Question about Makita 231647-1 TORSION SPRING 4, BO3700
Need change torsion spring makita 9401 - Makita 231647-1 TORSION SPRING 4, BO3700
I did the clutch and now there is a shudder when pulling away and in between gear shifting. Please help
Did you put in a rebuilt clutch or a brand new one?
Shudder is usually weak clutch disc torsion springs.
Rebuilt discs may have weak torsion springs on the clutch disc while new clutch disc torsion springs should be "new" and should not cause clutch shudder.
One other cause can be broken or damaged motor mounts.
May 17, 2017 | Cars & Trucks
Hi I want to replace the bearings on my makita 9401 belt sander Are they easy to change
This separator tool is neccesary to get the bearings from the armature the other parts have needle bearings and sinterbronze bearings , with a grinding machine its much more work to get them off And more chance of damage.
Feb 05, 2017 | Makita Tools & Hardware - Others
What are the dimensions of the plain bearings on the back roller of a makita 9401 belt sander?
Go online to images. Type the sander model etc and there are parts diagrams shown. Just order the bearings from a Makita agent and save time and trouble.
Aug 15, 2014 | Tools & Hardware - Others
HOW DO I ADJUST TORSION BAR?
it sounds like your front leaf springs need to be re arched or your coil springs are shot i dont believe you can adjust that bar
May 31, 2014 | 1997 Dodge Dakota
What locks in the left and right torsion springs
the proper set up on thre bar which hols thr springs is plate lock handle part 107-3946 then the right hand torsion spring 108-0953,make sure the spring hooks over the plate lock, then left hand torsion spring then bar slides through left hand hole and lever release 40-1823-03 attaches to end of bar with a set screw
Sep 22, 2009 | Tecumseh Lawn Boy Push Mowers Insight...
What tools do I need to remove both engine belts from my wife's 2004 Concorde.do I need ome special tensioner tool to move the tensioner the other belt is a regular v belt and it goes around the...
2.7L & 3.5L Engines same Tools & Procedure Rate Me Please 1/2 in. breaker bar & Special Tool 7198 for conventional V-belts and Poly-V belts
  1. REMOVAL
    AIR CONDITIONING BELT
    NOTE: The A/C drive belt self tensioner is NOT a dynamic tensioner. After adjustment the tensioner bracket bolts are tightened. The torsion spring is no longer responsible for tensioning the A/C belt. The torsion spring is only used for initial belt tensioning.
    1. Remove generator/power steering belt to gain access to A/C belt. Refer to GENERATOR/POWER STEERING BELT for procedure.
    1. Loosen BUT DO NOT REMOVE tensioner locking bolt and pivot bolt (Fig. 2).
    2. Insert 1/2" drive breaker bar into square opening on belt tensioner. Rotate tensioner counterclockwise until belt can be removed from pulleys (Fig. 2).
    3. Slowly rotate tensioner clockwise to relieve spring load.
    CLEANING
    Clean all foreign debris from belt pulley grooves. The belt pulleys must be free of oil, grease, and coolants before installing the drive belt.
    INSPECTION
    Belt replacement under any or all of the following conditions is required:
    • Excessive wear
    • Frayed cords
    • Severe glazing
  • Poly-V Belt system may develop minor cracks across the ribbed side (due to reverse bending). These minor cracks are considered normal and acceptable. Parallel cracks are not (Fig. 3).
    NOTE:
    Do not use any type of belt dressing or restorer on Poly-V Belts. INSTALLATION
    AIR CONDITIONING BELT - NEW
    WARNING: DO NOT REMOVE A/C BELT TENSIONER LOCKING BOLT WITHOUT FIRST HOLDING THE TENSIONER WITH A 1/2" DRIVE BREAKER BAR, AS PERSONAL INJURY COULD RESULT.
NOTE: Verify that torsion spring position is in the new belt position before installing a NEW belt (Fig. 4). If torsion spring is not in the new belt position, follow steps 1-7 to change the tensioner spring from the USED belt position to the NEW belt position.
  1. Insert a 1/2" drive breaker bar into the square opening on the tensioner. Hold counterclockwise pressure on tensioner while removing the locking bolt (Fig. 2).
  2. Carefully release spring load of the torsion spring on the tensioner.
  3. Remove pivot bolt, tensioner, and spring from front timing cover.
  4. Insert spring arm into the NEW belt position on the tensioner (Fig. 4).
  5. Install torsion spring, tensioner, and pivot bolt.
  6. Install pivot bolt. Tighten only finger tight, at this time.
  7. Using a 1/2" drive breaker bar, apply counterclockwise pressure until locking bolt can be installed.
    1. Install the NEW belt by rotating the tensioner counterclockwise until the NEW belt can be installed on pulleys. See (Fig. 5) for belt routing.
    2. Release tensioner and remove breaker bar. Belt is automatically adjusted with the tensioner's torsion spring.
    3. Tighten tensioner locking bolt and pivot bolt to 28 Nm (250 in. lbs.) (Fig. 2).
    4. Install generator/power steering belt.
    AIR CONDITIONING BELT - USED
    NOTE: A "used belt" is considered having more than 500 miles of service use. NOTE: Perform steps 1-7 to change the tensioner spring from the NEW belt position, to the USED belt position.
    1. Insert a 1/2" drive breaker bar into the square opening on tensioner. Hold counterclockwise pressure on tensioner, while removing tensioner locking bolt (Fig. 2).
    2. Carefully release the tension of spring on tensioner.
    3. Remove pivot bolt, tensioner, and spring from front cover.
    4. Insert spring into the USED belt position on tensioner bracket (Fig. 4).
    5. Install spring, tensioner bracket, and pivot bolt.
    8. Install the USED belt by rotating tensioner counterclockwise until belt can be installed on pulleys. See (Fig. 5) for belt routing.
    9. Release tensioner and remove breaker bar. Belt is automatically adjusted with the tensioner's torsion spring.
    10. Tighten tensioner locking bolt and pivot bolt to 28 Nm (250 in. lbs.) (Fig. 2).
    11. Install generator/power steering belt.
I Hope This is Of Help To YOU IF So PLEASE HELP ME RATE ME it Helps Thank You Very Much and Happy Motoring !!!!!!!!
Jan 21, 2009 | Chrysler Concorde Cars & Trucks
Rear torsion bar
the car has rear springs for sure. there is no adjustment you have to replace the springs.
Jan 13, 2009 | 2000 Ford Taurus
Looking for a manuel for a makita belt sander model #9401
There is a black metal ******** one side that is actually a lever and with the tip of a screw driver or the like, pops out and releases the front roller.
Dec 26, 2008 | Tools & Hardware - Others
Makita 231647-1 TORSION SPRING 4, BO3700 Logo
Top Makita Tools & Hardware - Others Experts
Jim Thurston
John Porter
Are you a Makita Tool and Hardware - Other Expert? Answer questions, earn points and help others
