Question about Toshiba MK1234GAX 120GB 5400 RPM 8MB Cache 2.5" ATA-6 Notebook Hard Drive -Bare Drive
I plugged in a 120gb internal toshiba mk1234gax hdd2d16 hard drive and when turn laptop on it says SMART failure predicted on hard disk. how should i go about fixing this
Im trying to find a way to fix this hard drive so I can use it in my laptop tells me failure predicted to back up files and replace hdd. is there a way to possibly fix the hdd so it can be used?
  • 383 Answers
Try turning off SMART in MotherBoard Settings (BIOS Settings) and if it won't work, Call a Computer Professional. If Warranty is alive, Call Authorized Service Center.
Posted on Mar 29, 2014
My Toshiba hard disk HDD2D16C not showing in computer and sounding clug clug... plz help me.
At this point the hard is dead. that sound is the head tring to read and not working. Data recovery is a long shot it this point as well.
Aug 29, 2011 | Toshiba 120GB (MK1234GAX) 5400rpm 8MB...
I have external toshiba harddisk MK1234GAX .when i connect to my laptop its not detecting only red and green light blinking..its not showing on my computer..i need all the files in tht hard disk..please...
click start control panel administrive tools ,computer management ,device manager scroll down universal serial bus controllers you should see a yellow question mark?
right click to reinstall drivers
make sure the lead/s that attach to this drive have a secure seating and are not bad/faulty the light on only tells that its getting power it might not be getting enough power you might test the lead/s or
just replace the cable of the hard disk, when you plugged the external disk drive you got that windows could recognize the USB device change the cable everything should work fine again, sometimes the wires inside the cable will be damaged due to bending or stretching or placing heavy equipment upon the cable,
hope this helps
Apr 21, 2011 | Toshiba 120GB (MK1234GAX) 5400rpm 8MB...
Toshiba MK1234GAX 120GB hard disk creating problems
Hello, verified if your hard disk is properly installed in the closure, don't forget to format your hard drive in NTFS. if your problem persist maybe need to check your USB connections in device manager.
Jul 10, 2010 | Toshiba 120GB (MK1234GAX) 5400rpm 8MB...
Hard Disk Problem
That failure is predicted by the SMART reporting system. Its a status chip on the drive that reports to apps that can read the smart data from the hard drive. Its not always accurate but it usually is.
Time backup your data on that drive ASAP and then buy a new drive.
Sep 07, 2009 | Toshiba MK1637GSX 160 GB IDE Hard Drive
I have a Toshiba hard drive model HDD2D16 C, Disk drive MK 1234GAX. When i connect it to my PC, it says that my PC cannot read it and red LED is always on the HD, Already try different USB cable and...
you can recover your data only if you have not dropped the disk down... there are many recovery software through which you can get back your data and even your disk
Jul 30, 2009 | Toshiba MK1234GAX 120 GB ATA-100 Hard...
Smart failure predicted on hard disk toshiba mk4025gas ( pm )
This means your hard drive is bad or about to go bad and needs to be replaced. If you can still access the drive, immediately back up anything important to you. You will then need to replace the hard drive. Thanks and please take a moment to rate this solution with a fixya rating, even if the news isn't what you wanted to hear. Thanks! :c)
Feb 14, 2009 | HP Business Notebook NX9110 Notebook
USB Hard Drive Problems
HI,
I have a TOSHIBA MK1234GAX USB Device.
My USB Controller finds it an I see it in my computer devices, but it do not gets a hard drive letter, so I can not access to my files on it.
Yesterdey it worked properly.
Can You explain me what happend and how can I get to my files?
Jun 13, 2008 | Toshiba 120GB (MK1234GAX) 5400rpm 8MB...
120gb toshiba external hdd pwer failure
if work 2 ,3 min fine. ot may be a cable error or encloser circuit error, remove the hdd from enclose and plug to pc and check
Sep 23, 2017 | Toshiba 120GB (MK1234GAX) 5400rpm 8MB...
Compaq laptop C310 T1300
here's what you should do.. first, as mentioned, you should backup all your important files in another drive or an optical drive... once you have done it, format your hard drive and perform scans to check the error.. during scan, you will see errors on it and you may not be able to fix it since the drive is internally damaged.. purchase a new one ok? just make sure to backup all your files..
Jan 23, 2008 | Compaq Armada E500 Notebook
Open Questions:
See all Toshiba MK1234GAX 120GB 5400 RPM 8MB Cache 2.5" Questions
Toshiba MK1234GAX 120GB 5400 RPM 8MB Cache 2.5" ATA-6 Notebook Hard Drive -Bare Drive Logo
60 people viewed this question
Top Toshiba Audio Players & Recorders Experts
James DuPont Jr
James DuPont Jr
 Grubhead
Grubhead
Are you a Toshiba Audio Player and Recorder Expert? Answer questions, earn points and help others
