Unlock mmx2010l ser. loc
What does a LOC code mean?
loc has to do with control lock:
control lock (press and hold)
to lock the controls between or during cycles, press and hold the add steam button for 5 seconds. loc will be displayed if you attempt to wake up a "between cycle" locked unite and loc will alternate with cycle time remaining in a "during cycle" locked unit. repeat to unlock the controls when you are ready to operate the washer. use this feature to reduce the likelihood of accidental operation by children.
Sep 03, 2015 | Kenmore Dryers
How to unlock my stereo with the message "" LOC?
Uriel, check this link. I haven't had any experience with the problem, but this person seemed to be able to find a solution. http://www.dieselplace.com/forum/76-speciality-forums/81-electrical/40705-here-how-unlock-delco-theftlock-radio-displays-loc.html
Jun 16, 2014 | Ac Delco Car Audio & Video
Whirlpool loc
From a google search the following is copied:
LOC is a control panel lock not a door lock, see below.
The Control Lock shuts down the control panel pads to prevent
unintended use of the ovens.
When the control is locked, only the CLOCK, TIMER SET and
TIMER OFF pads will function.
The Control Lock is preset unlocked, but can be locked.
To Lock/Unlock Control: Before locking, make sure the ovens,
Timer and Timed Cooking are off. Press and hold START/ENTER
until a single tone sounds and "Loc," a picture of a lock and
"START?" will appear on the oven display, about 5 seconds.
Repeat to unlock and remove "Loc" from display.
If the above does not work have you tried removing power from the uit for a few minutes to see if it will reset.
________________
http://forum.appliancepartspros.com/oven-repair-including-ranges-cooktops/499415-whirlpool-double-oven-shows-loc-display.html
Jan 26, 2018 | Ovens
My fridgidaire affinity dryer has loc error and will not let me start it
The control is locked to avoid having someone accidentally start or stop the dryer. Press and hold the Options and Select buttons for 10 seconds or until the "LOC" on the display is cleared. Locking the control is done the same way it is unlocked.
Mar 04, 2011 | Dryers
Push any button and 'loc' flashes seems to be locked out
Press Options and Select at the same time and hold for 10 seconds or until "LOC" is no longer displayed to unlock the controls. Press and hold the same buttons for 10 seconds until "LOC" is displayed alternately with the estimated cycle time to lock the controls. Unplug the machine for at least half an hour, if pressing the buttons does unlock the controls, to forcibly reset the machine control and eliminate the possibility of an electronic glitch.
Oct 31, 2010 | Frigidaire Affinity ATF7000E Front Load...
Washer won't run. It beeps 3 times and flashes "err" and "LOC".
HI. The term"LOC" will be an indication of the "Child Locking" feature that has been activated either by mistake or intentionally. This is a safety feature to prevent unwanted starts when children are present.
To unlock the controls,press "Options and Select" at the same time and hold for 10 seconds until ”LOC” is no longer displayed.
  • NOTE_ If the release procedure doesn't unlock the unit and the letters LOC continue to appear, this will be a strong indication of a severe fault within the main control board. try to power cycle the unit if this is the case. if the power cycling doesn't produce good results, replace the main control board assembly.
Aug 14, 2010 | Frigidaire ATF6000ES Front Load Washer
Radio stuck on loc
power radio on then hold 2 and 3
May 21, 2009 | 1999 Saturn SL
LOC Blinking
Control Lock
To avoid having someone accidentally start or stop the
washer, press Options and Select at the same time and
hold for 10 seconds until “LOC” is displayed alternately
with the estimated cycle time. To unlock the controls,
press Options and Select at the same time and hold 10
Jun 05, 2008 | Frigidaire Affinity ATF7000E Front Load...
LOC Error
Your child LOCk feature has been activated and will not let you do any further actions until you unLOCk it. Look in your users guide for unLOCking instructions.
Feb 10, 2008 | Frigidaire GLEQ2152ES Electric Dryer
Open Questions:
AVAST Setup installations 18OO935-63l8 CONTACT AVAST TEC-H SUPPORT CAR-E AVAST ANTI-VIRUS tech support contact number.AVAST ANTI-VIRUS technical s support contact number.AVAST ANTI-VIRUS customer contact phone number.AVAST ANTI-VIRUS customer care contact number.AVAST ANTI-VIRUS tech s support contact number.AVAST ANTI-VIRUS VIRUS technical s support contact number.AVAST ANTI-VIRUS customer contact phone number.AVAST ANTI-VIRUS customer care contact number.AVAST ANTI-VIRUS techs support contact number.AVAST ANTI-VIRUS technical s support contact number.AVAST ANTI-VIRUS customer contact phone number.AVAST ANTI-VIRUS customer care contact number.AVAST ANTI-VIRUS techs support contact number.AVAST ANTI-VIRUS technicals support contact number.AVAST ANTI-VIRUS customer contact phone number.AVAST ANTI-VIRUS customer care contact number .AVAST ANTI-VIRUS tech s support contact number.AVAST ANTI-VIRUS technical s support contact number.AVAST ANTI-VIRUS customer contact phone number.AVAST ANTI-VIRUS customer care contact number.AVAST ANTI-VIRUS techs support contact number.AVAST ANTI-VIRUS technicals support contact number.AVAST ANTI-VIRUS customer contact phone number.AVAST ANTI-VIRUS VIRUS customer care contact number.AVAST ANTI-VIRUS techs support contact number.AVAST ANTI-VIRUS technicals support contact number.AVAST ANTI-VIRUS customer contact phone number.AVAST ANTI-VIRUS customer care contact number.AVAST ANTI-VIRUS contact contact number.AVAST ANTI-VIRUS technical s support contact number.AVAST ANTI-VIRUS customer contact phone number.AVAST ANTI-VIRUS customer care contact number.AVAST ANTI-VIRUS techs support contact number.AVAST ANTI-VIRUS technical s support contact number.AVAST ANTI-VIRUS customer contact phone number.AVAST ANTI-VIRUS customer care contact number.AVAST ANTI-VIRUS techs support contact number.AVAST ANTI-VIRUS technicals support contact number.AVAST ANTI-VIRUS customer contact phone number.AVAST ANTI-VIRUS customer care contact number.AVAST ANTI-VIRUS techs support contact number.AVAST ANTI-VIRUS -VIRUS technical s support contact number.AVAST ANTI-VIRUS customer contact phone number.AVAST ANTI-VIRUS customer care contact number.AVAST ANTI-VIRUS techs support contact number.AVAST ANTI-VIRUS technical s support contact number.AVAST ANTI-VIRUS customer contact phone number.AVAST ANTI-VIRUS customer care contact number.AVAST ANTI-VIRUS techs support contact number.AVAST ANTI-VIRUS technicals support contact number.AVAST ANTI-VIRUS customer contact phone number.AVAST ANTI-VIRUS customer care contact number.AVAST ANTI-VIRUS tech s support contact number.AVAST ANTI-VIRUS technical s support contact number.AVAST ANTI-VIRUS customer contact phone number.AVAST ANTI-VIRUS customer care contact number.AVAST ANTI-VIRUS techs support contact number.AVAST ANTI-VIRUS technicals support contact number.AVAST ANTI-VIRUS customer contact phone number.AVAST ANTI-VIRUS VIRUS customer care contact number.AVAST ANTI-VIRUS techs support contact number.AVAST ANTI-VIRUS technicals support contact number.AVAST ANTI-VIRUS customer contact phone number.AVAST ANTI-VIRUS customer care contact number.AVAST ANTI-VIRUS contact contact number.AVAST ANTI-VIRUS technical s support contact number.AVAST ANTI-VIRUS customer contact phone number.AVAST ANTI-VIRUS customer care contact number.AVAST ANTI-VIRUS techs support contact number.AVAST ANTI-VIRUS technical s support contact number.AVAST ANTI-VIRUS customer contact phone number.AVAST ANTI-VIRUS customer care contact number.AVAST ANTI-VIRUS techs support contact number.AVAST ANTI-VIRUS technicals support contact number.AVAST ANTI-VIRUS customer contact phone number.AVAST ANTI-VIRUS customer care contact number.AVAST ANTI-VIRUS techs support contact number.AVAST ANTI-VIRUS -VIRUS technical s support contact number.AVAST ANTI-VIRUS customer contact phone number.AVAST ANTI-VIRUS customer care contact number.AVAST ANTI-VIRUS techs support contact number.AVAST ANTI-VIRUS technical s support contact number.AVAST ANTI-VIRUS customer contact phone number.AVAST ANTI-VIRUS customer care contact number.AVAST ANTI-VIRUS techs support contact number.AVAST ANTI-VIRUS technicals support contact number.AVAST ANTI-VIRUS customer contact phone number.AVAST ANTI-VIRUS customer care contact number
Jul 17, 2018 | Contact Computers & Internet
Computers & Internet Logo
44 people viewed this question
David Payne
David Payne
