Question about Profoto D1 500W/s Monolight
How to program battery mode
Trying to program battery mode
Goodmans tv is stuck in radio mode, the radio/tv button doesn't change it. How do I get back to tv?
It is most likely that button is damaged. You can change that button and see if it works.
Nov 15, 2016 | Goodmans Televison & Video
2004 ford taurus keyless programming mode activate problems
first check for blown fuses and confirm that all are good next what are you trying to program? and this sequence has to be done quickly and the ignition left in the run position if its a key fob you must touch a button on it don't forget that if the sequence is not done properly the system has to time out before you try again if its a chip key theres a battery in some of them
Sep 01, 2017 | 2004 Ford Taurus
Remote doesn't control on/off,volume or channels
Remote won't workThe most common reasons the remote won't work is that the batteries are dead or it hasn't been programmed properly. It's often easy to fix. Here are the steps to take to troubleshoot the problem.
Make sure you have a clear path between the remote and the infrared eye on your equipment. Clear any dust or debris that may be covering the eye.
Try unlocking the battery-saving mode. When a button is pressed for longer than three minutes, the remote goes into battery-saving mode. Press the SAT mode button at the top to unlock it. Your remote should work properly.
Check the batteries. When you press a mode button, does it light up? If not, you may be out of juice. Check to make sure they are in the right way, with the metal ends making good connections with the metal in the remote. If they're in correctly and you still don't get power, try replacing them. They may be dead.Learn about batteries
Check to make sure the remote is programmed properly, which basically means you reprogram it to work with your receiver, TV and any other components. Start with the receiver and work your way through programming each component that isn't working. We tell you how to program remotes in our guide to remotes.Learn about remotes
Still no go? You may have an internal problem with the remote. You'll have to talk to a Shaw Direct customer service representative. Call 1.888.554.7827.Be prepared to tell us:What components you have.All of the steps you've been through to try and solve the problem yourself.Can't change channels on receiverThis is almost always caused by a programming problem with the remote. Here are the steps to take to troubleshoot the problem.
Make sure you are in SAT mode. The receiver will only change channels when the remote is in the correct mode.Look for a timer. If you have a timer set, the receiver won't let you change channels. This ensures you don't miss recording a program with an external device. If a timer is set and you want to watch another channel, simply turn off the receiver and turn it back on.Learn about timers
Make sure the problem is with the remote and not the receiver. Try the buttons on the front of the receiver. Try to change channels. If your model doesn't have channel buttons, try to turn the machine off. If you can't change channels or power off, the problem is with the receiver. Try unplugging it for two minutes and plugging it in again.
If you can change the channels or power off, the problem is with the remote. Press any mode button on the remote. It should light up. If not, you probably have low batteries. They should be replaced.
Try unlocking the battery-saving mode. When a button is pressed for longer than three minutes, the remote goes into battery-saving mode. Click on any of the mode buttons at the top to unlock it. Your remote should work properly.
Try re-programming the remote to talk to your receiver.Find the manual for your remote control
Check to see if your Shaw Direct Receiver is using the same remote control address as your remote control.If you are using the DSR 319, HDDSR 505, or HDPVR 530 receiver press the Options button on the front panel of your Shaw Direct receiver. An options menu should appear on your screen. Using the direction keys on the front of your receiver navigate to 6 - System Setup and then press the Enter button on the front panel of the receiver. Using the same directional and Enter buttons go to 4 - System Setup. Then 3 - Installation Settings. Followed by 2 - Remote control Address.If you are using a legacy receiver such as the DSR 315, DSR 405, or any other receiver with front panel buttons, press the Options button on the front panel of your Shaw Direct receiver. An options menu should appear on your screen. Using the direction keys on the front of your receiver navigate OPTIONS and then press the Enter button on the front panel of the receiver. Using the same directional and Enter buttons go to 6 - Change System Settings. Then 3 - Change Installation Settings. Followed by 2 - Set Remote Control Address.Follow the on-screen instruction to reset the remote control address on your receiver and remote control.Check the back of your remote, if you own the IRC/URC 550 or RT-U50 remote controls you will need to enter the remote control address differently from what is displayed on screen. To program these remotes, hold the ENTER and MUTE button on your remote at the same time until the mode buttons at the top start to illuminate then enter the last three digits of the number displayed in "Current Address" column on the screen, then press the MUTE button to lock in the code. For example: If the remote address on the screen displays 0002, you would hold ENTER + MUTE until the mode button illuminated and then enter 0 0 2, followed by ENTER on your remote control.If you own the IRC 551 or URC 551 remote control you can follow the instruction depicted on the screen, but you must substitute the follows numbers in place those specified: 00869 for 0000, 01870 for 0001, 01871 for 0002, 01872 for 0003, 01873 for 0004, 01874 for 0005, 01875 for 0006, 01876 for 0008. For example: If the remote address on the screen displays 0003, you would hold the SAT button until it flashes, press 01872, then ENTER, to lock in the new code.Still no go? You may have an internal problem with the remote. You'll have to talk to a Shaw Direct customer service representative. Call 1.888.554.7827.What components you have.All of the steps you've been through to try and solve the problem yourself.Can't control TV volumeThis is almost always caused by a programming problem with the remote. Here are the steps to take to troubleshoot the problem.
Press the volume button on the remote. The TV mode should light up. If not, you probably have low batteries. They should be replaced.
If the SAT button lights up, you are in the wrong mode. Press TV and try again.
Try re-programming the remote to talk to your TV.Find the manual for your remote control
Still no go? You may have an internal problem with the remote. You'll have to talk to a Shaw Direct customer service representative. Call 1.888.554.7827.What components you have.All of the steps you've been through to try and solve the problem yourself.Thank you for using Fixya, Hope this will help your problem.Don't forget to rate me.thanks,Reymond
Oct 18, 2011 | JVC AV-27850 27" TV
I have the timer programmed but what mode should it be in Off, Auto or Random? I had it in Auto but the timer did not start at 10 am as programmed! Help!
HB88RC is discontinued timer, replaced by 2-outlet HB800RCL or 1-outlet HB800RCH.
Timer functions should work in AUTO.
Try resetting timer by removing AA battery, reinstall fresh battery, and then reprogram timer.
When programming is finished, press clock button and timer should be in AUTO mode and current time displayed.
If you want to change mode, then press mode button. When exiting mode, press clock button and timer should be back in AUTO mode.
If functionality does not restore, then timer has gone bad.
http://waterheatertimer.org/Woods-timers-and-manuals.html#6-24
http://waterheatertimer.org/pdf/hb88rc.pdf
Jul 05, 2011 | Intermatic HB88RC Outdoor Timer
My ST01c unit is stuck on MANual and I can't get to the SETUP option.
The timer initializes in MANual mode.
To reach SET UP, press MODE button until set-up displays.
If MODE button does not work, then timer has a serious glitch.
1) If this is a timer that worked correctly before, and recently malfunctioned, then try replacing CR2 battery. The timer display and programming functions are dependent on the battery, so when battery starts going dead, the timer does odd things.
http://waterheatertimer.org/ST01C-program.html#battery
2) Try resetting timer.
Hold down ON-OFF button and then push reset button for two seconds.
Release Reset button, but keep holding ON-OFF button until display flashes INIT.
Then release ON-OFF button and 12:00 displays.
Following page has easy to follow programming steps:
3) ST01C has 1 year limited warranty, and people write in about defective timers each day.
There are no repair parts other than the battery.
Manual says when all other attempts fail, then reset timer as described above.
http://www.intermatic.com/products/timers/consumer%20indoor%20timers/in-wall%20timers/st01c.aspx
4) If this is new timer, then exchange defective timer for new timer.
I test timers: 4-6% arrive defective. Many go bad first year or two. Some last quite a while.
Some programmable timers can be reset and the timer recovers, as described above.
Add a comment for more free help.
Also take advantage of fixya phone service.
For a price, fixya expert speaks with you over phone while you work on timer.
Jan 05, 2011 | Intermatic Inc. ST01C Digital In-Wall...
Hi, How can i restart my lap top after i was deleting a program it stopped working, it doesn't want to start or to shut off
Nermine,
The program you were deleting, wasn't windows right.
Try this.
remove battery and power supply. that should turn off your unit.
put them back in... and press F8 as it is booting..
This is SAFE Mode in windows. If you boot up in that mode.. then try rebooting and boot normally.
Jul 28, 2010 | Computers & Internet
Key fob not working after battery change ford focus 2006
Try reprogramming it.
1. Turn the ignition from OFF to RUN 4 times within 6 seconds.
2. Turn the ignition OFF. The system will chime to confirm programming mode.
3. Within 20 seconds, press any button on first keyless remote.
The system will chime once to confirm programming.
4. Within 20 seconds, press any button on second keyless remote.
System will chime once to confirm programming.
5. Turn ignition to RUN to exit programming mode.
May 28, 2009 | 2006 Ford Focus
Radio in safe II mode
try disconnecting the battery overnight. that should put it back in safe mode 1.
Jan 09, 2009 | 1995 Audi S6
Phone Program
TAKE BATTERY OUT AND REINSTALL TO SEE IF THIS WILL RESET IT
Jan 18, 2008 | Motorola Mobility RAZR V3
Honeywell thermostat RTH230B
Sound like you need new one... take a look on amazon ecobee3 Smarter Wi Fi Thermostat Remote Sensor. It's not worth repairing it..
Jan 06, 2008 | Honeywell Programmable Thermostat Heater
Profoto D1 500W/s Monolight Logo
79 people viewed this question
Top Profoto Photography Experts
Tony
Are you a Profoto Photography Expert? Answer questions, earn points and help others
