Question about Bernina Virtuosa 150
Fly Wheel won't turn !
Just aquired a vertuosa 150 , it's hardly been used and sat around for the past 6 yrs . The fly wheel will only turn under extreme force , i managed to raise the needle bar high enough to insert a needle ! , it makes a clicking noise like something is stuck !, any suggestions ?
  • 33 Answers
I know a lady who had a machine and never took it out of the
box until one day she did and itching would work- The
machine had frozen up and she had to send her machine
back to the shop to be repaired- it is always good to take a machine out and run it even without thread to get the oil moving around
in it- probably once a year is fine but don't wait for several years.
Posted on Mar 30, 2014
wolftech
  • 77 Answers
SOURCE: Needle Keeps Moving While Sewing and Bobbin Wont Thread
Hi Nikki,
The problem seems to be of the needles alignment. If you are using a half bobbin type (D type) needle, makes sure you have used the proper number & size and also fastened it well so that the flat side is firmly fixed/clasping the inner side of the needle hold. That black thing which I feel is the fly-nut that helps you tighten/clamp the needle to its hold. Then after having done that, slowly turn the wheel manually to see whether the needle is going in thru the hole in a straight line and if you can, look underneath to se if the knotter ring (the one that looks like having fangs) comes close as the neele advances inward. All these movements HAVE TO BE syncronised. Only then you will be able to stitch the fines of fabrics speedily. Also make sure oyu are not tugging on the front end of the fabric too hard as this may cause the needle to go in a diagonal manner thus causing it to snap. Take care as to NOT to be too close to the needle while at high speeds. The snapping pieces can fly right into your eyes/nose causing serious injury.
Hope that does it Nikki...
Posted on May 06, 2008
  • 323 Answers
SOURCE: thread get's tangled and attached to plate while embroidering
Just a thought. Is it possible that your thread is wrapping around your spool post or snagging on your thread spool?
sewman7
Posted on Jun 12, 2008
SOURCE: feed dogs are not coming up high enough to catch the fabric
as your tech i have fixed your feed dog height ablevac and sew cleveland ohio
Posted on Nov 07, 2008
kent581
  • 87 Answers
SOURCE: Bernina 1090 Needle assembly stopped moving down
There is a spring loaded catch on the needle bar assembly. It is designed to keep the needle bar from going up and down on command for basting. That way it can take fewer stitches while basting. Anyway, over time, with lint build up, use and not enough oiling, the needle bar clamp release can stick. It is located in the machine cover and hard to get at. It is located right at the point where the needle bar clamp (middle of needle bar) is. It looks pointed on top and about 3/8" tall and SHOULD be able to move front to back (as you are sitting at the machine. If you want to fix it your self, lay the machine on it's back to see up into the needle bar area, you can also see through the threading slot as well.to oil it with SEWING MACHINE oil (read not 3 n1 oil) and try to work it front to back until it breaks free and play with it until it springs back every time you push it. I hope this helps.
Kent
Posted on Mar 21, 2009
  • 1116 Answers
SOURCE: I was sewing and the foot pedal stopped working.
Take your machine in to a Bernina dealer for service. It could be you need a new foot pedal, or if could be something else.
Posted on Feb 23, 2010
My pfaff 7570 has stopped and the fly wheel will not move.
Forcing it may break some important parts. I recommend taking it for service.
Feb 27, 2018 | PfaFF Sewing Machines
Why does my machine make a terrible screaming noise
try oiling parts
remove any thread around the bobbin carrier shaft
take it in for a service
Jun 16, 2016 | Sewing Machines
Hand wheel won't move.Scissorbutton wont work.
Repairing a Janome or New Home Sewing Machine ...
www.thriftyfun.com/Repairing-a-Janome-or-New-Home-Sewing-Machin...
Question: Memory Craft Machine Won't Run ... I'm a computer repair technician and good with tools, is this something I could fix or should we .... machine which will zig zag fine if i turn the wheel by hand or sew very slowly; as soon as I speed ...
Janome won t turn Sewing Machines Questions & Answers ...
www.fixya.com > Forum > Tags > won t turn > Sewing Machines
Janome sewing machines won t turn related questions and answers. ... Ad. Question about Memorycraft 6500P Computerized Sewing Machine ... it could be a part has worn or broken, esecially when the hand wheel won't turn,, it needs to be.
Janome wheel not turning Sewing Machines Questions ...
www.fixya.com > Forum > Tags > wheel not turning > Sewing Machines
Janome sewing machines wheel not turning related questions and answers. ... 10000 janome jamming fly wheel won't turn fly wheel won't turn warning for too thick ...the hand wheel is not moving the needle at all Hi I was unable to move the needle at all ... Janome Memory Craft 9000 Computerized Sewing Machine.
Jan 25, 2016 | Janome Memorycraft 6500P Computerized...
The handwheel will turn manually but it will not move using the foot pedal. The sound it makes when I press on the foot pedal *sounds* like I am filling the bobbin.
foot pedal not moving needle - Home Forums - GardenWeb
ths.gardenweb.com > Home Forums > Sewing
Nov 8, 2013 - We have a Brother Limited Edition Project Runway Sewing MachineRefurbished LS2250PRW. I was trying to sew on a button and was turning the hand wheel to do ... front near the needle where you can run the machine with foot pedal ...just what I would experience when my Bernina was running, or not, ...
Sewing Machine Repair ' ThriftyFun
www.thriftyfun.com/tf/Home.../Machines/Sewing_Machines/index.html
The thread is being picked up from underneath, but will not form a stitch at all. ... Butwhen I push my pedal down my needle won't move, the motor runs, but nothing happens. ... I have a Bernina machine which is sewing OK with the normal foot. ....The hand wheel, the wheel at the end that manually turns to make the needle ...
Help me diagnose and fix a problem with my sewing machine - Sewing ...
artisanssquare.com > ... > Sewing Machines
Jan 11, 2016 | Bernina Sewing Machines
I would replace the needle anyway. It's hard to tell if one is bent or not.
Remove your feed dog/needle plate and the bobbin cover. Take out your bobbin and bobbin carrier.
Get out a magnifying glass and really examine. Look for thread ends in between moving parts.
Also check the thread pathways. Especially where the take up lever is hidden. I've heard of some ladies finding threads snarled up in that area which caused problems like this.
Good luck. If all else fails take it in for repair.
Nov 04, 2012 | Janome Sewing Machines
HI problem with Consew 199R-1A. Machine locked up. I just started sewing and it locked up. Needle is fine, fly wheel won't turn more then 1/4 back and forth
Good day!
that problem is usually happen when your machine have clog or no lubrication please try to use oil to lubricate your machine at all moving parts inside.
Thank you and good luck.
Jun 10, 2011 | Consew 199R-1A Sewing Machine
Oiling the Brother LS1217
oil all moving parts and try turning handwheel by hand to work oil in. it really needs a service by a technician
scott
Jul 26, 2009 | Brother LS-1217 Mechanical Sewing Machine
How do you adjust the stitch length on Consew 226 R-1?
if it is like the other industrial machines I've used, here is the general principle:
On the machine there is a button with no label. Hold button while turning the handwheel toward you. When you feel the button depressl you can adjust the length. Hold the button in the machine and crank the hand wheel back to decrease the length of ths titch and foward to increase it. I usually put a notch on the fly wheel for my standard length with some nailpolish. Release the button and sew to test the length.
Jun 16, 2009 | Consew 226R-1
Husqvarva 610
This was posted to the sewing machine category. Resubmit in correct category for a solution
Aug 26, 2008 | Husqvarna Designer I
Very old machine needs "rubber band"
please give more information maybe i will be able to help you my email is nicodhem@yahoo.com and please email a photo of the rubber band to my email.good luck my friend.is the rubber that cause the wheel to turn?
Jun 15, 2007 | Necchi 3537 Mechanical Sewing Machine
Sewing Machines Logo
109 people viewed this question
Top Bernina Sewing Machines Experts
Tally Girl
Tally Girl
jnissen
Level 1 Expert
silly01
Level 1 Expert
Are you a Bernina Sewing Machine Expert? Answer questions, earn points and help others
