I want to connect my samsung montage sph-390 to the internet using the internet connection from my mac powerpc g4 (non-intel) running os x 10.5.8. both the cell phone and the mac are bluetooth enabled and paired and able to connect to each other, but only for file and contact transfer so far. i was wondering if i can use either the internet sharing or bluetooth sharing or some other method? the services available on the cell phone, according to the bluetooth preferences on the mac are: A2DP Source; File Browsing; OPP Service; Phonebook Access PSE; Remote Control; Service Discovery; Voice Gateway.
  • Gene Linard
    Gene Linard Apr 22, 2014
    unfortunately my phone, while bluetooth enabled, is not a smartphone so i can't download apps or anything like that. i was hoping maybe there was a way to use the bluetooth protocol to link the two, then use the "internet sharing" feature on the powerbook to access the internet somehow!?
  •  Mike M
    Mike M Apr 22, 2014
    Go to the Apple Support forums. Also read up on tethering.
  • 3,320 Answers
I am covering for my sister at work right now and im using my 15 inch powerbook g4...i am rooted and try wifi tether here and there but its too slow so since i knew i was goona be working i tried pdanet last night and it worked and thats what im using right now to get online..i just installed pdanet on my phone then clicked bluetooth DUN and then on my powerbook went to bluetooth and clicked set up bluetooth device and let it run through the setup it found the droidx right away...then i had to pair it with a pin....now each time i wanna connect it i just start pdanet bluetooth DUN and then click the bluetooth in my status bar and mouse over where it says droid x and click connect to network....then the "droidx" turns bold and im connected
Posted on Apr 21, 2014
Testimonial: "if i had a smartphone, this solution would be perfect. but i don't. not yet."
JSEhandyman
  • 368 Answers
SOURCE: No longer searches for internet signal/connection.
First, is your Airport Card (wireless networking card) installed? Go to System Preferences, then Network, and see if the Airport Card is enabled. If not, make it so and re-try.
If it shows Enabled (green dot when connected), you should be able to pick-up signals.
I'd also click on the Configure button (when Airport is selected) and check the TCP/IP button - the Configure IPv4 menu should have DHCP selected.
If your card is installed, turned on and not searching for a signal, you may have to break down and buy a new one (eBay or the like).
If you can provide any further details (like precise model info - PowerBook or iBook, what version of the OS, and perhaps some screen-shots of various dialog boxes or error messages - - use key combination of Apple/Command + Shift + 3 for the whole screen, or Apple/Command + Shift + 4 to click-drag-select the area with your mouse/pad), I may be able to provide more in-depth assistance if that's needed.
If this solves the issue, please rate it accordingly.
Thanks in-advance for using Fixya.com,
Jon
Posted on Jan 22, 2009
imend
  • 66 Answers
SOURCE: Connecting another Mac to a laptop
Connect the 2 with a firewire cable. Reboot the Mac you want to read from & hold the T key down while it boots up. A large firewire symbol shows on the screen indicating FireWire Target Mode. The other Mac should be showing up as a firewire drive on the other Mac.
Posted on Apr 06, 2009
  • 396 Answers
SOURCE: internet connection
Depending on what model clamshell you have will determine a few things. One thing to take into considertion is does it have an airport card in it already? I know it does not have USB 2.0 so a dingle is going to be super slow.
The original apple airport cards that went into most of the computers before like 94 or so are the same and will work in your machine too.
Getting to it is a little more of a chore. go to iFixit.com for a detailed directions to install it and they also have items like this for sale. Check on eBay for a known good working pull apple airport card delivered for not more than $75.
Peter
The OS mac osx has the drivers installed on it to support this device so does OS9
Posted on Apr 13, 2009
  • 19 Answers
SOURCE: does the PC/MAC USB file transfer Adapter work to
hi there,
if you want to transfer files from Mac to Mac, you will need a firewire cable. You can not do it with a USB cable.
there are a couple of different types of firewire, and the appropriate ones you will need will depend on the macs you have.
Hope this helps
verb
Posted on Aug 02, 2009
damien729
  • 221 Answers
SOURCE: Help wanted to get rid of Blue Screen on my Mac G4 laptop
Hello
If your hard drive is full, then it can cause this problem. To empty the hard drive, deleting the files that you don't want anymore, you will have to use another Mac, and plug a firewire cable between the two.
Then press on the "T" key on your G4 (for target mode). You should see on the other mac's desktop your hard drive and everything in it. You can use the free software Disk Inventory X to get rid of the files that take too much space and that you don't need.
If that's too complicated, you can also try to boot the mac holding the shift key at startup, that will deactivate extensions and you will probably have access to your desktop. Then empty files and reboot.
Hope this helps
Posted on Aug 05, 2009
Connecting samsung montage to internet using mac powerpc internet connection?
does your mac support bluetooth hotspot ...
there are a few wifi hotspot programs for windows pc but Iam most ceetain macs don't
Apr 17, 2017 | Samsung SGH Cell Phones
How to unlock my apple ibook g4 laptop
You're going to need a bootable disk that came with the machine (or a version of the Mac OS that you know will run on it). You should do a complete custom install, including erasing the original disk.
I think you're going to need Leopard (Mac OS X 10.5) or earlier to get started. You can look for a disk on the internet, or see if you can get one from Apple (try the support forums at apple.com). A G4 is a PowerPC-based machine and isn't supported by the recent OS X versions, which require an Intel-based processor.
Mar 03, 2013 | Apple aluminum 13-inch MacBook laptop-...
I have a mac ibook g4 (os 10.5.8) & when i
I don't know what "kies" is, but what your are describing is that your download is for an intel based Mac. You have a PowerPC chip and cannot run the newer programs that do not have PowerPC support.
Nov 10, 2012 | Computers & Internet
Sims 3 wont install onto my powerbook G4
Sims 3 will not run on a mac that isn't using an Intel based processor. You will have to upgrade from a Power-PC processor in order to use the latest version of sims.
Oct 15, 2012 | Apple 15" PowerBook G4 Aluminum 1.67 GHz...
My Nancy Drew computer game won't work
Hi longview924,
Unfortunately there is no way to make that game run on your mac. Your mac uses the older powerPC architecture (all G3, G4 and G5 macintosh machines use this architecture) but the game requires that you have a mac using the newer intel architecture.
I found the details of the system requirements here:
http://www.buzz99.com/1167/nancy-drew-trail-of-the-twister-system-requirements/
Intel and PowerPC processors are very different in how they work (Intel chips are CISC chips and powerPC chips are RISC chips), which is why there is no way around it. This is also the reason why apple dropped support for the powerPC architecture in mac OS 10.6 upwards.
Without meaning to sound harsh, it may be time to consider an upgrade - macs are very expensive but the intel macbooks are leaps and bounds faster than the powerPC range :)
Jul 03, 2012 | Video Game Consoles & Games
How to conect iphone to itunes
All you should have to do is connect the iPhone to the computer via iPhone connector cable. If that does not solve the problem, what computer and operating system are you using. The iTunes requirements are as listed below and can also be found on www.itunes.comMacintosh Hardware
  • Mac computer with an Intel, PowerPC G5 or G4 processor and 512MB of RAM
  • To play Standard Definition video from the iTunes Store, a 1.0GHz PowerPC G4 or faster processor and 512MB of RAM is required
  • To play HD video, an iTunes LP, or iTunes Extras, a 2.0GHz Intel Core 2 Duo or faster processor and 1GB of RAM is required
  • Screen resolution of 1024x768 or greater; 1280x800 or greater is required to play an iTunes LP or iTunes Extras
  • Broadband Internet connection to use the iTunes Store
  • Apple combo drive or SuperDrive to create audio, MP3, or back-up CDs; some non-Apple CD-RW recorders may also work
  • Apple SuperDrive to back up your library to DVDs; some non-Apple DVD-RW drives may also work
Macintosh Software
  • Mac OS X version 10.5 or later
  • Safari 4.0.3 or later
  • 200MB of available disk space
Dec 09, 2011 | Apple iPhone 3G
Install Snow Leopard on a macmini Power-PC ?
If it is a G4 PowerPC processor No
If it is an Intel Processor Yes
Jan 06, 2010 | Apple Power Mac G5 Desktop
Popcorn3
Not unless that dell is running a Mac OS.
Popcorn 3 System Requirements
  • Macintosh computer with PowerPC G4, G5, or Intel® processor
  • Mac OS X v10.4.10 or higher
  • 300 MB of free disk space to install
  • Up to 15 GB of temporary free disk space during usage
  • QuickTime 7.1.6 or higher
Sorry about that!
Apr 10, 2009 | Dell Dimension XPS PC Desktop
Mac os x Snow Leopard
Apple's next major Mac OS X released, will focus solely on under-the-bonnet changes, the Mac maker has revealed. PowerPC-based machines might be left in the cold?
Apple is promising a version of Mac OS X that "dramatically" reduces the amount of storage space the operating system requires. Undoubtedly, some of that will come from the re-engineered core technologies, but it's hard to conclude that Snow Leopard's release will come not as a "universal" binary capable of running on both Intel and PowerPC processors, but as a single-platform product.
Universality has been handy in ensuring users can run the same installed code on both Intel- and PowerPC-based Macs without resorting to emulation. But just as Leopard lacks the ability to run Mac OS 9 apps - a feature present in previous Mac OS X releases - there will come a time when Apple drops Rosetta, its PowerPC emulation mechanism.
Early rumours concerning Snow Leopard suggested PowerPC support was to be dropped, though that was subsequently denied by Apple.
How can these two claims be reconciled? Only by Apple shipping native-only versions of Snow Leopard. Owners of Intel-based Macs will finally be free of all that redundant PowerPC code in the system software, freeing up space for, as Apple puts it, "their music and photos".
With any luck, Apple will finally allow users to readily remove unwanted languages from their system software, a process that can free up a fair bit of hard drive space too.
Apple won't be ditching support for universal binaries, or PowerPC Macs, because there, for now, too many of them out there. But if Snow Leopard's Grand Central technology does as promised and improves the OS' ability to work with multi-core CPUs, Intel-based Macs are going to shoot even further ahead of old G5 and G4 models.
Apple is also promising that Snow Leopard will offer more pervasive support for 64-bit computing, leading to the ability to support up to 16TB of memory, though the motherboard hardware to do this isn't there yet. In any case, limits to CPU memory controllers mean they don't physically support the full range of 64-bit memory addresses, only a subset.
Snow Leopard will also feature QuickTime X, a "streamlined" revamp of Apple's multimedia foundation, and OpenCL (Open Compute Library), a non-proprietary programming system for running complex code on a machine's graphic chip(s).
Oh, and it'll get Microsoft Exchange support too, in a bid to make Macs more business-friendly.
Aug 27, 2008 | Apple Mac OS X 10.4
Computers & Internet Logo
66 people viewed this question
David Payne
David Payne
