My sony hifi produce a distorted sound when in loud volume in both speakers
  • 383 Answers
Contact Sony Care if it's in warranty, else, call any Electronics Professional.
Posted on Mar 29, 2014
  • 14 Answers
SOURCE: Loud crackling / popping
Well gd stuart i think you need some new speakers
Posted on Jan 27, 2008
  • 19 Answers
SOURCE: My Philips SBP1100 speaker' volume is not loud enough
Try accessing the audio device under your 'My Computer' Devices settings on your laptop. Generally you can turn the system volume up and down for several devices, included outbound devices. While the main speaker volume on your PC speakers may be set to the max, there are other auxiliar outputs that your PC will recognize, and those may be turned down. Access your audio devices and make sure that all outputs are set to max levels, and this should solve your problem.
Michael Lazar
http://www.AudioholicBlog.com/
Posted on Oct 03, 2008
NitrusInc
  • 326 Answers
SOURCE: Distorted sound.
You can try shutting off Audio Hardware Acceleration.
Start > Control Panel > Sounds and Audio Devices > Advanced (Under Speaker Settings) > Performance.
Let us know
Good Luck
Posted on Apr 15, 2009
male_28_cam
  • 1555 Answers
SOURCE: Suddenly my speaker volume is low and scratchy
Congrats, you yourself is a good troubleshooter. Just pinpointed your problem. What you just diagnoist can be easilly checked just by taking other good known speaker. If that works your speaker is short check for audio output wires. If not your card needs replacement. If need further clarifications just comment.
Posted on Aug 04, 2009
sarasvatas
  • 329 Answers
SOURCE: There is a loud hum when volume is on low to high
go to control panel
sound and audio devices
voice
under voice recording clk volume and mute the mic phone...........
or
some how your mic is conflicting with speakers. Keep your mic away from your speakers..
Do reply if this woks
Posted on Oct 03, 2009
Marshall MB4410, with low volume gives no real volume,
Guitar amps have preamp sections (think unpowered audio mixer) and power amp sections (Crown rack-mount amp). An excellent way to isolate audio problems if amp is still producing audio is to check the preamp out (line out). Preamp output distorted = preamp failure. Connect MP3 player to "Power Amp In"...sound distorted = power amp failure. In your case the latter is the case as your "line out" is clean. Also test each speaker for clear sound as speaker cone damage from being overpowered is fairly common. At 300w. I'll assume the failure was not from cranking the volume to loud but a shorted speaker or speaker wiring could zap the power amp in an instant.
Jan 06, 2014 | Marshall MB4410 Bass Combo Amplifier
Iis there a volume control on toshiba tecra a2
If it's plugged into a external speaker system, doesn't the external speaker system have volume control? In the Tray Notification Area, right click or click on the Sound Icon, adjust volume OR open the Control Panel and select Sounds Icon. Laptop aren't known for great sound, I use this: http://www.bose.com/controller?url=/shop_online/digital_music_systems/sounddock_systems/sounddock_portable/index.jsp
Apr 11, 2013 | Toshiba Tecra A2 Notebook
The volume of my aspire note book is very low what can i do to fix it
Well, either your windows volume (normal volume control in the bottom right corner of your screen) or whatever program you're running to produce the sound (iTunes, Media Player, etc.) is probably turned down low. Check that first, otherwise, your speakers are probably dying, and need to be replaced (quite the fix).
I hope this helps!
May 04, 2011 | Acer Aspire 5610-4648 Notebook
My SONY Home Theater Model HT-6600DP unit was working fine and then about tow years after...present, my sub woofer is sounding distorted. Why is this happening? Please help me as I often watch my home...
Is it so even at lower volumes?
Are you sure it's the sub distorting and not the front or center speakers?
If you designate them incorrectly as Large (which tells the receiver they CAN effectively produce bass frequencies) they will probably distort in the presence of low frequencies.
See Page 17, 19
Register and download the manual for free at retrevo.com
http://www.retrevo.com/support/Sony-HT-6600DP-Home-Theater-Systems-manual/id/390ag319/t/2/
Mar 13, 2011 | Sony HT-6600DP System
I have a sony MP# player, same range as listed but the 8GB model. I can only turn volume up to 16 before it starts distorting and giving a really bad and weak signal though the headset, when the stereo...
Headphones are not designed to have the volume levels run at maximum. At this level the sounds from the headphones will distort.
Speakers have a much larger voice coil and therefore will not distort at higher volume levels.
Also when the speakers are connected to the MP3 player the sound level may appear lower because speakers require more energy to drive (produce sounds). In this case you need to connect powered (amplified) speakers to the MP3 player.
Mar 10, 2011 | Sony Network Walkman NWZ-S545 Digital...
Hi I have Denon 1910 7.1 avr, I bought last February 2010, the right front channel is producing some sort of sound distortion (hiss and popping sounds) when the receiver is turned on, I tried...
I SUSPECT THE CHANNEL IS BLOWN.YOU COULD TRY OPENING THE UNIT AND SEE IF THERE IS ANY GLASS FUSES.ONE MIGHT BE BLOWN.IF NO FUSES THEN TAKE IT TO A TECHNITION FOR REPAIR.THAT WILL BE YOUR ONLY OTHER OPTION.I KNOW,I HAVE HAD THIS HAPPEN TO ME.GOOD LUCK
Oct 18, 2010 | Audio Players & Recorders
My peavey CS4000 IS TRIPING IN AND OUT WHEN I TURN THE VOLUME UP IN BOTH STERO AND MONO MODE. MY IS TO 15'' 1600 watt RMS subwoofer 8 OHMS SPEAKERS
How loud? Or how high on the volume? Any amp can produce a heck of a lot of dirty power (well above its 'clean' rated power) if pushed hard enough. Distortion will rise rapidly and speaker-killing clipping can occur. It's trying to tell you to back off.
Feb 23, 2010 | Audio Players & Recorders
I have a kenwood kac-8452 4 channel amp that makes the speakers pulse after the volume gets turned up to 10. I also have a kenwood amp doing the same thing with my subs. any ideas?
Its not pulsing, its called clipping. The sound is being clipped due the amp being pushed past is power capacity and distorting the signal. This will damage your speakers very quickly. No amp should be turned more then 3/4 up. If its not loud enough you need to purchase a larger amp or be comfortable with the wattage it produces at 3/4 volume. You may also have speaker wires touching/crossed causing th issue.
Sep 10, 2009 | Kenwood KAC-8452 Car Audio Amplifier
I have just been given a pair of aiwa speakers sx-fz1800,there is two cables comming out of the back,which one do i use.
One pair goes to bigger speaker (woofer) and other pair for smaller speakers in box, to get full frequency response, you need to hook both cables.
Sep 10, 2009 | Audio Players & Recorders
Sound Distortion
somekind of hardware side failure or bad drivers.
I hear sounds from my audio output if i connect my headphones there directly but when I connect it to my speaker system they filter the distortion.
Apr 13, 2008 | ASUS M2N-E SLi Motherboard
35 people viewed this question
 Grubhead
Grubhead
