Question about Samsung PN50C450B1DXZA 50-inch Class Television 720p Plasma HDTV
Samsung overheating and melting frame
Overheating
  • 383 Answers
BEWARE : STOP USING THIS TV RIGHT NOW AND CALL CUSTOMER SERVICE ENGINEER. IT MAY BE A SERIOUS PROBLEM IGNORING WHICH MAY BE HAZARDOUS TO YOU. TURN THE TV OFF, SWITCH IT OFF FROM THE WALL SOCKET (MAINS) AND UNPLUG IT FROM THE SOCKET. CONTACT SERVICE ENGINEER AS SOON AS POSSIBLE.
Posted on Mar 29, 2014
  • Kelty Richardson
    Kelty Richardson Aug 18, 2014
    My TV of this exact model experienced this problem (melted frame) and just died. I called Samsung support and they had never heard of this problem. How did you know about this problem?
Overheating dishwasher samsung
What do you mean "overheating"? Are you getting an error code that indicates it's overheating, or are all of your plastic dishes inside the dishwasher melting? If that's the case, then you have a bad controller, one in which the heater relay is stuck on, and you will have to replace the electronic controller.
Mar 07, 2015 | Samsung Dishwashers
My rectifier wires are overheating and melting this happens when the bike runs for just a few seconds any answers why
check if connections are corroded. is battery ok, some earth out when need replacing. are earths ok, esp the battery to frame. is the rectifier giving out 2 positive 12v wires as it should .. 1 to battery one to system..if that dont sort it give this ago ( your need a volt meter) http://www.electrosport.com/media/pdf/fault-finding-diagram.pdf
Feb 17, 2013 | Motorcycles
When I replaved samsung hls6767w lamp with hosing with new lamp with hosing I noticed burning smell.I assumed it is new lamp buring smell. After 15 mnts when smell did not go I removed power and when...
Most of the time the female end of the connector comes right of a part called the ballast. Ballast's are replacable. Is the aluminum melted? I am not sure where to purchase the ballast. The female connectors is ussally atached to frame with screws or sometimes clips
May 27, 2011 | Samsung HL-S6767W DLP TV
The wall seperating the fridge and freezer is overheating. The face of the wall is about 139 degrees F. The rest of the the fridge is just fine.
Hi there
There is a trace heater in the frame of the unit to prevent ice build up, this seems a little warm but I don;t think its a problem. Sometimes in manufacture the heater is a bit closer to the frame than it needs to be.
If there is no discoloration of the frame then I think it is nothing to worry about
Regards
Gordon
Apr 25, 2011 | Samsung RS2630SH Side by Side Refrigerator
My samsung home theater system HT-Q100 cut off shortly after I turn it on.could it be a power supply problem ?
Yes it could be .., overheating is a killer in audio equipment depending in usage of unit. The audio amps of the board may be melting slowly, but fuses may do that too before they give out
Jun 29, 2010 | Samsung HT-Q100 System
Shows a message error opening overheating....the printer is brand new
Warranty should cover that problem for you, but when that happens you need a new fuser assembly and also the power supply PCB, or it will just melt the new fuser again.
Oct 02, 2009 | Samsung SCX 4521F All-In-One Laser Printer
The top of screen frame has melted
Yes i would agree with you not turning it on, Fire is a risk here. I would isolate it from its power source altogether and have someone take a look at it at the earliest. I suspect one of the caps or several of them have overheated on the power board which is located near the top of the surround.
Please rate our help++++Thanks for usinjg FIXYA
Sep 25, 2009 | LG 32LG40 32 in. LCD HDTV
Fuser unit overheat problem
i want to install samsung ml 1610 printer on window vista but i have not driver
Apr 30, 2008 | Samsung ML 1610 Laser Printer
Samsung PN50C450B1DXZA 50-inch Class Television 720p Plasma HDTV Logo
260 people viewed this question
Henry  Thomas
Henry Thomas
