Complete cover or fascia for vulcan quasar wall Heater console model
New or second hand cover
  • 383 Answers
Contact Authorized Service Center or Authorized Dealer.
Posted on Mar 29, 2014
SOURCE: Pilot light won't stay lit
Look for dust and lint. Look for them in places where gas should be freely flowing. I had a similar problem with an Empire Corcho wall-mounted propane ceramic catalyst heater. First it was the pilot light, then the #2 ceramic mantle. After horsing around with the gas lines and pressure regulators and trying to re-aim the pilot, it all turned out to be dust and lint in the gas passages. A little dust bunny in the brass pilot tube gave me a pilot light the shape and color of a banana. One puff of compressed air, and I got back my razor-sharp pilot. And some dust in the chimney of the #2 burner kept it burning blue/yellow and blistering paint off the upper surfaces of the heater. A bit of cleaning with a shop-vac put that right. "Passive" heaters are very much prone to this sort of problem because they rely on convection currents (i.e. LOW velocity) to get the job done. Convection currents are notorious dust collectors, as in COBWEB CITY.
Posted on Feb 28, 2009
SOURCE: need fan for vulcan gas wall heater serial no. 1003129019
found a supplier using the Google search engine. Thanks any way.
Posted on May 15, 2009
  • 53 Answers
SOURCE: Vulcan Quasar 40 wall furnace - electronic display problem
Have a gasfitter bypass the clock. The clock is the source of the problem. You will then have a manually operated heater.
Posted on Oct 08, 2009
SOURCE: Noisy pilot light Vulcan Quasar 40
Simply clean out the jet tube with a fine wire, the sound you hear is the gas blowing by the irregular edges, and swirling and not mixing and producing sound waves, (Bit like a flute) So, you need to clean the tube right out, and smooth off the end again, & sorta "Countersink", Flame the end too, at the end.use a very fine needle file, and make it look like new, that will sort your problem out. Then adjust so you have a good gas flow. Also check out it isn't blocked too.
Posted on Apr 30, 2010
  • 674 Answers
SOURCE: pilot on, gas fires up, no fan comes on.
Sounds like you are talking about the indoor fan that circulates air through house. Turn the unit off and make sure the fan rotates freely. Next check the capacitor for the fan. If it looks swollen its probably bad. If it doesn't look swollen then you will need a multimeter to check it with. If that's ok then check the fan relay. Let me know what you find.
Posted on May 30, 2010
My father has to replaxce an 11 year old Vulcan Wall Furnace. He wants a Braemar Wall Furnace. He must tell Braemar what model his Vulcan is - there aren't any model badges. Can he determine if his...
Usually these numbers on most other untits are stamped on a metal plate which is located
or attached to the gas valve, which would also give the BTU Input/Output. Probably the
Model Number as well
Sep 01, 2011 | Heating & Cooling
Vulcan quasar elite heater 2400w, trying to find operating instructions
May I get the model # so I can get you the right manual
Jun 20, 2010 | Heating & Cooling
Apr 30, 2010 | Cozy Enclosed Front Console Heater 20,000...
Oct 05, 2009 | Heating & Cooling
Vulcan Quasar 40 air issue
Hi the problem you have is your heater is cutting out due to the over temp switch getting to hot the reason for this is that your fan is not working thus not enough air flow is getting through the heat exchanger to keep it cool
your heater is designed to not exceed a certain temprature so as not to become a fire risk
to solve your problem you will need to replace your fan
this will solves your problem
Jul 27, 2009 | Heating & Cooling
Where to get vulcan gas heater spare parts?
Google vulcan gas heater spare needed it will find it for you
Jul 09, 2009 | Vulcan AUW230A Heater
Hi there, I have a Vulcan Gas Wall Furnace Heater 26.4. Would you please tell me where I can get manual book or how to use it. Thanks! Paul
Hi
Please see this link to view/download the manual fro your heater---
Vulcan Gas Wall Furnance Heater
Please accept this solution and ask for any assistance.
Thanks
Rylee
Mar 29, 2009 | Vulcan Heating & Cooling
I have a vulcan quasar wall furnace. the fan no longer works
Perhaps the fan motor is bad. If not, you have an electrical problem.
Jul 23, 2008 | Heating & Cooling
Heating & Cooling Logo
59 people viewed this question
Top Heating & Cooling Experts
paulcarew
Dan Webster
Dan Webster
Donni Steen
