Question about Karcher Garden
The hose keeps popping out when you put the water on
K4.68 hose keeps popping out
    Cheetah:
    An expert who has answered 20 or more questions within one hour.
  • 165 Answers
The house end or the high pressure end?
Posted on Apr 21, 2014
How do i fix leaking water at thermostat housing?
If your thermostat housing is pitted and corroded it might be time to purchase a replacement housing. If your hose clamp is worn out, it might be time for a replacement. If the bolt holes are worn out, it might be time for new bolts and heli-coils in the intake. If none of these are the problem....I would think that a thorough cleaning of all surfaces and a thin bead of silicone on each side of a clean dry gasket would work.
Jun 23, 2015 | Cars & Trucks
Hose keeps popping out of hansgrohe shower panel
that must be because the water pressure coming out of the hansgrohe has loosen the area that holds hose. If its not a problem you can change what holds the hose for a newer one so that the hose is tighter
Aug 15, 2013 | Home
The control panel is not working the water keeps filling up
This is called your water fill diaphram. Or your water level select. Replace it and you have fixed the problem. You might want to check the hose for holes or to see if the hose popped off the switch. The same thing happened to my cousin. Good luck!
Aug 20, 2010 | Whirlpool LSR7333 Top Load Washer
Im am not getting any heat either in manual or automatic. I took the hoses of the core and was able to blow air through (there was anti-freeze present). I ran the engine (hot) and no water came out...
i have a 1998 olds intrigue and had the same problem. In my case i had to pop on of the hoses off from the water put with the other hose still connected. I took a high presssure car wash sprayer on the rinse mode NO SOAP. Put the sprayer into the one hose about 1 min, then put that hose back on the water pump and did the same with the other heater hose. This completly solved my problem. You have prolly got a clog in ur heater core as I did. Just make sure no 1 sees u at the car wash doing this cuz it a major D.E.C no no, But sure to fix a clog a simple house hold garden hose will not work u need a high pressure water hose and a car wash is cheap and effective.
Jan 02, 2010 | 1998 Oldsmobile Intrigue
Loud pop, now circut breaker flips off when I turn on the machine
HI
A loud pop can be a couple of things. Usually it is a ruptured hose, or a hose the has separated from its keeper.. This can explain why it is you are popping the circuit breaker. Water is spraying on an electrical circuit, and causing the short. The other thing that pops is when you blow the circuit board but then you would have a burnt smell.
Oct 14, 2009 | Starbucks Saeco Italia Digital Barista...
Hose keeps popping off of sunheater panel
Panel is most likely creating too much back pressure for the pump. The solar panel creates a major restriction in the flow of water, which is why the hose keeps poping. You can try a couple of thing,
1. The panel should be installed after the filter. Sequence should be Pump to filter to panel to pool.
2. Install a longer hose from filter to panel, will reduce pressure. Or install a diverter valve which you can control the amount of water going to the panel, sending some straight to the pool.
3. If you roof mounted the panel and it goes from the Pump to filter to a booster pump to solar panel, you will need to install a check valve to reduce the back pressure.
Jul 04, 2009 | Smartpool Sunheater - Above Ground Pool -...
Water line to freezer pops out when water is delivered.
try putting a small one way valve at the end of the line so it wont back up. or put more insulation around the hoses
Jun 06, 2009 | Frigidaire Freezers
We keep getting holes in our clothes when we use this washer
For low water volume - or "Trickling" effect...
1. Turn off the water supply to both hoses.
2. Remove hoses (one at a time so you don't get them confused)
3. On the washer side - look for a removeable screen inside wher you just removed the hose.
4. Using a small screwdriver - pop out the screen and reverse-flush it/clean it. It will likely be full of sediment and calcium deposits from your pipes.
5. Replace the inlet screens.
6. Re-fit the hose to the machine.
7. Turn on water supply valves.
8. re-try.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
Mar 15, 2009 | Kenmore 46462 Front Load Washer
Turbo hose popping off when driving
Clean the hose and connecting area with an agent to remove all oil (accetone may work), then put hose back on and ensure bolts are torqed to spec (F250 about 9FTLBS).
Jul 04, 2008 | 2006 Ford F-250 Super Duty
Water keeps going and going and going!
the water is draining back to the ocean. The drain hose was not emptied properly from its last use. Put the machine in spin cycle (about 5 minutes) only to spin out the water from the outer tub completely and retry washer. If still problem, then visual check drain hose that it still has a "rising" section higher in altitude than the water level of inner tub (when working properly) before it makes a U-turn downward to send back to the ocean. You can also test the drain hose by putting machine in fill mode and crimping off the hose (fold hose over) to simulate a good drain hose. At this test, you should not "feel" water running through the hose if successfully crimped.
Jun 21, 2007 | Estate TAWS800JQ Top Load Washer
Garden Logo
97 people viewed this question
Top Karcher Garden Experts
John Trevino
andy just round the...
Level 1 Expert
Are you a Karcher Garden Expert? Answer questions, earn points and help others
