Question about Whirlpool Washing Machines
ERR code I have a Whirlpool AWSX63213 washing machine. Before beginning the drying spinning and at the end of spinning (2 minutes befor the end of program) it displays a Err mesage insted of the remaning time counter. Now it stuck in a program (hearing the water and it spins about 1/4 o a cycle and then stops, but the reming timer is counting down). How can I do a "factory reset" for this model? Besides unplugging the power is there a secret key combination? Thank you.
    Master:
  • Whirlpool Master
  • 753 Answers
Inside the machine is the tech sheet with all the info you need. It maybe just under the top or down along one of the sides but it is in there
Posted on Mar 30, 2014
  • 298 Answers
SOURCE: Washer will not spin; displays nd error
(nd) stands for no drain check the pump,and drain hose
for clogs
Posted on Dec 24, 2007
kakee
  • 1269 Answers
SOURCE: Whirlpool AWM 6145/3 gets stuck
That's a timer problem. Check on the user's manual on how to reset the timer settings. The timer can be replace if found defective but you need a pro technician to do it.
Posted on Aug 29, 2008
futureloginn
  • 734 Answers
SOURCE: Whirlpool AWO3761 stuck mid-cycle
The cycle doesn't advanceWhen the cycle doesn't advance, it's probably the timer or a cold-water supply problem:
  • It's the timer, if your washing machine fills with water and begins agitating, but the timer never advances--or if the washer is in a spin cycle and the timer won't advance. Then you need to replace the timer.
  • It may be a cold-water supply problem, if the washing machine fills with water, agitates, drains, and spins, but then doesn't fill with rinse water. See There's no cold water.
  • Posted on Dec 10, 2008
    • 107 Answers
    SOURCE: Whirlpool washing machine (model LLR 9245 B) does not work
    If it's a top loader, the coupler is broken. It's located between the motor and the gearcase. If you put it in spin and hear the motor run, this is your problem. It drains because the pump is mounted on the opposite side of the coupler and will be un-affected
    Posted on Mar 25, 2009
    ghost4548
    • 776 Answers
    SOURCE: nec nw-891 washing machine will not complete the programmed cycle
    Apparent malfunction in the timer circuits. Specific Component replacement not available.
    Posted on Jun 30, 2009
    Model SM8280867. Why does it fill, then spin without washing?
    1.try to unplug your unit then wait for 5 minutes
    2.plug back your unit
    3.program back your unit and start
    Sep 05, 2015 | Whirlpool Washing Machines
    How do I dry only
    When using the WD-1000 as a Dryer only, are you turning the rightmost knob Clockwise to the correct starting point?
    Looking at the periphery of the knob, at the bottom, see the elongated "sausage" shape, outlined in blue? Turn the knob so it passes "Stop", and points there.
    At the end of a completed Wash Cycle, that is where the pointer will be pointing. Once there, the machine switches automatically to Dryer Mode.
    As long as the middle dial is set to a timer length greater than zero, the drying begins. I recommend turning the middle dial to somewhere around 2:00 o'clock, which corresponds to about 90 minutes if I remember correctly.
    (You'll notice that is in the "Orange" area, meaning Full Heat - which is always fine because it never gets too hot anyway)
    So, turn right dial to point to the "white sausage" at the bottom of the dial; Turn middle dial to 90 mins, or so; (Left dial only controls "Spin" speed - just set to max); and close the door. (It should begin drying)
    Feb 14, 2015 | Malber WD1000 Front Load Washer/Dryer
    Whirlpool WFW9050XW Washer Front Load
    Disconnect your mains from the wall and clean out your filter.
    Pl click if helped.
    Apr 28, 2013 | Whirlpool Washing Machines
    Its a whirlpool 6th sense washing machine no awd/d 5706, it stopped with a full load in 8 minutes before end time no numbers are flashing up but it wont do anything , i have opened the door took washing...
    i have a whirpool 6th sense washing machine and it wont spin and the timer stays on 14 minutes remaining have you come across this problem and do you have a cure
    Jul 29, 2010 | Whirlpool Washing Machines
    End of wash cycle (last 2 minutes,) F code, no spin & drain
    If your getting an FdL or F11 (and possibly others) code the problem is more than likely the CCU. The CCU is a circuit board at the inside top back of the machine. The board has quality issues in that it is prone to cold solder joints at the spot where the relays and the spade connectors for external connections meet the circuit board. The repair is to remove the board and touch-up those solder joints.
    Jul 06, 2010 | Whirlpool GHW9400 Front Load Washer
    Washer spin and not enough water
    Spinning both ways is pretty normal. You did not say if your clothes were clean in the end. You may not see much water when it washes, when it rinses you may see about 1/3 thru the glass. Careful with the door aft wash, wait for 2 minutes before opening.
    Feb 28, 2009 | Washing Machines
  • Jul 06, 2008 | Whirlpool AWM6100 Front Load Washer
    Washer won't spin
    ckd fill hoses be sure hot and cold are full on ck screens at washer end of hoses in inlet valve are they clean?
    Apr 20, 2008 | Whirlpool Duet GHW9150P Front Load Washer
    Whirlpool washer problem
    run the waher in a high spin and lift the lid repeat this three or four times and your brakes will free up and begin working again
    Feb 18, 2008 | Whirlpool Ultimate Care II LSQ9549L Top...
    Open Questions:
    Washing Machines Logo
    148 people viewed this question
    Sal De
    Gerry Harvey
    Gerry Harvey
