Question about Vehicle Parts & Accessories
How to replace honda pilot steering lock assembaly
Car ignition would turn
    Habit-Forming:
  • 179 Answers
Disconnect the battery.remove the lower dash cover.remove the steering column cover. locate 4 bolts holding the steering column to body and remove.don't let the column fail and brake wires.disconnect any wire if you need to lower the column.on upper part of ignition look you will find 2 bolt with round head broken sight in center.use chisel and lose the 2 bolt.remove the old look and install the new one. thigh slowly 2 bolt alternate to insure the look tight even on both side.on end the security head will break.lift the column and thigh the 4 bolt.connect any wire disconnected before.install the covers.
good luck
Posted on Apr 04, 2014
The switch bolts are bolt torque off, that means when you tighten the bolt, the head snaps off, at a preset torque setting leaving the round dome carriage bolt like fitting head.
You grind a slot, or chisel the bolt head off.
Remove the switch, then there are three pins that need to be punched out, of the switch to allow the cylinder to be removed.
Mar 29, 2014 | Vehicle Parts & Accessories
MY KEY DON'T TURN THE IGNITION, IS LOCK
The solution may be just to grab the steering wheel and turn to left or right, some slight resistance may be felt as you turn, and at the same time try to turn the key in the ignition.
Jun 23, 2012 | 2005 Honda Pilot
Him!..My name is san, and i have 2003 honda pilot and i been having problem with the ignition,first the key wont go in the ignition for like two days and then finally i get the in ignition and now key wont...
Your steering wheel key cylinder is bad. You will need to replace it, but when you replace the key cylinder the Honda Dealer might need to reprogram all your keys to the car again or the car will not start.
good luck
Jun 28, 2011 | Honda Pilot Cars & Trucks
Can I tighten the ignition switch in a Honda 2004 pilot? I can't turn the key unless I push the switch forward in the column. It appears to be lose and it I adjust the switch it starts
on a honda you have to push the key/lock inwards to turn/start the car( stops you turning the key when already running)and when you pull the key out it engages the steering lock..so without me actually turning the key i do not see you have a problem...
Sep 15, 2010 | 2004 Honda Pilot
My 2003 honda pilot is difficult to shift into drive
There could be a number of issues with a Honda Pilot not shifting into drive. In fact, I had this problem with my 2003 Honda Pilot two weeks ago and had to replace my transmission. More than 100,000 2003 Honda Pilots were recalled in 2004 because of a transmission problem -- was your Honda part of that recall? If so, Honda may help you with some of the costs.
If the problem is not with the transmission, I suggest making sure that your steering column is not locked. You will also notice that on the top of the steering column is a small plate. If you remove the plate and press down with a coin, you can unlock the steering column, enabling you to shift into drive.
Hopefully these solutions will help...but be sure to see your auto service shop for more details on your situation.
May 15, 2010 | 2003 Honda Pilot
Unable to turn key in ignition to start 2003 Honda Pilot .
Your ignition lock cylinder probably fell apart. They get worn out and the tumblers inside fall out and leave the cylinder inoperable. Get your lock cylinder replaced and you'll be good as new.
May 07, 2010 | 2003 Honda Pilot
Resetting a Key fob on 2007 Honda Pilot
to program a key fob- get in vehicle and close all doors. insert key into ignition, have all the key fobs you want to program for this vehicle in hand, programing erases all old fobs. turn the ignition switch to on(all dash lights light up, on click before starting the car). then hit the lock button on one of the fobs. turn the ignition to lock. turn the ignition back to run and press the lock button again from the same remote. repeat untill all the locks cycle. ones the locks cycle keep the ignition in run and press the lock button on each key fob(the ocks will cycle each time a button is pressed). then turn the ignition to lock after all fobs have been programed
Dec 31, 2009 | 2009 Honda Pilot
My key won't turn the ignition. Can not start my 2003 Honda Pilo
Make sure it's fully in park. Try wiggling the steering wheel as you turn the key.
Aug 03, 2009 | 2003 Honda Pilot
Key won't turn on 2003 Hoda Pilot
Sometimes the steering wheel will put pressure on the switch from the steering lock. Try this:
- insert the key that usually works
- with your foot on the brake, make sure the shifter is fully in park
- while turning the key, move the steering wheel left or right firmly
Jun 20, 2017 | 2003 Honda Pilot
Vehicle Parts & Accessories Logo
65 people viewed this question
Top Vehicle Parts & Accessories Experts
Thomas Perkins
Thomas Perkins
Are you a Vehicle Part and Accessory Expert? Answer questions, earn points and help others
