Question about Garden
Paula How do you remove the tension arm on a L.T 150 John Deere ride-on. Do I need to remove the steering wheel in order to slide the shaft up?
    New Friend:
    Problem Solver:
  • 9 Answers
Paula, what are you calling the tension arm? What is this "arm" suppose to do? What is it that you are trying to accomplish? You may be taking the steering wheel off for nothing. I just can't visualize what you're looking to do, or what is wrong with the machine. You have a steering wheel, steering shaft ext, steering gear assy which has the steering shaft in it, a drag link, then a tie rod. I added a link to a similar type tractor for reference.
http://www.searspartsdirect.com/partsdirect/part-model/Craftsman-Parts/Riding-mower-tractor-Parts/Model-917256660/0247/1509200/10042967/00004?blt=06&prst=0&shdMod=917256660
Posted on Mar 30, 2014
  • 86 Answers
SOURCE: John Deere riding mower SRX95 - Steering wheel is sticking
You need to replace your Ball Joints! On the front steering rods There are two sometimes three !
Posted on May 09, 2009
  • 548 Answers
SOURCE: can't get front wheel off my john deere lawn tractor
remove the cap on wheel then there is a ring or cotter pin to remove then pull wheel off
Posted on Aug 22, 2009
mowerman1857
  • 389 Answers
SOURCE: cant remove steering wheel from john deere rx 95
At the bottom of the steering wheel you should see a screw that goes crossways through the steering wheel and shaft. It will have a nut on one side and a phillips head on the other. Do not try to unscrew this bolt! Use a punch and tap it out from the nut side being careful not to damage the end of it. It is serated and will not turn with a phillips screwdriver. Once this is removed the steering wheel should just pull off. If it doesn't, post your model/serial number and I will check to see why.
Posted on Sep 23, 2009
  • 150 Answers
SOURCE: John deere 68 riding mower steering column won't
Just had same problem with my craftsmen. There is a very inadequate little nylon bushing supposed to keep that shaft stable. When worn out it allows that shaft to move and puts the gears in a bind. It is located on the end closest to arced gear where shaft hooks to drag link. Its a pain.
Posted on Sep 27, 2010
Testimonial: "sounds good will try to fix it thx"
  • 6468 Answers
SOURCE: The steering linkage on my John Deere RX75 Riding Mower needs to be tightened. The steering wheel moves - but does not catch on the steering gears. The tires do move (if I do it by hand) - occasional
the gears are common to wear out where the steering gear meets the drive gear
Posted on Jun 17, 2012
How to I remove the steering wheel from SX75 John Deere riding lawn mower
I have not been able to pin down your exact model but this link is to another model that may give you the info you need. john deere 214 steering wheel removal
Oct 17, 2016 | John Deere Garden
I have a John Derre L130 and the left steering arm has lots of play any suggestions?
it has a steering wheel not steer arms... your issue is either something is bent/broken, the steering shaft is stripped or the steering wheel is just off
Aug 29, 2014 | John Deere Garden
How to remove the steering shaft on a John Deere 125 Automatic riding mower?
should be enough room to get it ontry rolling it past the steering shaft
Aug 25, 2014 | John Deere Garden
Peg perego john deere steering repair
you need spst8119r, let me know if you need me to order you one
Jan 07, 2012 | Peg Perego John Deere Gator HPX Ride on...
John deere 68 riding mower steering column won't turn wheel assembly via arced toothed plate. Wheel assembly OK and greased. Some minor play when rotating steering column with steering wheel, but appears...
Sep 27, 2010 | John Deere Garden
May 08, 2009 | John Deere 420,1020,2010,2020,2510,2520...
John Deere Gator steering
I need to fix a sticking steering wheel
May 07, 2009 | Peg Perego John Deere Gator HPX
Garden Logo
77 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
