Bauhn 55 inch tv wont display first step set up. I just get a blue screen. tried a dvd player and i have sound only no picture.
Nothing is displayed when i turned it on for the first time
  • 383 Answers
Maybe you've turned on Blue Screen Mode, contact Customer Care of this Manufacturer.
Posted on Mar 29, 2014
  • 192 Answers
SOURCE: Sony KDL 46V2500
This set does have a video problem. If it was bought locally, then, the retailer may have a 30 day return policy. If bought online or cannot be returned, then, contact Sony, for a service center in your location: http://eservice.sony.com/webrma/web/index.do Either way the set is to new to have a problem and you should get it resolved as soon as possible.
Posted on Aug 05, 2007
jdbouncer
  • 72 Answers
SOURCE: Blank screen, cannot get menu to display, but sound works
Does the lcd screen have a glow to it ? Or is it really dim if u get real close to screen u can see images moving ?
it it has a glow to it you panel lighting is fine but you control board is bad. If you have a dark screen and see faint images you panel back lighting is out u can check the power with a meter at the connection to inverter board on panel.
Posted on May 06, 2008
SOURCE: I am trying to use my 32 inch Insignia HDTV as the
--==<[ DVI to VGA vs. DVI to HDMI ]>==-- Caleb, what you really want to do to get your Macbook working with the Insignia HDTV is to >RETURN< and exchange the DVI to VGA adapter for a DVI to HDMI adapter. This is assuming your hdtv has HDMI inputs (which I'm pretty sure all the insignia ones do! I own a 1080p 32" Insignia HDTV and it has 4 HDMI's). The reason you should exchange them is that DVI and HDMI are essentially the same connector (and a better connection than VGA), the only difference between DVI and HDMI is that HDMI additionaly contains two audio channel wires. HDMI (which is a smaller version of DVI) is a digital signal and will give you perfect picture quality compared to the analog 'pc vga' type connector you were converting it to with the adapter you described (not to mention it will probably just work immediately since there is intelligent 'handshaking' that goes on with an HDMI connection, so it will tell your HDTV what resolution to use rather than it having to guess....)
I am guessing by now you solved the problem since it was in June that you posted and it's now November as I write this, but I figured you're probably not the only one who tried hooking it up that way. And most people don't seem to realize that DVI and HDMI are essentially the same type of connection, just smaller, with audio added. So someone will most likely benefit from this posting =)
Best regards, -=VRMan3D=- http://www.vrman3d.com <- 3D Screensavers and in browser 3D Mac/PC gaming for free!
Posted on Nov 13, 2009
Raditronic
  • 196 Answers
SOURCE: My Panasonic tv displays only a thin blue horizontal line
This is vertical problem. The tv have a cold solder in vertical ic or ic is bad.
Posted on Apr 22, 2010
SOURCE: No picture on Memorex MLTD3222 flat panel LCD.
I recently got this tv from somone because of this exact problem. I have found a solution that works for mine. You can check to see if it works for you also. What I did was take of the back cover. 3 screws (1 big one in the center and 2 little ones below it). Next look at the power board. If plugged in and turned on the red light on the power board should be lit up. If so your power board is fine. Next find the component that has 4 switches. I manually turned these on and turned the tv on and it worked! Has been working ever since!
Posted on Jun 27, 2010
My 19 inch Emerson tv screen has went blue an no picture isn't showing
Sounds like a bad connection to whatever you have it connected to (cable box, dvd player, etc). Check the connection and then replace cables.
Feb 13, 2015 | Emerson LD195EM8 19 in. LCD TV
My DVD is playing my videos in black and white .. It's a Panasonic tv model is tc-L32c5
follow the steps. God bless you
Insert a DVD lens-cleaning disc into your player and press "Play" to clean the DVD laser, eliminating picture problems due to read errors. Do not use a CD cleaning disc as the brushes on these discs can damage your laser.
  • 2 Wipe your DVDs clean of all visible marks and dirt using a lint-free cleaning cloth moistened with rubbing alcohol or glass cleaner. This further fixes read errors which can damage the quality of picture and sound.
  • 3 Disconnect your DVD player from the TV or receiver you have it connected to. Reconnect the DVD player directly to the "AV" or "Video In" port of your television, firmly pushing the plug into place, to eliminate possible noise from the receiver and ensure a clean connection.
  • 4 Connect your DVD player using an S-Video, component video or HDMI cable. Standard yellow/red/white RCA connectors cannot carry the high-quality signal that DVD discs are capable of transmitting, and will display a particularly poor picture on flat-screen high definition televisions. Use an HDMI cable, if your television and player support it, or a red/blue/green component video cable.
  • 5 Press "Setup" on your DVD remote and enter "Picture Settings." Make sure your DVD player is set to display images in the correct screen format ("Widescreen" or "16 x 9" for HDTV sets, "Standard" or "4 x 3" for older square sets) and scan mode. If you are using a DVD player that supports "Progressive Scan" on an HDTV or flat-screen set, activate this setting; for older sets, choose "Interlace" if given a choice.
  • Nov 14, 2012 | Televison & Video
    My bauhn TV screen stopped working. DVD plays sound but no picture. Can the TV be reset or rebooted
    You can try unplugging the units--no picture often means the DVD has a dirty or failed optical unit.
    Aug 30, 2012 | Televison & Video
    The Yamaha RX-V463 AV does not playsound from the blue ray player
    "I am also having difficulties in try to display the yamaha set up menu on the tv."
    According to the manual the display menu for TV will not work with HDMI hook up.
    I also have a Panasonic HD TV and can't get TV sound through my Yamaha AVR on "TV Sound" mode.  Trying to use HDMI cable for this also.  Do I need a digital optical cable or do I not have something set right?
    Apr 07, 2009 | Yamaha RX-V463 Receiver
    DVD plays but nothing is displayed on screen.
    1.make sure that the video input/output are plugged in.
    2.make sure ur tv is programmed to vieo 1 2 3 etc.
    May 07, 2008 | Delphi MV10015 Car DVD Player
    Our TV screen no longer displays pictures, it just displays a blue screen and sound. The inbuilt DVD player still works with pictures and sound. Whay can I do to fix this?
    Without the make and model number, I can no tgive you specifics. In general there are switches that control the source of video and audio signals internal to the set. If the switching chip for the video section is defective, this can occur. Post the make and model and I'll try to provide more details.
    Thanks,
    Dan
    Apr 17, 2008 | Televison & Video
    Grey Screen
    Try the reset on the remote. Press this key twice to restore factory settings. The TV will automatically start Channel Search and clear all customized settings. These features will automatically reset: ? Picture/Sound Adjustments: Color, Tint, Contrast, Brightness, Sharpness, Color Enhancer, Tone, and Surround Sound ? Channel Memory ? Audio to Stereo ? Caption to OFF ? V-Guide to OFF ? Aspect Ratio to 4:3 (normal) ? Menu Language to English ? Sleep Timer (if previously set) ? Video to TV (if previously set) If desired, personal settings can be made again using the menu options
    Jun 23, 2007 | Sanyo DS32224 TV
    Can't get the remote to display the set up screen
    If you have the original remote and the unit wont let you in the menu, then Try first ti reset the machine by unplugging it for 24 HOURS. If that does not reset the microprocessor then the eeprom IC or the microprocessor is bad.
    Sep 30, 2006 | Samsung DVD-V1000 DVD Player/VCR
    No picture but has sound
    Hi If your t.v.has built-in blue screen when there is no signal, then the DVD may have been accidentally switched to progressive scan mode, or defaults to that setting if new. If your T.V. is not capable of displaying in progressive scan mode, you will just get a blue screen. If you have an older tv, without blue screen, then connect it to that, and if you get a black and white split screen when you turn on the DVD, then progressive scan is the problem. Check the manual for the DVD player for the procedure to get out of that mode, and it should then work. If you still have no video, and you are using the yellow composite video jack on the back of your DVD player, then it must be brought in for service. Good Luck!
    Aug 14, 2006 | Zenith DVB312 DVD Player
    Can't see full picture on TV
    sounds like the dvd players set for differant picture format like full screen compared to wide screen settings. Look in the Menu of the tv as well as the dvd player
    Apr 01, 2006 | Panasonic TH-37PD25U/P 37 in. EDTV-Ready...
    Televison & Video Logo
    138 people viewed this question
    Top Televison & Video Experts
    Electro Med Services...
