Question about Sony DVP-SR200P DVD Player
TRAY LOCKED HENCE IS RESISTANT TO OPEN
NO.6625135 CD/DVDPLAYER~AC110-240V 50/60HZ 12W
  • 383 Answers
BE VERY VERY CAREFUL WHILE TRYING IT :
(1) USE SOME HARD PLASTIC NEEDLE.
(2) TRY TO LOCATE A VERY LITTLE WHOLE BENEATH YOUR DVD TRAY.
(3) PUSH YOUR NEEDLE IN THAT WHOLE SLOWLY, GRADUALLY INCREASING PRESSURE.
(4) IT WILL CAUSE THE TRAY TO OPEN, ONCE IT OPENS A LITTLE, YOU MAY SLOWLY PULL IT TOWARDS YOURSELF AND REMOVE YOUR CD/DVD FROM THERE.
(5) REMEMBER TO TURN OFF YOUR PLAYER FROM MAINS BEFORE TRYING.
(6) IF YOU FIND YOURSELF UNCOMFORTABLE DOING SO, CALL YOUR CUSTOMER CARE CENTER / SERVICE CENTER. IF WARRANTY HAS EXPIRED, YOU MAY CALL ANY OUTSIDE PROFESSIONAL OR A COMPUTER HARDWARE PROFESSIONAL.
BE VERY VERY CAREFUL NOT TO INSERT ANY GOOD CONDUCTOR OBJECTS IN THAT TRAY WHOLE OR YOU MAY GET AN ELECTRIC SHOCK ALSO!!!
Posted on Mar 29, 2014
How do I open my CD Tray and remove a trapped DVD? The Display shows "Locked", everytime I try to press eject button on the Receiver.
Unplug the machine. Have a look behind the tray flap. there should be a very small hole to push a paperclip or similar into to release the tray.
Mar 08, 2015 | Televison & Video
Why does my cd tray keep opening in my laptop. its apresario cq62-421nr
The sensor inside the cd writer does not recognize the closing of the tray. Hence it keeps opening all the time. To stop it from opening hold the tray pressed when it closes for some time. The tray may stop opening. Sometimes it works. Else you have to repair or replace the CD writer.
sonsunny
Jul 04, 2011 | Computers & Internet
Door keeps opening.
Replace the loading tray belt, it is quite a common problem on CD Players using the same Sony transport mechanism as your Arcam.
The belt loses its tension and cannot fully load and then spits the tray open.
When you try to load a CD you should be able to hear a whirring sound after closing the tray and that's the motor trying to lift the laser mechanism at full travel but is unable to hence not enough tension on the belt.
Hope this helps.
Jan 18, 2011 | Arcam Alpha 7SE
When i press the eject button ,it appears LOCKED in the dvd screen, plz help me to unlock it
takes; a flashlight and a sewing neddle or hat pin
to fix: using the flashlight, locate the pin hole located somwhere just below the disk tray. insert the neddle into the hole, and give a firm push . be sure to keep the neddle straight, as failure to do so will usually cause you to miss the carrage arm, hence the tray will not be released. when done correctly, you will feel the mechanisem release and traval inward, and the tray will pop open about an inch or so.
Nov 22, 2009 | JVC Televison & Video
CD tray "Locked"
Dear Alberto,
Please check the underside of the system . The transportation lock at the bottom may be locked manually .
ramesh22
Jun 07, 2008 | Sony MHC-EC70 Shelf System
Code for multi region free
I figured out the code, it's printed incorrectly many places.
1 - Turn on DVD Player
2 - Press Open/Close button - open tray
3 - Press "8888"
4 - Put a DVD in the tray (from outside your region)
5 - Press Open/Close button - close tray
6 - Voila! It plays!
Works on mine!
Apr 01, 2008 | GPX D1816 DVD Player
Tray will not open!
press &hold stop then press the eject button.
Nov 04, 2007 | JVC MX-KB30 CD Shelf System
Trays locked
remove the tray out & put the grease on gears under the tray
Apr 01, 2007 | Philips CDR795 2-Disc CD Recorder
CD tray doesn't open
if the unit actually tries to open but does not, it is not locked. a locked unit does not even try to open. it sound like a mechanical misalignment. take it back to get a new one, since it's only 2 days old.
Nov 12, 2006 | Sony CMT-CPX22 CD Shelf System
Locked Cd Tray
The solution is to turn the machine onto standy and then hold the 'display' button for a few seconds, and voila, the trays are unlocked... geni-arse!
Aug 05, 2006 | Philips MC-90 CD Shelf System
Sony DVP-SR200P DVD Player Logo
43 people viewed this question
Top Sony Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
