Question about HP Office Equipment & Supplies
Error 52.1.c hp4600
I'm working on the 2004 Jeep Grand Cherokee 4.7 showing error codes
lashes 52 and 54 ,you do mean flashes ? What flashes ? Check engine light doesn't flash codes .
Apr 24, 2017 | Jeep Cars & Trucks
Show error 52.00
Note this a not something users can repair themselves. It is a fault with scanning motor. may need motor or whole scanning assembly to be replaced. Only service centre can perform this.
HP LaserJet 4200 and 4300 Series Printers - Numerical Error Messages 52.XY PRINTER ERROR For help press? alternates with 52.XY PRINTER ERROR To continue turn off then on
Description
A temporary printer error has occurred.
X Description 0- Scanner error
1- Scanner startup error
2- Scanner rotation error
Action
  1. Press the (Select) button to continue.
  2. Turn the printer off and then turn the printer power on.
  3. If the message persists, contact HP Customer Support.
The laser scanner speed is incorrect. X description: 1 = Scanner startup error 2 = Scanner rotation error.
1. Press GO. The page containing the error will automatically be reprinted. 2. Turn the printer off and then on. 3. Reseat cables to the laser/ scanner and engine controller. 4. Replace the laser/scanner. HP LaserJet 4200 and 4300 Series Printers Numerical Error Messages
Apr 16, 2016 | HP LaserJet 4350n Printer
Hwo do i repair error 52 in hp leserjet pro 400 m 410 dn
52 error is scanner related not formatter. HP has had issues with some serial number ranges of this printer having bad scanners which they will replace. You should contact HP regarding this problem.
Sep 09, 2014 | HP LaserJet Pro 400 M401DN Laser Printer
Scanner error 52 turn off and turn on
Sir/Madam
Unfortunately there's no troubleshoot with a 52 error. As it implies it's usually the scanner bad. It sits up top- under the top cover. It connects to the Formatted Board on the left side. and there's 2 connector s at the scanner itself.
So if Your HP Printer is Under warranty ( 12 Months ) Then I Suggest You Go To Official authorized HP shop for your HP Printer Problem and Troubleshoot or Go To Official HP Printer Website To Update HP Printer Software and Driver,Or You Update It From Official Below URL Link:
http://h30499.www3.hp.com/t5/Printers-LaserJet/HP-Laserjet-P2055d-error-message-quot-52-Scanner-Error-Turn-off/m-p/5905671#M207987
or
Or
In Case You Having Still Problem Then Follow Us On:
HP Printer Support
Feb 13, 2014 | HP LaserJet 3055 All-In-One Printer
HP Laserjet 4600N printer - come up with error 53.11.03 ERROR DIMM 2 BANK 0 Any ideas how to resolve this please
That is the memory for your printer. It can be easily replaced by accessing a panel on the side. http://business.fsu.edu/tech/printermanuals/laserprinters/HP4600.pdf See page 211 and 213. Depending on document sizes and number of users who print to it you may be able to remove the bad DIMM without needing to replace it.
May 11, 2011 | Office Equipment & Supplies
I intialized my hp4600 and it seems to be hung in the initialized mode
just check is the printer power cable is connected to a wall power or any power surge.
>> if connected to power surge/ dtrip//
>> unplug it and connect to wall power outlet.
>> some time this problem occours..when there is low voltage supply to printer
Dec 16, 2009 | HP LaserJet 4600dn Color Printer
Install hp4600 dc controller
This is not exactly an easy task. But here are the step by steps
The following procedures explain the removal and replacement of internal components DC controller shield 1 Remove the following assemblies: ● Print cartridges and ETB.(ETB Is the black belt) ● Rear cover. ● Top cover. ● Rear top cover. ● Left cover. 2 Remove nine screws (callout 1). A tenth screw might be located on the rear of the printer at the bottom of the DC controller shield (callout 2). If that tenth screw is present, remove it. 3 Remove the DC controller shield. c0a7a70.jpg
Behind this shield is the DC controller board; It has quite a few wires connected to it, as it's the main controller for the printer.
1089df3.jpg Be sure to reconnect every wire or the printer will not work.
The correct Part Number for the LJ4600 (only) for the Dc controller is RG5-6391.
Good luck :)
Aug 31, 2009 | HP LaserJet 4600 Printer
Error 52 on ricoh FT3213.
error code 52 on ricoh ft3213, that's mean heating element burn out , such as heater lamp, thermister , thermo fuse.
Dec 09, 2008 | Ricoh Aficio 1035 Copier
51 people viewed this question
Ben Johnson
mukhtar21 shaikh
mukhtar21 shaikh
