Question about Radio Communications
Gme tx6100 Press SQL key to check channel but no hiss voice, is it antenna damaged?
4 Suggested Answers
SOURCE: tv not working
Can you confirm that you didn't have any input signal? My wife once accidentally pressed the reset button on the remote and the TV was stuck in this state. I tried to hook up an antenna to the digital antenna input and let the TV search for a channel. It did find a station and got out of the channel search mode, which was all I needed. Then, I unhook the antenna and continued to enjoy my DVD movie. I didn't check the manual. So, it's possible that there is a better solution. My TV was working fine and I think it just has a terrible user interface. I'm not sure about your TV's condition, though.
Posted on Sep 19, 2007
  • 556 Answers
SOURCE: Stuck on Channel searching!!!
the problem is we have no cable-none at all. The tv is used only for playing DVD's. solution check dvd to tv wire or socket if it is ok then play dvd in another tv if it works fine then problem in tv. for that check tv tuner & its circuit for loose. check tuner itself
Posted on Sep 23, 2007
  • 4234 Answers
SOURCE: Power surge damaged tuner
The tuner should be replaceable, but without the make and model, I can't get part numbers or cost.
Please update this with the make and model.
Thanks,
Dan
Posted on Aug 21, 2009
Testimonial: "Thanks guys/gals!"
How do I fix a blown channel?
If you're on an antenna it could cause the problem.
If you're on cable, forget the above.
Hope this helps.
Channel 2 is the lowest frequency and requires the longest antenna elements.
Mar 26, 2015 | Audio Players & Recorders
How can I repair a corrupted MDF files and SQL server?
Similar question has been answered here: http://www.fixya.com/support/t24364927-sql_repair_recovery_process_very
Before asking any question in the forum, first you need to search your problem.
May 12, 2014 | Microsoft Database Software A5K-02817 SQL...
Background noise
no problem with..record some part of the start with no voice just a 5-10 seconds remain quite...just kept running the recording...then start and record your voice after which install AudaCITY Software and drag your audio file in it and then select the first 5-19 seconds recording which was just the background kept recording selecting the part go to Effects -> Noise Removal then press Get Profile,
after which again select all the track by: Control + A key on PC and then go to Effects Noise Removal move the bar to the left side...and press ok/continue key....now your track is very much clean by the noise...and
for sound loudness select all the track and go to Effects -> Normalize then again Effects -> Amplify put the slider value to -0.1 of what the value is shown.
Jan 19, 2012 | Vizio VSB210WS Soundbar
I can only get channels 600 through 900 which I have never see before.I cannot get regular channels or cable channels.It is not a flat panel t.v.Q1435A is the model number
Hi -
If you have a cable TV line connected directly to the TV, an antenna or a cable box connected by coaxial cable, I would suggest running the automatic channel scan (AUTO-PROGRAM) again:
1. Press the AV key on the Advent remote control repeatedly until TV is displayed in one corner of the TV screen. If you don't have the Advent remote, use the TV/AV button on the front of the TV.
2. Press the MENU key on the advent remote or the front of the TV to open the on-screen menus.
3. Use the CH+/- keys on the remote or on the front of the TV to highlight PRESET then press VOL+ to select.
4. Use the CH+/- keys on the remote or on the front of the TV to highlight ANTENNA then use the VOL+ key to select either AIR (for antenna) or CABLE.
5. Use the CH+/- keys on the remote or on the front of the TV to highlight AUTO-PROGRAM then press the VOL+ key to start the automatic channel scan.
Once the channel scan is complete, the TV should automatically return to viewing the first channel found during the scan. Do not press the MENU key during the scan or the scan will not complete.
If you are using a cable/satellite receiver and it is connected to the TV by any means other than a coaxial cable, you do not need to run the channel scan. You should simply select the correct AV input using the AV key on the remote or the TV/AV key on the front of the TV (see step 1 above).
If you have done all of the above and you are still unable to get the channels on your TV, please post back for further assistance. You can reply to me by clicking on "Add a Comment" below your question. Please let me know whether you are using a direct cable line, antenna or cable box, etc.
Regards,
BElectric
Mar 26, 2011 | Televison & Video
Every time I press my MIC to speak into it the red lights on the RX/T and ANT light come on alerting me of a problem. How can I fix this.
RX/TX light should change to red, however the ANT light is a bad light. This means that your antenna is not adjusted properly. Do not key the radio or talk on it for any other reason then to check the SWR and tune the antenna. If you have the manual that came with your cobra 29, there is a section that explains how to check the SWR. And the manual for the antenna, it will explain how to adjust it.
If not, here is how to do it.........
How to check the SWR on a Cobra 29
Step 1. Find out what your current SWR is on the center of the band.
  1. Turn the radio to channel 20.
  2. Set the S/RF SWR CAL switch to CAL.
  3. Turn the CAL knob all the way counter clockwise.
  4. Key the radio. Do not talk into the mic.
  5. While holding the mic key, turn the CAL knob to the right until the needle reaches the CAL mark on the top right of the meter.
  6. Now flip the S/RF SWR CAL switch to SWR while still holding the key on the mic.
The needle should fall. Where ever the needle is while holding the key is your SWR reading on channel 20. It should be as low as possible. If its a reading of 2, then its not gonna kill the radio but is border line. Any higher and its bad. Using the radio like this will damage the final output transistor. If its less then 2 this is better. You want it to be less then 1.5 or better.
The ANT light may come on with an SWR of 2. running the radio with an SWR of 2 shouldn't hurt the radio, but I don't like to mess around. Get it as low as possible.
How to adjust the antenna for SWR
The length of your antenna will change your SWR. SWR is basically how much RF energy is not leaving the antenna and getting reflected back into the radio. That's why it hurts the radio when its high. An antenna has to be the right length, matching the length of the radio waves in order for it to radiate all of the RF energy out of the antenna.
Most antennas have a way of lengthening or shortening the antenna. If its a mag mount antenna with a metal whip, there is probably a set screw that when loosened, will allow you to raise or lower the whip. If its a fiberglass antenna, under the rubber cap at the top is how you raise or lower the antenna.
Figuring out if your antenna is too long, or too short
Here is how to know weather or not you have to lengthen or shorten your antenna.
  1. Take an SWR reading as explained in the first step on channel 1. Write down the SWR for reference.
  2. Take another SWR reading on channel 40. Again write it down for reference.
Now if the SWR is higher on channel 1 then on channel 40, its too short. You need to make it longer.
If the SWR is higher on channel 40 then channel 1, then the antenna is too long. You need to shorten it.
Make small adjust ments about an 1/8th to a 1/4th inch at a time. each time checking the difference between channel 1 and 40.
You will know when you are a good match when there is little to no difference between channel 1 and 40's SWR. Once you are satisfied that the difference between 1 and 40 is about the same, and much lower, then turn the radio back to channel 20 and take an SWR reading.
You will now find that the SWR on channel 20 is really low. Most likely under 1.5 or better, Almost nothing on the meter.
Here is a Meter Key, so you know what you are looking at.
Oct 11, 2010 | Cobra 29 LTD CB Radio
I have the box installed and on. Now what do I do to get the local stations on my TV
What box - satellite/cable/digital-to-analog converter? This tv has a digital (ATSC) tuner built in. So if you are looking for OTA channels, use antennaweb.org or tvfool.com to find out what direction to point your antenna and what antenna you need. Then connect the antenna's coax cable to your TV. Antennaweb is very conservative and assumes an outdoor antenna. tvfool.com will list several more channels and the different antennas that are needed for various distances between your location and the station transmitters.
If you are sharing one antenna between several tvs or tv and other devices, you may need an amplifier in addition to the splitter. (Unfortunately, these can get damaged by surges as well. I've lost certain channels after a lightning strike turned the amp into a filter for one part of the RF signal spectrum.)
Once you have the antenna connected and pointing in the direction of the desired station, you will need to scan for channels. If this is the first time the tv is set up, you will be prompted for menu language, the input type and then asked if you want the TV to auto-scan for channels. Otherwise, hit Menu, use the left and right arrows to get to the Channels menu option and press the + button in the center of the arrow keys. Next use the up and down arrows to set the incoming signal (if needed) - the item is labeled Cable and is a Yes/No (again press + to select item and to enter the change). Continue down to the Auto-program and let that run. You can add/remove channels from the resulting listing with the Channel Skip/Add option just below Auto-program.
I hope this helps.
Jun 21, 2010 | Sony FD Trinitron WEGA KV-27HS420 27" TV
Freq change GME GX300 from 27Mhz to 29Mhz
Hold down the 88/pri and the DW buttons while switching on the radio into programming mode. You'll then need the programming soft and hardware to read the radio., add the 27mhz channels and write it back to the radio. The GX300 can only store additional freq. in the p1-p0 modes
Sep 05, 2009 | Boating
Sep 11, 2007 | Sanyo DS20930 20" TV
Radio Communications Logo
50 people viewed this question
Top Radio Communications Experts
eradiostore
eradiostore
Mike Charette
Are you a Radio Communication Expert? Answer questions, earn points and help others
