Question about Razer Ferox 2 Speakers
My razer ferox wont make any sound
The other speaker works but the other one doesnt
What are the side effects of taking tim jan?
Timjan contains 16.5% alcohol Vol. So any side effects you have to alcohol would apply here. But as for the Aloe ferox in Timjan.
"Aloe Ferox has no side effects; only rare cases of allergies have been reported.
Aloe Ferox is non-toxic and has no undesirable side effects on the body. Aloe Ferox is not habit-forming.
Keep an eye on your condition when using medication. It may be necessary to adjust your medication as your condition normalizes, especially in the case of high blood pressure and high/low blood sugar."
The Detoxification possess could cause so discomfort.
"Symptoms of a chronic condition may temporarily worsen as part of the detoxifying process of the body. Other detoxifying symptoms that may occur are diarrhea, nausea, windiness, stomach cramps and headaches. Symptoms are of a passing nature. Give your body time to adjust. Diarrhea, as part of the detoxifying process, is only a problem if it lasts longer than a couple of days. Drink a lot of water and lower the dosage. "
Aug 03, 2017 | Cars & Trucks
Razer nostromo
you need to go to control panel and then devise manger and update driver software for that devise
Jan 27, 2014 | Razer Nostromo Keypad
Microphone doesnt work with skype
I've heard of this problem alot, I took 10 minutes today with my friend with this headset to figure out a fix.
From what i can tell, Skype doesnt pick up the Microphones input.
The only solution I could figure out so far has been this.
A voice changing program called MorphVox Pro (by Screaming bee) offers a Trial.
If you download it, and set up your microphone on this to work, You can then in skype select the MorphVOX Pro as your microphone, and you can use this chat program to work with your headset.
This is only a temporary fix But it is a step in the right direction, I'll be forwarding my email to Razer later to try and get some updates for the headset.
Best Regards
Ricky.
Feb 09, 2013 | Razer Chimaera 5.1 Wireless Gaming Headset...
Makes a clicking sound and won't play sound
I guarantee it's a simple 99 cent capacitor. takes 5min to fix. It's labeled C125 on the circuit board.view this photo for reference....
https://www.dropbox.com/sh/cvlnyj5cmkdr8yl/7tNh8CsSAj#lh:null-Mako.jpg
it's a simple 25V 47uf 85C capacitor. you can pick one up at your local Fry's electronics, or get one on ebay for about one dollar. I know of 4 people now that have fixed their razer mako with this single capacitor being the only problem. TRUST ME, it's not the control pod, nothing to do with it, but the control pod does initiate the power start up, and this capacitor is faulty and works...sort of until complete failure. yet no visual sign of failure with oozing or leaking. it's just bad, along with ALL the capacitors on this board are from fujicon... absolute *******! make it a project and replace all of them if you want these awesome speakers to last forever. I decided to upgrade it all and bought high end audio caps from ELNA, NICHICON, PANASONIC and FROYLT. Sourced ALL of them on ebay. I'm not very tech savvy, it's NOT difficult to repair one cap on your own. A soldering iron (40watt min) some rosin core solder (thinnest guage is best), and solder wick is all you need. OH, and patience. check this link for more info. https://www.dropbox.com/sh/cvlnyj5cmkdr8yl/7tNh8CsSAj#lh:null-Mako.jpg
I will plan on uploading info about my whole re-capping project, listing all my parts, prices and time involved. Also will post photos of before and after. :D DOOOOO NOT THROW YOUR SPEAKERS AWAY! 99cents is your fix! DON'T WASTE YOUR MONEY ON NEW SPEAKERS! Razer Mako's are amazing speakers, and with an upgrade of new caps, these bad boys are sure to be impressive!
Jan 27, 2013 | Razer Mako 2.1 Speakers
Tv speaker problem
OK try to check the sound board or sound IC
Jun 25, 2012 | Polaroid 4241-TLXB 42 in. LCD Television
My Razer Mako 2.0 speakers started emitting a ticking (popping?) sound about 2:00 am. My computer was off at the time. The sound is constant unless I turn off the control pad, turn off the sub woofer or...
I guarantee it\'s a simple 99 cent capacitor. takes 5min to fix. It\'s labeled C125 on the circuit board.view this photo for reference....
it\'s a simple 25V 47uf 85C capacitor. you can pick one up at your local Fry\'s electronics, or get one on ebay for about one dollar. I know of 4 people now that have fixed their razer mako with this single capacitor being the only problem. TRUST ME, it\'s not the control pod, nothing to do with it, but the control pod does initiate the power start up, and this capacitor is faulty and works...sort of until complete failure. yet no visual sign of failure with oozing or leaking. it\'s just bad, along with ALL the capacitors on this board are from fujicon... absolute CRAPOLA! make it a project and replace all of them if you want these awesome speakers to last forever. I decided to upgrade it all and bought high end audio caps from ELNA, NICHICON, PANASONIC and FROYLT. Sourced ALL of them on ebay. I\'m not very tech savvy, it\'s NOT difficult to repair one cap on your own. A soldering iron (40watt min) some rosin core solder (thinnest guage is best), and solder wick is all you need. OH, and patience. check this link for more info. https://www.dropbox.com/sh/cvlnyj5cmkdr8yl/7tNh8CsSAj#lh:null-Mako.jpg
I will plan on uploading info about my whole re-capping project, listing all my parts, prices and time involved. Also will post photos of before and after. :D DOOOOO NOT THROW YOUR SPEAKERS AWAY! 99cents is your fix! DON\'T WASTE YOUR MONEY ON NEW SPEAKERS! Razer Mako\'s are amazing speakers, and with an upgrade of new caps, these bad boys are sure to be impressive!
Apr 02, 2011 | Razer Mako 2.1 Speakers
Hi I bought Razer Mako speakers few days ago, and from the start i've got this problem... The speakers stop working (there's no sound) after few minutes (from 7 to 15) of playing, the same for different...
I had the same problem today. Don't know what caused it. But I turned off the Makos using the switch behind the subwoofer waited about a minute then turned them back on, problem solved.
Hope this helps you and others who encounter this problem.
Sep 07, 2010 | Razer Mako 2.1 Speakers
My computer wont make any sounds but the speakers work
check to see i the sound card drivers are installed, try updating your drivers
Dec 06, 2009 | Computers & Internet
No sound in rear speakers
I figured this one out, although I might still send it back for an exchange. It turned out that the right rear speaker works just fine, however the jack seems to be flawed. When fully plugged in, the rear speaker input only picks up the left channel. If you pull it out just a little, say 1/8-1/4 the way out it will pick up both channels. Not a good solution but it works for the time being.
Jun 03, 2008 | Razer Barracuda HP-1 Consumer Headphones
Razer Ferox 2 Speakers Logo
127 people viewed this question
Top Razer Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Razer Audio Player and Recorder Expert? Answer questions, earn points and help others
