Question about Lego Creator Revvin' Riders, Motorcycles and ATVs
Yamaha 660 grizzly runs hot radiator clean,theremostate replaced
Use these machine to soilsample it will run 30 to 40 min,before it gets hot
  • 142 Answers
Make sure the quad has the updated side panels, the have vent cut outs in them, these were recalled for over heating issues from not enough air flow
Posted on Sep 27, 2009
  • 87 Answers
First pressure clean rad check fan sensors an run a bottle o vinegar in rad for a while
Posted on Aug 05, 2009
  • 50 Answers
If it is liquid cooled you would need to more coolent in the radiator coolent. But if is air it takes longer and get hot quicker.
Posted on Jul 01, 2009
My Kipor KDE16STA3 shows p03 error after 15 min runing and shuts down after 3 sec.The voltage drops to 30,40 whta's happening?
[PDF]DIESEL GENERATING SET
www.kipor.com/upload/spec2011053011590766.pdf
3/KDE16STA3/ ..... P-03 Undervoltage: Indicating voltage higher (lower), the generator will self- braking. P-04 Generator ... KDE16STA3 KDE19STA KDE19STA3.
[PDF]2
www.kipor.com/upload/spec2011061109073968.pdf
P-03. Decrease load less than the related load, turn on the breaker. P-04. Replace the fuse of the same type. Check the circuit and inserter. Replace the starting ...
Oct 31, 2015 | Kipor Electrical Supplies
Why would my 660 grizzly pop in & out of forward gear, jus whines, jumpin in & Out ???
Grizzly 660 Shifting problem. - Yamaha Grizzly ATV Forum
www.grizzlycentral.com > ... > Grizzly Engine & TransmissionMar 12, 2012 - 4 posts This is a discussion on Grizzly 660 Shifting problem. within the Grizzly Engine ....2005 grizzly 660 gear position sensor problem.
Aug 17, 2015 | Yamaha 2005 Grizzly 660 Auto 4x4
How long does the 55 degree normally run for
Depends on the water temp going into the machine. Dishwashers should be connected to cold water. Some people fit to hot water but the machine will go through the cycle too fast and you wont get a decent wash result. 55 isn't superhot for a machine (I assume this is 55 celcius?) Most machines will take about 45 mins to an hour.
Jan 03, 2015 | Dishwashers
I have a 660 Grizzly 03 Atv im having a idle problem i have not did any repairs on this bike the idle will set its self down to low and quit running i set the idle up to normal and in a few moments of...
1. Check the INTAKE valve clearance!!!!
2. Check for an air leak
3. Install a new spark plug and air filter!!
4. Check the compression..
5. Have the carb professionally cleaned and set!!
>> Once you have sone all these steps.. repost to me if this did not fix it!!
Sep 07, 2017 | Yamaha 2004 Grizzly 660 Auto 4x4
Overheating, new pump,new coolant,new oil. And rad is clean !! Im stumped
General advice: Check that the thermostat is working and not stuck closed or open. Then make sure you have all the air out of the radiator. Also make sure the radiator fan is plugged in and working properly.
Sep 15, 2013 | Yamaha 2005 Grizzly 660 Auto 4x4
Backfires when you try to rev up engine,
check fuel flow and check spark at spark plugs
According to an "ATV Rider" 2009 article, "When the Grizzly was introduced in 1998 as a 600cc machine, the top was blown right off the displacement wars of the time."
It was replaced in 2002 with Yamaha Grizzly 660, an even bigger engine derived from the well-established all-terrain vehicle (ATV) Yamaha Raptor 660R.
Grizzly's 660 cubic centimeter (cc), four-stroke, liquid-cooled single overhead camshaft, five-valve engine performs well in open country, but sometimes it causes serious problems for owners.
Before you call a Grizzly dealer, however, trying a few tricks in your garage can save you a lot of time and money.
Check the fuel level.
Locate the fuel meter indicator on top of the multifunction display.
If it does not work properly, open the fuel tank, and push the Yamaha 660 Grizzly side to side.
Ensure the fuel is not contaminated by water or rust.
If you have not driven your Grizzly 660 for a long time, drain the tank completely, and fill it with a fuel tank cleaner.
Check fuel hoses for cracks or leakage.
The hoses should be soft and simple to bend.
Replace those that show any sign of wear.
Screw a compression tester into the spark plug hole, and press the electric starter button.
If no compression exists, contact a Yamaha dealer.
Wipe wet or dirty electrodes with a dry cloth.
The spark plug gap should be checked regularly
Correct the spark plug gap.
Measure the gap with a wire thickness gauge.
If necessary, adjust it to 0.8mm using a screwdriver or replace the spark plug.
Use only a Yamaha-specified spark plug.
Check the Yamaha 660 Grizzly's battery.
Operate its electric starter.
If the Grizzly starts quickly, then its battery is in good condition.
If the engine turns slowly, check the battery lead connections, and you may need to change the battery.
If the engine still does not eventually start, your Grizzly is beyond home repair.
Jul 23, 2013 | Yamaha 2005 Grizzly 660 Auto 4x4
My Kipor KDE19STA3 shows lower voltage on one of three phases in control pannel and keep shutting down. Voltage is actually OK on all 3 phases, if I measure it with my voltmeter. I need to adjust measuring...
There is no way to adjust voltage on just one phase. I would check voltage sensing leads and check to see if there is a way to calibrate. Otherwise it sounds like a logic problem.
Jul 08, 2011 | Electrical Supplies
2003 yamaha grizzly 660 4x4 atv, right side rear axle/cv joint came lose at differential
Yamaha Grizzly 660 2002 2008
get one of these..If you are going to try the repair yourself....
.this is serious, ....
there MIGHT be damaged components that need to be inspected by a professional.
Mar 17, 2011 | Yamaha 2004 Grizzly 660 Auto 4x4
Car shuts off when it gets hot
your ignition coil are going bad, they need to be replaced. once the car gets hot the circuit shut down the car when hot. once they cool your riding again until they get hot. thats your problem. Good Luck
Jul 31, 2010 | 1988 Buick Electra
After the machine has been running for about 45
Have you checked the oil? many motors have an oil pressure switch. When did you last change it? if the oil gets hot and thin, there is less oil pressure. Could also be a safety switch, vibrating loose. Switch on seat maybe?
Jul 12, 2010 | Garden
Lego Creator Revvin' Riders, Motorcycles and ATVs Logo
687 people viewed this question
Top Lego Toys Experts
Marvin
Marvin
Tom Chichester
Bill Boyd
Are you a Lego Toy Expert? Answer questions, earn points and help others
