Slide-In Electric...
    Stove beeping
    You have a fault in the range electrical system
    FRIGIDAIRE
    Range/Stove/Oven Fault Codes Version 3 Failure
    Code
    Condition Check/Repair F0 & F1 EOC (Electronic Oven Control) failure Replace EOC (Electronic Oven Control)
    Jun 04, 2008 | Frigidaire FEF376 Electric Kitchen Range
    F1 and F2
    Here are the codes for Tappan ranges:
    TAPPAN
    Code
    Condition Check/Repair F0 & F1 EOC (Electronic Oven Control) failure Replace Electronic Oven Control F2 Oven too hot Check Bake function, if OK, replace oven temperature sensor F3 Oven temperature sensor open Check oven temperature sensor, should be ~1100 ohms at room temperature. If too high or low, replace oven temperature sensor F4 Oven temperature sensor shorted Replace oven temperature sensor F5, 6, 7 EOC (Electronic Oven Control) failure Replace Electronic Oven Control F8 Lock switches Check switches and replace if necessary
    Nov 06, 2007 | Tappan TGF363 Gas Kitchen Range
    Refrigerators Logo
    96 people viewed this question
    Top Kelvinator Refrigerators Experts
    Charles T Nevin
    Charles T Nevin
    Melissa Martin
    Melissa Martin
    Are you a Kelvinator Refrigerator Expert? Answer questions, earn points and help others
