Question about Acer Aspire 4730 4730z 4730zg 4735 4736 4736z 4736zg 4935 4935g Cpu Fan
I press the power button twice for the device to boot
Booting problem
    Master:
  • 435 Answers
Can we have some more details? What happens when you push the power button once? Do lights come on? Does it make any noise? Is it plugged into a working electrical socket? Do you get any kind of a screen on the monitor, even a blue screen?
Posted on Apr 27, 2014
Polar 76em will not boot computer
switch on power supply on check fuse in plug
Dec 11, 2014 | Computers & Internet
Tip
Troubleshooting Error Messages on a Black Screen that may Occur During Startup...
<b><u>For Hp Laptop</u></b><br /><br />There are many reasons that a computer does not startup or boot into the Windows operating system.<br /><br /><b><u>Resolving Start Up and No Boot Problems Checklist</u></b><br /><b></b> <br /><b>Perform a Hard Reset</b><br />1. Disconnect all peripheral devices and remove all USB devices and media cards.<br />2. Disconnect the AC power adapter, remove the battery, and then press and hold the power button for at least 15 seconds.<br />3. Reconnect the AC power adapter (do not connect the battery), press the Power button and look for the LEDs to blink or glow, and listen for the sound of a disk drive and fan turning.<br />If computer does not start normally, identify the specific problem symptom listed below and take the recommended actions.<br /><br /><b>Symptom: LED lights do not glow, display is black, computer does not start<br /></b>If LEDs do not glow when power button is pressed, there is no power available to the notebook. Check AC adapter wiring and power connection to the notebook. Connect a different AC power adapter and remove battery. Connect a different battery and disconnect AC power adapter. If there is no battery or AC power at the notebook, contact HP for technical assistance.<br /><br /><b>Symptom: LEDs glow, but computer fails to startup or boot, and displays a black screen</b><br />Usually occurs if a component is installed incorrectly, or there is a device conflict or failure. Connect an external monitor to check display Remove all CD/DVDs, SD cards, USB devices, peripherals and do hard reset If memory or hard drive components were replaced, reinstall original components Remove memory modules and replace one-at-a-time If possible, boot to BIOS mode (f10) and run Memory Test and Hard Drive Test If all other methods fail, use recovery disk to recover the computer to original condition.<br /><br /><b>Symptom: Computer displays a blue screen or continually re-starts</b><br />Trying to restart the PC after an error message can usually bypass the error and the PC can run in Safe mode to install an update or patch. <br />Boot to BIOS Diagnostics (f10) and run memory and hard drive diagnostic tests Boot to Windows Advanced boot options (f8) and:<br />o Select Disable automatic restart on system failure to view error message<br />o Run Repair Your Computer<br />o Run Last Known Good Configuration (Advanced)<br />o Select Boot into Safe Mode and then Run a Microsoft system restore<br />o Select Boot into Safe Mode and then Uninstall recently installed programs<br />o Select Boot into Safe Mode and then run Windows Update<br /><br /><b>Symptom: Computer displays the Windows logo screen and stops responding</b><br />Boot to Windows Advanced boot options (f8) and select Disable auto-restart to view error message<br />Boot to BIOS mode (f10) and Restore the BIOS defaults (f9) Boot to BIOS mode (f10) and run Hard Drive Test Boot to Windows Advanced boot options (f8) and select Last Known Good Configuration (Advanced) Boot to Windows Advanced boot options (f8) and select Boot into Safe Mode and then Uninstall recently installed programs<br /><br /><b>Troubleshooting general black screen errors on an EFI-based computer</b><br />The Extensible Firmware Interface (EFI) is available on select HP Notebook PCs manufactured in late 2008 and beyond.<br />To access the Startup Menu and the troubleshooting options on an EFI-based computer, press the power button and immediatly press the ESC key. If computer does not display a EFI Startup Menu, it may a non-EFI computer.<br />The EFI environment allows you to select from the following options:<br />Press f1 for System Information .<br />Press f2 to perform System Diagnostics .<br />Press f1 for System Information System Information.<br />Press f2 to perform the Start-up Test .<br />Press f3 to perform the Run-in Test .<br />Press f4 to perform the Hard Disk Test .<br />Press f11 to view the Error Log .<br />Press f9 for Boot Device Options .<br />Press f10 for Bios Setup .<br />Press f11 to perform a System Recovery .<br /><br /><b>Troubleshooting general black screen errors on non-EFI based computers<br /></b>The Extensible Firmware Interface (EFI) was not available on computer manufactured in 2008 or earlier.<br />When you try to start your computer, it may appear to stop responding with an empty, black screen before reaching a blue screen or the Windows logo. If there is no specific error message provided, there are several things you can do to troubleshoot a black screen. <br />Remove a non-system disk from the computer <br />To remove all non-system disks and reboot the computer, follow the steps below:<br />Disconnect any eSata, USB, or 1394 (Firewire) devices that are attached to the computer.<br />Remove any CD / DVD discs or memory cards from the drives if present.<br />Press and hold the Power button for 30 seconds to turn off the computer. Then, press and release the Power button to turn on the computer. <br /><br /><u> NOTE: During startup, a computer checks several devices for an operating system in a pre-determined order. You can change the order that the computer uses in the system BIOS. </u><br /><b>After removing any non-system disk:<br /></b>If the computer starts up normally to the Windows desktop, no further action is needed.<br />If the computer still stops at the black screen continue by restoring the BIOS default settings.<br /><br />for re-installation bios process, waiting for next tips. <br /><span>Thank you</span> <span>for taking</span> <span>the time</span> <span>to</span> <span>read. H</span>opefully these tips beneficial to you to solve your hp laptop.<br /><br />Regards<br />Multilinkent
on Mar 08, 2011 | Computers & Internet
Reset intermec cn70
There are 3 ways to reset the device:
Warm Boot - When an application becomes unresponsive.
Press the Yellow Power button (also referred to as the IO Button) and select the reboot option.
Cold Boot - When device itself becomes unresponsive, will loose any cached data.
Press the Yellow Power Button (also referred to as the IO Button) to suspend the device. Remove the battery pack and press the reset button in the battery compartment (Round rubber button). Replace the battery pack and press the yellow power button or IO button. The blue Intermec startup screen appears.
Clean Boot - When device itself becomes unresponsive and cold boot fails, device will be restored to factory state, all data and installed applications will be lost except for data stored in Flash Storage.
- Firmware 1.50.19.0013 and prior -
Remove the battery pack and press the reset button in the battery compartment. Replace the battery pack and immediately press the yellow power button (IO button) and volume down button (the lower
button on the right side) together until a message box appears on the screen stating the clean boot. Press the volume up button (the upper button on the right side) to confirm the clean boot.
- Firmware 1.62.27.6 and later -
Remove the battery pack and press the reset button in the battery compartment. Replace the battery pack and immediately press the yellow power button (IO button) for 8 seconds. Message box will appear stating to release the power button. Press button number 1 then button number 2, confirm again by pressing button number 1 then number 2 again. Message box will state that the device is clean booting.
Jun 20, 2014 | Intermec CN70 Handheld Mobile Computer...
Change boot cd rom bios300
Your IBM 300 series desktop computer is normally set to boot its operating system directly from the installed hard disk drive.
There are some cases where you may want to boot from a different device, such as loading from the floppy drive to install a new operating system.
In order to change the boot order on the IBM computer you need to access the Basic Input Output System (BIOS) menu.
Close any applications that are still running.
Turn off the IBM 300PI computer and then turn it back on again.
Tap the "F1" key when the "Configuration/Setup Utility" prompt appears at the bottom of the screen.
Tap the down arrow key four times to highlight the "Start Options" entry.
Press the Enter key.
Highlight the "Startup Sequence" entry and then press Enter again.
Scroll down and highlight "First Startup Device."
Press Enter. Scroll through the list of available boot order devices.
Highlight the device you want to use, such as "CD Drive" or "Floppy Drive," and press Enter.
Press the "Escape" key twice.
Highlight "Save Settings" and then tap Enter.
Power off the IBM computer and then power it back on.
May 06, 2013 | IBM 300PL (PC 300 PL 733) PC Desktop
My computer will not boot windows xp os
Do you mean it won't pick the disc? If so, try F10 it should also give you a boot menu if you don't see press any key to boot from cd... The other option is boot into BIOS and change your boot order. CD-ROM/DVD should be the 1st option.8_28_2012_7_14_07_am.jpg
Aug 28, 2012 | IBM ThinkPad X41 Notebook
Screen shows "Reboot and select
what you want do is disconnect your hard drive then disconnect the power from your motherboard the from the power supply, and press the power button the connect all the power cables back then enter bios screen go to the boot tab and select boot device priority and move your hard drive up.
May 21, 2011 | Computers & Internet
Toshiba satellite5202 need to change boot order in bios how do i do that?
To get into the BIOS configuration, try pressing the DEL key or the ESC key. Then got to the startup device or Boot up order. You can then change the boot order of the devices.
Oct 18, 2010 | Computers & Internet
HP Laptop DV2415NR Need to power on twice to boot.
log in your bois and make sure first boot option is hard drive. not cd/usb or anything else. unless you need to
Apr 18, 2009 | Dell Latitude D600 Notebook
Usb power issues
Some systems will try to boot up on a usb device such as an IPod or a external hard drive.
It should be unplugged to get it to boot properly.
Oct 31, 2008 | HP Compaq Business d530 Ultra-Slim PC...
Forgot password
Performing a Clean Boot
THIS WILL TAKE IT BACK TO THE FACTOR SETTINGS
A clean boot resets the EDA to the factory default settings. All data is the Application folder is retained. You must
download the Clean Boot Package file from the Support Central and install on the EDA.
NOTE When the EDA powers up after inserting a battery for the first time, the device boots and powers on
automatically.
CAUTION A clean boot should only be performed by an authorized system administrator. You must connect the EDA
to AC power during a clean boot.
Removing AC power from the EDA during a clean boot may render the EDA inoperable.
To perform a clean boot:
1. Download the Clean Boot Package from the Support Central web site. Follow the instructions included in the
package for installing the package onto the EDA.
2. Simultaneously press the Power button and the 1 and 9 keys.
3. Immediately, as soon as the device starts to boot and before the splash screen is visible, press and hold the
left scan button for a few seconds.
4. Insert the EDA into a powered cradle.
5. The EDA updates and then re-boots.
6. Calibrate the screen.
Waking the EDA
The wakeup conditions define what actions wake up the EDA. These settings are configurable and the factory
default settings shown in Table 1-3 are subject to change/update.
Table 1-3 Wakeup Conditions (Default Settings)
Status Description Conditions for Wakeup
Power Off
(Suspend Mode)
When the EDA suspends by pressing
Power, these actions wake the EDA.
1. Power button is pressed.
2. AC power added or removed.
3. Cradle/cable connect or disconnect.
Key or scan button is pressed.
Real Time Clock set to wake up.
Incoming phone call (MC7004/94/95 only)
Auto Off When the EDA suspends by an automatic
power-off function, these actions wake the
EDA.
Apr 11, 2008 | Symbol MC70
Acer Aspire 4730 4730z 4730zg 4735 4736 4736z 4736zg 4935 4935g Cpu Fan Logo
61 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
