Question about Kitchen Appliances - Others
One of the stove plates on the mini oven do not heat up
Sunbeam electric oven with double hot plates. Model: SCO-300B. One of the hot plates do not heat up when switched on. How do I fix it?
  • Tammy Burger
    Tammy Burger Mar 29, 2014
    To be more specific, it is the left hot plate. The light indicating that the hot plate is on does not work either. I was cooking with the left plate one day and the lid of my pot struck the base of the pot which caused a spark. Since that happened the hot plate stopped working.
  • 383 Answers
BEWARE : STOP USING IT RIGHT NOW AND CONTACT AUTHORIZED SERVICE CENTER AND DO NOT TRY ANYTHING WITH THIS MACHINE YOURSELF. IF YOU CONTINUE USING IT, IT MAYBE HAZARDOUS AS IT'S AN ELECTRIC EQUIPMENT.
Posted on Mar 29, 2014
Oven will not heat past 195 degrees
Check and see if you have blown a fuse which is usually in the top of the stove in the area of the clock if you have one. You usually can get in from the back of the stove at the top.
Jan 03, 2015 | Maytag Gemini 30" Self-Cleaning...
What is a Laboratory Hot Plate?
Wikipedia says: A hot plate is a portable self-contained tabletop small appliance that features one, two or more gas burners or electric heating elements. A hot plate can be used as a stand alone appliance, but is often used as a substitute for one of the burners from an oven range or the cook top of a stove. Hot plates are often used for food preparation, generally in locations where a full kitchen stove would not be convenient or practical, as hot plates are easily moved from one location to another.
May 01, 2013 | Science & Laboratory
When using grill knobs get to hot to turn stoves 600 sidl
you are missing the heate plate that stops the knobs from getting hot go to ebay and put your model in and look for heate plate or some thing like that
Oct 12, 2012 | Ovens
Got stoves double oven, oven not heating up
If your electric oven is taking too long to heat or just not heating up right,then check out this tip that will give more detail about your problem.
Oven Problems Electric Oven is Heating Slowly or Poorly
heatman101 =-
May 08, 2011 | Stoves Newhome ECH600MXa Electric Kitchen...
Main oven not heating up , fan running ,temp light on but no heat
I suspect that the oven element has failed, to check this, remove cover at rear of oven compartment, there you will see the round oven element, it should feel hot after turning oven on to heat, if it is cold, replace it.
Feb 28, 2011 | Stoves 720EF Electric Double Oven
Fan in oven sticking and only intermittently working
The fan plate is held on by four self tapping screws, which are fairly easy to remove. It will all be rather greasy and the grease runs down the inside of the fan plate and congeals and could possible restrict the fan. Take the fan plate off and just soak it in hot washing up water. if this does not work get the paste on oven cleaner from Lakeland and give that a go. It works! (You can use this all over the inside of the oven to clean it)
Aug 08, 2009 | Stoves 720EF Electric Double Oven
Electric Diagram for Kenmore Model 790
Has the oven run out of control or gotten too hot? The 790 series is made by Frigidaire and those fault codes are F0 to F8. F2 indicates the temperature sensor is reading too hot. Now with the double oven models, some manufactures add an extra digit to the fault codes to indicate which oven created the fault.
Your most likely fix is to replace the temperature sensor. The most probable locations for the wiring diagram is taped inside the bottom drawer, on the back or under side of the oven, or behind one of the panels on the back of the oven. This might tell you the room temperature resistance for the temperature sensor so you can test it with an ohmmeter and be sure that it is faulty. Try Appliance Parts Pros for replacement sensors.
Jan 09, 2009 | Kenmore 40494 / 40495 / 40499 Electric...
Chambers parts
need a part for a cambers electric cooktop model # AT-33-A
Jun 13, 2008 | Kitchen Ranges
Neff model U1461
your convection element has blown by one online and replace it yourself
May 25, 2008 | Neff U1461 Double circotherm plus Electric...
Kitchen Appliances - Others Logo
53 people viewed this question
Top Kitchen Appliances - Others Experts
Angel Joseph Jr.
Angel Joseph Jr.
Are you a Kitchen Appliances - Other Expert? Answer questions, earn points and help others
