Functional key its stop working after few second due to regulation problem.what can i do.
  • 3,320 Answers
Regulation of what? Do you mean registry?
Posted on Mar 29, 2014
Horizon T91 Treadmill - Key Pad Troubleshooting
correct. If the console is not responding or some buttons do but others don't the membrane needs replacement.
Apr 02, 2017 | Horizon T92 - Treadmill
99 tarurus stop getting fuel.
Could be a fuel pressure regulator or lost signal from crank sensor that gives inaccurate data.
The crank sensor is responsible for sending data to increase fuel pressure as a function of increased RPM. If the RPM reads low, then fuel pressure will be low.
Check fuel pressure.
Thinking that air pressure is affecting pressure regulator and compensating for a weak regulator diaphragm.
Would be interested in final fix of your problem.
May 10, 2013 | Ford Taurus Cars & Trucks
My alarm system went off due to wrong key ingnition...had to take a battery terminal off to stop the alarm, now I have the key and it wont start...is there a security reset?
Yes there is. 1. Press (LOCK) button 5 times at 2 second intervals to resynchronize transmitter. Attempt to function transmitter, if working as designed discontinue programming. 2. Turn ignition to run position. (Allow ignition chimes to stop).
3. Using any original (working) transmitter, press the [UNLOCK] button for 4 to 10 seconds.
4. Within the specified 4 to 10 seconds, continue pressing the [UNLOCK] button and press the [PANIC] button for 1 second and release both buttons (AN/DN release either button first). A chime will sound to indicate that the transmitter programming mode has been entered (allow 3 seconds for chime to sound).
5. Press [LOCK] and [UNLOCK] buttons simultaneously for 1 second and release (a short chime will sound for AN/DN).
6. Press and release any button on the same transmitter and a chime will sound after successfully programming the transmitter (locks will cycle for AN/DN).
Aug 15, 2011 | 2002 Jeep Liberty
I have a 95 fxstsb bad boy with an electrical problem. crank it up all lights work fine after a few minutes headlight blows rest of lights go real bright and bike shuts down everything goes off ater a few...
well, its not the "circut breaker" aka the fusebox, so there has to be a problem with the regulator. when you say headlight "blows" do you mean the actual bulb burns out, the fuse burns out, or the light just turns off? it matters. on a side note, if your headlight stops working, its normal for all the other lights to get a little brighter due to the extra power for the headlight going to the others.
Aug 23, 2010 | Harley Davidson FXSTS Springer Softail...
Ibm typewriter in LANG mode. How do you get it out of LANG mode?
Figured it out on our own. Just had to hold down the function key a few seconds for it to work. So we held the function key and "L" for lang down together for a few seconds and it went off.
Oct 06, 2009 | Lexmark Wheelwriter 10 Series II...
Takes multiple times to start
I think you have a faling fuel pump or a bad pressure regulator allowing fuel pressure to bleed down when the engine is off.
Try this test - When you start the car for the first time of the day, turn the key to "ON", wait a few seconds, turn the key off. Wait about 15 seconds, turn the key to "ON" again, wait a few seconds. Then wait one final time for 1 seconds and try starting the car. If it starts right away, that means fule pressure is bleeding of due to a bad check vavle int he fuel pump, a bad fuel pump or a bad pressure regulator.
The reason for the procedure is because when you turn the key to "ON", the fuel pump runs for 2 seconds and then shuts off if the engine is not running. The 15 seconds wait is for the power and fuel pump relay to cycle off before it will run the pump again.
Let us know how the test comes out. The fuel pump is in the fuel tank and hums when it is running.
Mar 01, 2009 | 1999 Chevrolet Silverado 1500
Good fuel pressure. engine turns will not start. runs if primed through trottle body.
Replace the fuel pressure regulator in the intake plenum. This is the No. 1 problem for hard starting with the 4.3 L engine. It leaks fuel and loses fuel pressure when sitting for a few hours. You can try to cycle starter for a split second without cranking wait 3 seconds the turn key OFF then repete 3 times then tryto start. This will build up lossed fuel pressure and verify leaky fuel pressure regulator. Joe ASE Master Tech
Feb 22, 2009 | 1999 Chevrolet S-10 Pickup
Function button keeps failing
only do this if you relay know what you are doing. try asking your local appliance second hand shop it will save you time and money
Nov 12, 2007 | Hotpoint SY36 Style Line Stainless Steel...
Tv reacts very slow
the problem is due to the crystal which sets the speed of the processor and it may be dry due to heat if that crystal is replaced or dry soldered the problem can be solved
Jun 27, 2007 | Philips 60P8341 60" Rear Projection...
Computers & Internet Logo
20 people viewed this question
David Payne
David Payne
