Question about Carrier Heating & Cooling
38ba009550 tonage HOW MANY TON IS IT
LRA how to convert in tonage so 10 LRA How many ton and 145 LRA Copland scroll compressor tonage value pleas give me answer
LRA on the data tag stands for "locked rotor amps" and has nothing to do with tonnage. In the model # there should be a number to use. And divide that # by 12 (12,000 btu/ton). So if I had a PFG24H200 it would be the "24"and a 2 ton unit
Jul 06, 2015 | Heating & Cooling
Describe your 38BRC036 Air Conditioner Problem WHAT TONAGE IS A 38BRC036?
Three tons 036. One ton 12, Two ton 24, Three ton 3, Four ton 48
Aug 25, 2011 | Carrier 38BRC036 Air Conditioner
What is the tonage on a 10aja3601
Hi, the tonnage of your unit is a 3 Ton unit. There are 12,000 btu's per ton of cooling, so your model number has a a36, so 3 x 12 = 36 which is 36 = 3 tons of cooling.
Sincerely,
Shastalaker7
A/C, Heating, & Refrigeration, Contractor
May 15, 2010 | Weather King 10AJA3601AH Air Conditioner
SIZE, TONAGE
hey there, you hace a 2 and a half ton unit there.
seth
Jul 29, 2009 | Heating & Cooling
Tonage or BTU/hour rating from Ruud name plate
See this link
http://www.epinions.com/specs/pr-GE_Zoneline_AZ55H07D_Air_Conditioner
Its say 7100 BTU/hr
Jun 05, 2009 | GE Zoneline AZ55H07D Air Conditioner
Age and tonage of carrier 38CKC036350 S/N 2005E40526
its a 3 ton unit manufactured in 2005
the 36 in the model number indicates tonnage 12,000 btu's to a ton times 3 equals 36
the 2005 in the serial indicates year made not sure what month but if i had to guess i'd say May of '05
Thanks Peyton
Mar 13, 2009 | Carrier 38CKC042 Air Conditioner
Air conditon units
the higher the seer the more efficent it is no matter the tonage of the unit
make sure that the tonage is correctly sized for the home rule of thumb is if the home is insulsted properly 600 sq feeet per ton
oversizing creates shot cycles real cool then warm real cool then warm, under size unit runs all the time
May 19, 2008 | Heating & Cooling
Heating & Cooling Logo
134 people viewed this question
Top Carrier Heating & Cooling Experts
Dan Webster
Dan Webster
Bill Long
Are you a Carrier Heating and Cooling Expert? Answer questions, earn points and help others
