Logik freesat hd
Sound has stopped on hd channels
  • 383 Answers
Check HDMI Cable
Posted on Mar 29, 2014
3 Suggested Answers
Nova_1
  • 196 Answers
SOURCE: record and watch different channels with freesat
I believe that the Humax can only output 1 channel and because it has no built in hdd and twin channel capabilty that is all you can record 1 channel (unlike sky +/sky HD) so that means also that unless you watch a different source (like the picture from your aerial (terrestial channels)) you are stuck with having to watch the channel you record
Posted on Oct 12, 2008
SOURCE: I have a logik DVD/HDD recorder with built in
Put the main aerial lead into the dvd tune in the channels,once in then it will not scan.
Posted on Oct 17, 2009
My Logik freeview box has will not tune some channels - most are fine. What can be done to fix this?
Usually that is caused by poor signal strength or a faulty tuner inside the receiver. Replacement boxes are only £18 upwards.
Nov 23, 2014 | Televison & Video
Code for logik l22fed tv
I have a logik 22'' HD model no L22fedc the sound works but have no picture can anyone help
Jun 15, 2013 | Televison & Video
Need a master code to reset my dtr94 hd freesat tv reciever/recorder
From memory you need to get the channel list up then press green to unlock each channel in turn if any have been locked.
Aug 08, 2011 | Sagem PVR 6280 Freeview DTV Receiver /...
I have a sharp aquos 32DH500E TV and have difficulties with receiving all the freeview DTV channels. I've used the auto tune function and get most freeview channels but not ITV, C4, C5 and the signal on...
Your lack of channels is from a specific group and is usually caused by poor signal from your aerial. A new larger aerial may solve that.
Freesat is OK if you have a dish installed.
Jun 03, 2017 | Sharp Aquos LC-32G4U 32 in. HD-Ready LCD...
How do i connect my samsung dvd recorder sh853m to my free sat box? Also is it possible to record a channel from free sat onto my samsung recorder while also watching a different free sat channel.
If it's a Standard-Definition (SD) FreeSat box then a SCART cable would be the normal method of connection to your DVD recorder. This would connect to the SCART/EXT OUT socket on the back of the FreeSat box and the SCART/EXT IN on the DVD recorder. However, this depends on whether your FreeSat box has multiple SCART outputs and whether you are using a SCART cable to connect to the TV.
If there is no spare SCART output socket on the FreeSat box, then you need to use an alternative connection which is common to both devices, i.e. co-axial, and make sure you are connecting from an OUT socket on the FreeSat box to an IN socket on the DVD recorder.
If you have a FreeSat HD box, then you need to connect it to the DVD recorder using an HDMI cable or another cable type that will carry an HD signal.
You will only be able to record from a different Satellite channel if you have a Dual LNB with 2 feeds to the FreeSat box. The LNB is the receiver that attaches to the arm on the satellite dish. You can determine whether you have a Dual LNB as you will have 2 cables from the Dish to the FreeSat box. They may be joined as one cable, but there will be 2 F-plugs (threaded co-axial plug) on each end.
If you don't have 2 cables then you will only be able to record the same channel as you are watching. To record another channel, you need a FreeSat box that supports this feature and each channel needs also a separate feed from the dish.
Hope this helps. If you need any further assistance please post back with the brand model number of your FreeSat box and details of the connections you are using between the FreeSat box, the TV and the DVD recorder.
Regards,
BElectric
Dec 29, 2010 | Samsung Televison & Video
I can't get Channel 4, E4, More4 etc. on freesat
Channel Four is available on Freesat as follows:
Channel 4 Freq 10729 Vertical 22000 5/6 -
Enter these figures on your 'Search for Channels' menu, and it should turn up Channel Four.
Mar 10, 2010 | Grundig GUFSAT02SD
I am about to receive an LG32LF4700 Freesat/HD TV If I disconnect the SKY Box and connect the TV direct to the Dish cable will I receive Freesat HD channels. Also can I connect an extra bedroom TV into the...
Yes you can split the signal out from the back of the Freesat/HD (not the TV)to the second TV.
Look what outputs are on the Freesat box - the RF (standard cable) output should go to the 2nd TV (TV set to CH3) and the a/v cables,HDMI or DVI cable should go to the new TV - Note:To receive HD the output from the Freesat should be either HDMI,DVI or Composite output (RGB video jacks) with red White for audio. If you have HDMI this is best - it also provides audio.
Oct 28, 2009 | LG 42LC2D 42 in. LCD HDTV
No sound on hd tv thru freesat
HDMI to DVI adaptors do not always support audio.You have to run seperate audio into the TV.
Jan 12, 2009 | Televison & Video
Record and watch different channels with freesat
Oct 12, 2008 | Televison & Video
Televison & Video Logo
24 people viewed this question
Top Televison & Video Experts
Electro Med Services...
